Wiring Woes #2015726
02/19/16 11:04 PM
02/19/16 11:04 PM
Ohio in the USA
O
Omni Source 1 Offline OP
O
Ohio in the USA
Good Day All
I have a tilt wheel column shift 71 Charger. I'm looking for the short wiring harness that connects the column mounted ignition switch to the main harness.
I have contacted both Evans and M&H with no luck. Does anyone know of a supplier or where I could locate one?
Thanks for your time.
Omni
Re: Wiring Woes [Re: Omni Source 1] #2015940
02/20/16 09:05 AM
02/20/16 09:05 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Don't know of any off the shelf ones but have you checked pickups and vans? F,M,J bodies too, all had a similar jumper harness when equipped with tilt wheel.
Angry white pureblood male
Re: Wiring Woes [Re: ruderunner] #2016187
02/20/16 06:33 PM
02/20/16 06:33 PM
NC
1970A66 Offline
1970A66  Offline
NC
I wonder if this could work:
https://www.hiltopautoparts.com/product/...ith-tilt-wheel/
Not cheap but...........
