Re: A couple questions on Borgeson box install
[Re: redmist]
#2013054
02/16/16 12:30 PM
02/16/16 12:30 PM
Posts: 1,033 Madison, Wisconsin
chrisnben
Madison, Wisconsin
Call Bergman- he owns, races, and sells these 'kits'. Get it from the Horse!
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
[Re: chrisnben]
#2014443
02/18/16 02:19 AM
02/18/16 02:19 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Call Bergman- he owns, races, and sells these 'kits'. Get it from the Horse! Yeah...Piss off already ! Kidding of course. My guess is that the OP probably wants to call, but maybe is unable to do so during regular business hours. Sometimes, guys with experience are lurking around here at odd hours, just waiting to help out!
[Re: redmist]
#2014498
02/18/16 04:58 AM
02/18/16 04:58 AM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
At the risk of stepping into this quagmire again, do a search on Borgeson box and postings under my handle, or Hotchkis. Likely if shaft is not in perfect alignment with steering box you will be looking at shimming the box in order to obtain proper toe in whilst having steering box on top center.
The shim seen in the 2nd photo was placed there to correct the angle seen in the 1st photo. Without the shim, was impossible to obtain proper toe. This on 70 Challenger.
The adapter spines do not have a master spline to steering box, this permits you to achieve proper steering wheel alignment.
Roll pin is eliminated. Set screw on adapter should point at 9 pm toward driver side of car when steering box is on top center. If not,,,,,again is a clue that steering box must be shimmed when toe is properly set.
[Re: redmist]
#2014647
02/18/16 02:13 PM
02/18/16 02:13 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
I'm interested in the Borgenson ps box... but I'd prefer to install the longer fast-ratio pitman arm (with the longer idler arm, as well).... making the ratio ~11.7:1 vs the T/A = 12.7:1.
The pictures shown above... with the angle of the shaft... is that corrected by adding the shim?
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2014721
02/18/16 03:57 PM
02/18/16 03:57 PM
Sxrxrnr
Northern Calyfornua
Yes. Until I added the shim I was unable to obtain toe within specs unless the steering box was indexed at about 10:30 o'clock,,,given if you were to consider 12 noon at proper top center index.
This forces steering shaft a straight shot into steering box with no angle created at coupler, which is as should be.
In short, if steering shaft was straight with your old steering box and not so when Borgeson is installed, you may have a problem that will require shimming or other remedial action before proceeding. I had considered several possible options before going with shimming,,drilling 2 holes in 1/8 inch X 1 inch wide X about 2 inch or so long steel stock.
I have since ordered up the correct mounting bolts to replace the incorrect Grade 8 bolts I used as shown in the photo. Threads on original mounting bolts were quite buggered for some unknown reason.
My understanding that Borgeson has now chosen Mustang boxes as the basis of their Mopar replacement boxes. Earlier one's were reconditioned Mopar boxes(Jeep believe) as I understand,,,however they do certainly appear externally different than that in my case on my E Body,,,,am uncertain which Mopar if not Jeep. These replacement boxes are smaller and 15 pounds lighter than stock Mopar box and do clear my 2 inch TTI headers much better. The Mustang box is reputed to be even smaller
Therefore this potential issue regarding shimming requirement may no longer exist.
As an aside, I recently installed Borgeson in wife's 55 T Bird. Outside of the fact that Borgeson does not offer a kit for a T Bird and was forced to adapt a Ford sedan's kit,,,a substantial difference from what a T Bird requires,,,was able to make it work. Likely had some 50 hours of effort and false starts to achieve success. Told by Borgeson tech that this was a first on a T Bird.
Was able to make it work with no Borgeson related issues and very pleased with outcome,,,which incidentally am also quite pleased with outcome on our Challenger,,,albeit a real pita.
[Re: redmist]
#2014844
02/18/16 07:06 PM
02/18/16 07:06 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Mine needed a shim as well, maybe 1/8" thick. Still worth it.
Mopar to the bone!!!
[Re: Mopar Mitch]
#2014876
02/18/16 07:37 PM
02/18/16 07:37 PM
Posts: 2,432 NorCal
RylisPro
NorCal
I'm interested in the Borgenson ps box... but I'd prefer to install the longer fast-ratio pitman arm (with the longer idler arm, as well).... making the ratio ~11.7:1 vs the T/A = 12.7:1. Let me know how well your install goes Mitch! I forget if you have a small block? I am considering the same setup and will go for it only if you get good results. Hard to justify spending a grand if its gonna be another PITA
[Re: redmist]
#2014973
02/18/16 09:35 PM
02/18/16 09:35 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
My box is shimmed...and I have the Bergman installation stuff. One of the best things I ever did to the car. It's NOT the same thing as tightening the lash on the stock box.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: BergmanAutoCraft]
#2033842
03/18/16 03:30 PM
03/18/16 03:30 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Why people dont call and ask me these questions is beyond me.... So provide us some feedback on the differences between the mustang and Jeep boxes? Impression on the changes, etc. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
