Re: Rear brake ? On 84 D150
[Re: 98RAM1500]
#2017403
02/22/16 03:00 PM
02/22/16 03:00 PM
Posts: 10,585 Freeport IL USA
poorboy
Freeport IL USA
If your saying that with the truck idling in gear, the rear brakes won't stop wheel rotation, the rear brakes are not working properly.
There is not an anti-lock feature for the rear brakes is there? Rear end in the air, will reduce or stop rear brake function if the anti-lock system is functioning.
If no anti-lock system is present, I would begin with checking the adjustment of the shoes, they may be too loosely adjusted. Then make sure the shoes are not glazed over or grease or brake fluid soaked. A lot of brake dust will also reduce the effectiveness of the brakes.
Beyond that, the concern would be not enough brake fluid movement or volume to over come the return springs and apply pressure of the brake shoes against the drum. Look for leaks, bypassing master cylinder, or a not centered brake proportioning valve.
Then be sure the pads the shoes rest against on the backing plates are smooth and lubricated so the shoes can actually move and are not stuck in groves or stuck to the pads.
Rear drums that are worn too thin can deflect when brake pressure is applied and can make the brakes less effective. Gene
[Re: 98RAM1500]
#2017462
02/22/16 04:03 PM
02/22/16 04:03 PM
Posts: 32,943 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
Are the shoes adjusted to where they have a slight rubbing sound when the drums are rotated? Are you getting good pressure out of the bleeders?
