Re: Ammeter very fast fluctuation from middle to pegged out.
[Re: JL2]
#2013363
02/16/16 07:58 PM
02/16/16 07:58 PM
Posts: 4,848 Memphis
HemiRick
Memphis
the stock ammeter is only made for 40/60 amps so sending 90 amps of charge thru will melt it and peg it out. Bypass the ammeter and install a volt meter.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: JL2]
#2013389
02/16/16 08:29 PM
02/16/16 08:29 PM
Posts: 25,994 Rio Linda, CA
John_Kunkel
Rio Linda, CA
It seems that with these two new parts there were multiple directions on installation. With new compatible parts there is only one correct way to install them. Details? Just because the alternator is rated at 90 amps doesn't mean it's putting out that much all the time.
[Re: JL2]
#2013414
02/16/16 09:04 PM
02/16/16 09:04 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I am working on the very same problem on a 73 charger that I also installed a Powermaster alt and new voltage regulator (mopar) . This is the dual field alt and regulator with the triangular plug. I have the same exact situation with my setup. I bypassed the ammeter gauge and ran a 6 gauge wire from the alt directly to batt pos. and just hooked up a volt gauge inside. I confirmed the readings with a digital volt meter at the pos batt term as well as the alt. output stud and get the fluctuation . I also notice that when it fluctuates, the alt. makes a sound also (maybe corresponding to the higher charging rate).
I just tried a 2nd new volt regulator and same thing. I have a few other things to look at, but i am running out of ideas also. I don't think it is the alternator .
[Re: Chargerfan68]
#2013425
02/16/16 09:22 PM
02/16/16 09:22 PM
RapidRobert
I believe it IS the alt. Electronic regs either work fine or go open (which'd show a constant discharge) or full field & allow the alt to max charge (& when they act up (not often) they stay that way). I'd visual on the brushes/brush holders for anything loose & something/somewhere is intermittently grounding (full fielding) the field circuit. it is possible that with the part time open it shows a discharge then when the open makes contact again the ammeter shows a high charge or a maxed out charge (pegged) as it is trying to catch back up (depends on how long it is open & the loads at the time. Dig in & holler with any news
[Re: JL2]
#2013451
02/16/16 09:45 PM
02/16/16 09:45 PM
John_Kunkel
Rio Linda, CA
Grounding one field terminal is only if you're using the pre-'70 regulator, the regulator P/N in your OP is the '70 and later and it's wired like the diagram below.
[Re: JL2]
#2013826
02/17/16 11:40 AM
02/17/16 11:40 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
FWIW...the factory ammeter in my cuda shorted out and burnt the dash and engine wiring harness. When it happened, the ammeter was bouncing back and forth like you described. This was with a factory 60 amp alternator. I'd get rid of it and install a voltmeter.
[Re: HemiRick]
#2013942
02/17/16 02:43 PM
02/17/16 02:43 PM
Thumperdart
State of confusion
the stock ammeter is only made for 40/60 amps so sending 90 amps of charge thru will melt it and peg it out. Bypass the ammeter and install a volt meter. THIS...........Did it years ago and also ran separate alt wires bypassing the stock bulkhead and goes to 14.5-14.7 the second it starts......
[Re: JL2]
#2014146
02/17/16 07:57 PM
02/17/16 07:57 PM
Posts: 360 Ohio
shorthorse
Ohio
I just installed a new Powermaster 90 amp alternator on my car along with a new VR part # BWD R296. It seems that with these two new parts there were multiple directions on installation. One way I would not get a reading from the alt showing a charge and nothing on ammeter in car. Another hooked up way, the ammeter would jump from the middle of ammeter to pegged on C with interior lights flickering etc. Hooked up the other way my ammeter would still flicker but when revving it up, the needle would straight out peg on C. I'm clueless on whats going on or even what to check. But previously before the new stuff, my ammeter would sometime hold right above the middle bar and then would just peg out, then would get normal again. Give Powermaster a call. I've worked with them before and got the best customer service anywhere. The first thing I noticed is they didn't start by telling me it was my fault. They worked with me and even contacted me later to check on my progress. I hope it works the same for you.
[Re: shorthorse]
#2014165
02/17/16 08:13 PM
02/17/16 08:13 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Also remember as someone stated that the alt will only put out what it needs to maintain the target voltage of the reg setting. You could put a 200 amp alt on the car and as long as its regulated right by the regulator it will only put out the needed current to maintain the voltage setting. So if you still have a mostly the stock setup but added a few things like electronic ign and fuel pump and fan that even with a battery close to dead the alt will put out just what it needs to hit the 14.5 or there about target voltage. Even with a 200 amps the alt may only need to put out 70 or 80 amps to maintain the target volts and supply the electrical load. Its always good to upgrade the wireing and bypass the ammeter and bulkhead connector on our older cars when larger output alts are installed but if you have not added much electrical load its not like it will fry your wire harness right away. I am guessing you are sure the alt you got does not have an internal regulator ? Ron
[Re: JL2]
#2014191
02/17/16 08:52 PM
02/17/16 08:52 PM
Posts: 16,163 Mesa, Arizona
dart4forte
Mesa, Arizona
I'm running a 60 amp round back Power Master. We bench tested it and it showed putting out 14.75 volts. I converted the amp meter to a voltmeter.
Abe Lincoln
[Re: Thumperdart]
#2014244
02/17/16 10:17 PM
02/17/16 10:17 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
the stock ammeter is only made for 40/60 amps so sending 90 amps of charge thru will melt it and peg it out. Bypass the ammeter and install a volt meter. THIS...........Did it years ago and also ran separate alt wires bypassing the stock bulkhead and goes to 14.5-14.7 the second it starts...... DO IT before it melts. They are nothing but a fire waiting to happen.
Mopar to the bone!!!
[Re: JL2]
#2014285
02/17/16 11:18 PM
02/17/16 11:18 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Although it will only output the amps it needs, the ammeter, being resistive will drive the alternator to high output. The ammeters in these cars are old. the resistance will cause a meltdown(at best) or a fire. The symptoms described are a precursor to the latter...
