Re: A833 rear seal replacement
[Re: robertop]
#2013836
02/17/16 11:53 AM
02/17/16 11:53 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
Piece of cake, after you remove the driveshaft.
Make sure to get the booted seal and get a piece of PVC pipe that touches the outer steel ring to put it back in.
[Re: robertop]
#2014054
02/17/16 04:45 PM
02/17/16 04:45 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
I made my "drift" for replacing my A-833 rear seal using a large 1/2" bolt, a big washer (same size as metal of rear seal) and smaller washers on either side of the big one + a nut. Wipe a little grease on the seal/tail shaft hole, line it up and drive it in with a hammer (2-3 hits will do it, doesn't need to be all that hard).
WRONG - SORRY! SEE MY LATER POST
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: PurpleBeeper]
#2015514
02/19/16 04:37 PM
02/19/16 04:37 PM
JohnRR
I made my "drift" for replacing my A-833 rear seal using a large 1/2" bolt, a big washer (same size as metal of rear seal) and smaller washers on either side of the big one + a nut. Wipe a little grease on the seal/tail shaft hole, line it up and drive it in with a hammer (2-3 hits will do it, doesn't need to be all that hard). You aren't replacing a BOOTED seal, like the stock factory seal, with that setup ... without crushing the outer boot that sticks about an inch past the metal ring.
[Re: robertop]
#2015644
02/19/16 08:08 PM
02/19/16 08:08 PM
Posts: 8,926 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Originally Posted By PurpleBeeper I made my "drift" for replacing my A-833 rear seal using a large 1/2" bolt, a big washer (same size as metal of rear seal) and smaller washers on either side of the big one + a nut. Wipe a little grease on the seal/tail shaft hole, line it up and drive it in with a hammer (2-3 hits will do it, doesn't need to be all that hard).
You aren't replacing a BOOTED seal, like the stock factory seal, with that setup ... without crushing the outer boot that sticks about an inch past the metal ring. I was thinking that too! It amazes me the number of people on this site that don't subscribe to the KISS principle. Post that you have a mouse problem in your shop and someone will suggest you make billet aluminum mousetraps !!
[Re: JohnRR]
#2019596
02/25/16 05:42 PM
02/25/16 05:42 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
I made my "drift" for replacing my A-833 rear seal using a large 1/2" bolt, a big washer (same size as metal of rear seal) and smaller washers on either side of the big one + a nut. Wipe a little grease on the seal/tail shaft hole, line it up and drive it in with a hammer (2-3 hits will do it, doesn't need to be all that hard). You aren't replacing a BOOTED seal, like the stock factory seal, with that setup ... without crushing the outer boot that sticks about an inch past the metal ring. Oh shiznit, you guys are right... wrong "drift". That's the one I used for my axle bearing races. For the rear seal on a A-833 I used a 2-1/2" or 3" pipe nipple with a cap on it as my drift. I guess PVC would work too. My bad.
[Re: Stanton]
#2019599
02/25/16 05:46 PM
02/25/16 05:46 PM
Posts: 21,854 Kirkland, Washington
Pacnorthcuda
You aren't replacing a BOOTED seal, like the stock factory seal, with that setup ... without crushing the outer boot that sticks about an inch past the metal ring. I was thinking that too! It amazes me the number of people on this site that don't subscribe to the KISS principle. Post that you have a mouse problem in your shop and someone will suggest you make billet aluminum mousetraps !! But the trailer-queen mouse trap people will beat a path to your door!
[Re: Pacnorthcuda]
#2019734
02/25/16 08:44 PM
02/25/16 08:44 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
But the trailer-queen mouse trap people will beat a path to your door! No sh!t !! I can't believe the amount of billet crap out there and most of it looks downright UGLY. A lot of the billet users could probably build a damn nice second car with what they've spent on billet crap.
