588" motor,,,
#2016809
02/21/16 08:55 PM
02/21/16 08:55 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
I am having Todd at Marsh Performance build my motor for me. after reading about the motor he built for moparts member Tig, I knew I wanted him to build mine. It specs:
588 ci indy aluminum block indy 572-13 heads 410-420 cfm diamond gas port pistons 4.5" bore 13.5-1 cr callies 4.625 crank cam motion solid roller 282/290@.050 .800/.751 indy 3x intake 1150 dominator isky xmax bushed lifters jesel 1.7 rocker arms oliver rods 7.100"
this is going in my 68 formula S fastback cuda. it is a 4 speed car, with a 3.73 moser dana 60. it also has a hemi denny front coil over front end.im hoping for about 3200 pounds. this is a street car only.
anybody want to guess the hp and tq for motor? I'm hoping for 900hp and 800 tq. Todd will dyno it, so I will know what it makes, and will post the results. I should have it very soon!
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: 588" motor,,,
[Re: Old School]
#2016822
02/21/16 09:11 PM
02/21/16 09:11 PM
Old School
Virginia Beach, VA
The car it is going in....
Re: 588" motor,,,
[Re: Old School]
#2016849
02/21/16 09:28 PM
02/21/16 09:28 PM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Should hit the mark! Depends on a lot of things,, vacuum pump? Ring pack? Fuel?
Re: 588" motor,,,
[Re: gregsdart]
#2016867
02/21/16 09:43 PM
02/21/16 09:43 PM
Old School
Virginia Beach, VA
no vaccum pump. 110 Sunoco race fuel. I don't know the ring details. I know the pistons are gas ported.....
Re: 588" motor,,,
[Re: Old School]
#2016873
02/21/16 09:47 PM
02/21/16 09:47 PM
Posts: 4,255 Canada
WO23Coronet
Canada
No expert hear but your goal sounds pretty doable to me. Going to be a ridiculous ride with a 5 spd!!! What kind of tranny are u going with?
Re: 588" motor,,,
[Re: WO23Coronet]
#2016882
02/21/16 10:02 PM
02/21/16 10:02 PM
Old School
Virginia Beach, VA
No expert hear but your goal sounds pretty doable to me. Going to be a ridiculous ride with a 5 spd!!! What kind of tranny are u going with ? I wish it was a 5 speed! I built a 18 spline 4 speed for it....
Re: 588" motor,,,
[Re: racerx]
#2016905
02/21/16 10:28 PM
02/21/16 10:28 PM
Old School
Virginia Beach, VA
what suspension under it? Good luck with it. It has a Hemi Denny coil over up front. HD leaf springs out back.
Re: 588" motor,,,
[Re: Old School]
#2016909
02/21/16 10:33 PM
02/21/16 10:33 PM
Posts: 17,923 Akron, Ohio
ProSport
Akron, Ohio
Nice car with a badazz motor! That thing is gonna be a ridiculous handfull and I commend you for that!
Re: 588" motor,,,
[Re: ProSport]
#2016911
02/21/16 10:37 PM
02/21/16 10:37 PM
Old School
Virginia Beach, VA
Thanks Prosport! I will post the dyno sheet when it is done. should be very soon. the builder has all the parts needed now.....
Re: 588" motor,,,
[Re: dvw]
#2016915
02/21/16 10:40 PM
02/21/16 10:40 PM
Old School
Virginia Beach, VA
You better get some suspension and tires. It's all I can do to get my 572 to hook on 10.5's at the track.That should be 8 second power at 3200. Doug its just a street car. it does have 275/60 15,s. I think I can put the next size up tire on it thou. it still has room....
Re: 588" motor,,,
[Re: Old School]
#2016916
02/21/16 10:41 PM
02/21/16 10:41 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Great stuff, it will be an animal.
1963 Plymouth Max Wedge 1971 Barracuda
Re: 588" motor,,,
[Re: slantzilla]
#2016934
02/21/16 10:55 PM
02/21/16 10:55 PM
Old School
Virginia Beach, VA
If nothing else you will be the burnout king in your neighborhood. I'm already that with the other cars... it will have a fiberglass hood, with a ss style scoop. it also has fiberglass bumpers, lightweight brackets, deck lid. it has lightweight willwood brakes front and rear. with the aluminum motor and coil over front end, I am hoping for about 3200 pounds.... maybe that will help a little with traction
Re: 588" motor,,,
[Re: Old School]
#2016967
02/21/16 11:36 PM
02/21/16 11:36 PM
Posts: 9,881 Weddington, N.C.
Streetwize
Weddington, N.C.
Hey Old School, I hope you are doing great my friend!
Have you thought about getting Todd and my buddy Larry Smith to port a mopar 337 for you?
It might fit under the hood and it might be as good or better on a mild big motor as the indy
Just a thought....heres a pic of the 337 Larry did for my 517
Re: 588" motor,,,
[Re: Old School]
#2017001
02/22/16 12:14 AM
02/22/16 12:14 AM
Old School
Virginia Beach, VA
Hi Bobby I am doing well buddy! I believe that is who Todd has porting my heads for me. I think I will have them port a 337. When we dyno, I will have them test the 337 and the 3x. On a motor this size it will probably be a big difference between the two.
Do you live near Todd? I was at his shop Friday.....
