Re: Gen III Hemi and B/RB Question
[Re: ahy]
#2015099
02/19/16 12:36 AM
02/19/16 12:36 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
All I can say is I went from a "good" running BB to a Gen III. The BB was a pump gas ,hyd cam, flat top, ported stock heads, RPM intake and FAST EZ TB EFI. At 3400 lbs the fastest it EVER went in the 1/4 was 112mph with Sunoco 112. Gen III has flat tops,ported stock heads, ported stock intake, hyd cam and EFI. At 3700 lbs it went 122 MPH first time out with 28 less cubic inches and pump 91.
Mopar to the bone!!!
[Re: 72Swinger]
#2015153
02/19/16 01:20 AM
02/19/16 01:20 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
496 12-1 indy ez heads 630 270 roller 3" exhaust 9.71@140
426 11-1 eagle heads. 600 250 hyd. 3" exhaust. 9.88@134
Same converter and gear
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#2016598
02/21/16 02:22 PM
02/21/16 02:22 PM
Posts: 12,400 Taxes & Virus's R-US, NY
Dragula
Same converter and gear I think there is a good advantage in weight reduction going to the G3 over an RB, no? Only draw back seems to be the cost. Do you know the approx cost for what each mill cost you? The Wedge I am guessing is in the $7500 range, but the G3 with headers and ignition has to be closer to +$10k I was thinking....Love you car and combo by the way...Seems like it does double duty really well. Which combo did you prefer driving wise and did you have the GV unit with the RB?
[Re: Dragula]
#2018058
02/23/16 02:27 PM
02/23/16 02:27 PM
sixpackgut
Charleston
Same converter and gear I think there is a good advantage in weight reduction going to the G3 over an RB, no? Only draw back seems to be the cost. Do you know the approx cost for what each mill cost you? The Wedge I am guessing is in the $7500 range, but the G3 with headers and ignition has to be closer to +$10k I was thinking....Love you car and combo by the way...Seems like it does double duty really well. Which combo did you prefer driving wise and did you have the GV unit with the RB? short blocks cost what short blocks cost basically for any combo or brand. my eagle heads were $422 and I ported them. My apache heads not on car yet cost 1200 My EZ heads cost around 2k and I ported hem to MW port My BB had $700 harlands. My gen 3 stock rockers headers same cost really. Actually I bought my fenderwells for the BB for $700 and got $600 for them when I sold them because the price went up so much. paid $740 for the TTI's ignition, same, when you add Dist, Coil and 6al to Hemi 6 controller I could go on and on but it all costs the same when you figure it out except I think the hemi block is better, the stock heads are better and if you want to go boost it would be easier I just sold the GV. I want to stop being so slow at drag week. My car is going on a diet and will be faster next year. I doubt I lost all that much weight going from the BB to the hemi. 100lbs maybe I think if I was a little more aggressive with the hemi it would be just as fast as my BB was. little more comp, a little more cam, etc
[Re: ahy]
#2018091
02/23/16 03:25 PM
02/23/16 03:25 PM
Triple Threat
Renton Washington
My Hemi is going to end up in the $12K range, I've been keeping track. That's intake to oil pan, water pump to flex plate using good stuff and including headers and ignition. It could be done cheaper, but you'd be making sacrifices IMO.
My experience is there isn't much difference in cost as Ray pointed out. Short blocks are pretty comparable price wise, SB, BB , G3. Headers are the same. Heads and rocker gear depends on what you want.
No matter how you cut it, when starting from scratch, building an engine isn't cheap.
[Re: ahy]
#2018100
02/23/16 03:53 PM
02/23/16 03:53 PM
72Swinger
Nebraska
Don't forget the $100+ for GOOD plugs wires that Gen III's don't need. But that might be offset by the 16 spark plugs....
