Early 1968 383 four barrel Dodge Charger air cleaner #2016214
02/20/16 06:39 PM
02/20/16 06:39 PM
Canada
CrAzYMoPaRGuY Offline OP
Canada
My buddy has a 1968 Dodge Charger, early build date.
He has a 383 4 barrel, it has a dual snorkel air cleaner. The "bell" on the top where the air cleaner stud goes through is small.
Can anybody post the correct air cleaner pie plate he needs for his air cleaner?
Any input at all appreciated!
CrAzYMoPaRGuY
Re: Early 1968 383 four barrel Dodge Charger air cleaner [Re: CrAzYMoPaRGuY] #2016227
02/20/16 06:50 PM
02/20/16 06:50 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
383 4bbl Chargers did not originally have "pie plates"
how early - got more info you can share (fender tag?) - got pics?
Re: Early 1968 383 four barrel Dodge Charger air cleaner [Re: 6bblgt] #2016230
02/20/16 06:53 PM
02/20/16 06:53 PM
Canada
Canada
He has a book called "Charger, Road Runner, and SuperBee Restoration Guide". It states they should have a pie plate, that's the only reason he is looking.
It's very early, has the second emblem on the roof panels etc. I can ask him when he gets back but not sure how to post pics until I get home.
CrAzYMoPaRGuY
Re: Early 1968 383 four barrel Dodge Charger air cleaner [Re: 6bblgt] #2016250
02/20/16 07:15 PM
02/20/16 07:15 PM
Canada
Canada
Here is some pictures of the original Air Cleaner assembly...
If any other pics needed let me know
T2206_635915740529218750.jpgT2206_635915740530156250.jpgT2206_635915740550781250.jpgT2206_635915740931562500.jpg
CrAzYMoPaRGuY
Re: Early 1968 383 four barrel Dodge Charger air cleaner [Re: CrAzYMoPaRGuY] #2016254
02/20/16 07:19 PM
02/20/16 07:19 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
No pie tins for that air cleaner. I think they do make a decal though.
Re: Early 1968 383 four barrel Dodge Charger air cleaner [Re: CrAzYMoPaRGuY] #2016295
02/20/16 08:38 PM
02/20/16 08:38 PM
Canada
Canada
Pictures of Fender Tag (August 18, 1967)
CrAzYMoPaRGuY
Re: Early 1968 383 four barrel Dodge Charger air cleaner [Re: CrAzYMoPaRGuY] #2016314
02/20/16 09:21 PM
02/20/16 09:21 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
AwEsOmE!! drool
I'll ASSUME it's a California car and correct as it appears, IMO a red & yellow "air filter care" decal on the side is all it should have.
In '69 CA 383-4bbl b-bodies had different air cleaners and/or mufflers to comply with their "noise reduction" wishes. realcrazy Not sure if '68 was the same.
& lots of errors in that book
Re: Early 1968 383 four barrel Dodge Charger air cleaner [Re: CrAzYMoPaRGuY] #2016329
02/20/16 09:54 PM
02/20/16 09:54 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Didn't the RTs with AC use that aircleaner?
Careful, your character's showing!
Re: Early 1968 383 four barrel Dodge Charger air cleaner [Re: mopar346] #2016341
02/20/16 10:16 PM
02/20/16 10:16 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
The 17" unsilenced air cleaner that was used on 67 383 A-Body's were also used on early B-Body's. The base was different as there was a change from the AFB carb in 67 to the AVS carb in 68. I have seen a couple of survivor Chargers with that air cleaner. twocents Picture stolen off of the A-body Parts for sale section... whistling
JB Rhinehart, Realist
A-Body's RULE!
Re: Early 1968 383 four barrel Dodge Charger air cleaner [Re: CrAzYMoPaRGuY] #2016479
02/21/16 02:26 AM
02/21/16 02:26 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
The 383 68 Charger came with an unsilenced air cleaner with this pie plate.
Re: Early 1968 383 four barrel Dodge Charger air cleaner [Re: CrAzYMoPaRGuY] #2016531
02/21/16 10:36 AM
02/21/16 10:36 AM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
i believe there has been discussion about that book stating there are factual mistakes in many areas. at least i think that is the book. if not, please correct me.
beer
Re: Early 1968 383 four barrel Dodge Charger air cleaner [Re: CrAzYMoPaRGuY] #2017484
02/22/16 03:47 PM
02/22/16 03:47 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
That book is barely worthy of lining the bottom of a bird cage, I think it has more WRONG info than it has correct info.
Mainstream Media is the new Pravda
Re: Early 1968 383 four barrel Dodge Charger air cleaner [Re: CrAzYMoPaRGuY] #2017489
02/22/16 03:52 PM
02/22/16 03:52 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
My early build 68 Sport Satellite convertible 383-4bbl, that had a Langely AFB sticker on the front bumper and red clay all over the underside of it, had that exact dual snorkel air cleaner in the trunk when I got it.
Original, no clue? But I'm pretty sure it was considering how original everything else, except the paint, was.
Re: Early 1968 383 four barrel Dodge Charger air cleaner [Re: CrAzYMoPaRGuY] #2017548
02/22/16 05:30 PM
02/22/16 05:30 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Quite frankly I think you'll find there is no pie tin that will fit or even sit on your air cleaner.
Look at the picture of yours here and the picture below of one that takes a pie tin, and look at the lid contour differences.
The bevel on the one below accomodates the pie tin.
On yours that area is too tall and the bevel concave where wingnut rests, is much smaller.
