I'm currently running an SSBC drum to disc brake conversion kit (part# A156) and my question is if it's possible in any way to keep using this brake kit with the new 2 inch dropped spindle that is based on the 73 and later big bearing? Is it possible to just change the rotor and the bearings? The current rotor got a diameter of 11.25" and 0.8125" thickness.
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600) 1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600) 1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