[Re: sixpackgut]
#2018414
02/23/16 11:04 PM
02/23/16 11:04 PM
Dragula
Same converter and gear I think there is a good advantage in weight reduction going to the G3 over an RB, no? Only draw back seems to be the cost. Do you know the approx cost for what each mill cost you? The Wedge I am guessing is in the $7500 range, but the G3 with headers and ignition has to be closer to +$10k I was thinking....Love you car and combo by the way...Seems like it does double duty really well. Which combo did you prefer driving wise and did you have the GV unit with the RB? short blocks cost what short blocks cost basically for any combo or brand. my eagle heads were $422 and I ported them. My apache heads not on car yet cost 1200 My EZ heads cost around 2k and I ported hem to MW port My BB had $700 harlands. My gen 3 stock rockers headers same cost really. Actually I bought my fenderwells for the BB for $700 and got $600 for them when I sold them because the price went up so much. paid $740 for the TTI's ignition, same, when you add Dist, Coil and 6al to Hemi 6 controller I could go on and on but it all costs the same when you figure it out except I think the hemi block is better, the stock heads are better and if you want to go boost it would be easier I just sold the GV. I want to stop being so slow at drag week. My car is going on a diet and will be faster next year. I doubt I lost all that much weight going from the BB to the hemi. 100lbs maybe I think if I was a little more aggressive with the hemi it would be just as fast as my BB was. little more comp, a little more cam, etc The Hemi's will tolerate a lot of compression on pump junk. I would have probably stayed with the GV unit and thrown more gear at the engine. How much did it weigh and what gears were you running? If I built a 6.1 stroker, it would be 12:1 right out of the gate, and the ability to tune it with gasket thickness ....The rest, I would do like yours. I like it a lot. I can't think of a better NA combo than yours in an A body. My 512 should be in the 9.60's this year on pump gas, so we have learned how to make one of those run....But I am not sure we could hook that on a small drag radial. It does not like like a lot of rpm..But a 1.32 60ft really gets the thing moving in a hurry. Now my 605 is more built for mid 9's in street trim....I am debating going to a 315 radial in the rear over the M&T street cheaters I normally run...My biggest gripe...M&T does not make a matching radial front runner in 28" diameter..
[Re: ahy]
#2018531
02/24/16 01:20 AM
02/24/16 01:20 AM
sixpackgut
Charleston
One of the things is my BB would have went 9.50s or better. The very next pass after the 9.71, i opened the cutouts. Waited for ever after an oil down. It bogged real bad, 1.6x 60ft and ran the exact same 9.71.
I had 4.10s in it with the GV. It felt better in 1st gear but its just to much weight to compete at DW where guys are outspending me 3 to 1. The 727 with 3.55s was faster although it felt like a dump truck.
I am now going 904 with a low gear set and 3.73 gears. I think with some tuning and the weight loss I may see low 9.7s and still be able to run 70 mph and get 14+ mpg
The gv and 4.10s vs 727 and 3.55s was about the same on the highway
Right before DW, i added over 100lbs and the rotating weight of the GV, plus the fact i entered in the sealed hood competition caused my poor performance. Im ashamed how bad i got my azz kicked by the aluminum block, trick flow head, liberty trans fox body
[Re: ahy]
#2018659
02/24/16 11:05 AM
02/24/16 11:05 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
"Im ashamed how bad i got my azz kicked by the aluminum block, trick flow head, liberty trans fox body" Ashamed of what? Getting beaten by someone that didn't have stock off the shelf parts as a base? Kinda like comparing an SS motor to a Comp Eliminator motor, isn't it? Sounds to me like you are learning, and having a good time at it to boot.
[Re: gregsdart]
#2018779
02/24/16 03:03 PM
02/24/16 03:03 PM
sixpackgut
Charleston
"Im ashamed how bad i got my azz kicked by the aluminum block, trick flow head, liberty trans fox body" Ashamed of what? Getting beaten by someone that didn't have stock off the shelf parts as a base? Kinda like comparing an SS motor to a Comp Eliminator motor, isn't it? Sounds to me like you are learning, and having a good time at it to boot. I should have had been making a better showing the past 2 times. "PPPPP"- one of the Motown Missile quotes poor preparation pizz poor performance
