8 3/4 posi parts source #2012368
02/15/16 01:03 PM
02/15/16 01:03 PM
Chicago land, IL
dafixr Offline OP
dafixr  Offline OP
Chicago land, IL
Looking for replacement parts for a 8 3/4 Borg Wanner cone type posi unit
Does anybody know of a source where we can can some replacement parts from.
Also does anybody have a parts breaksdown showing the parts and numbers.
Re: 8 3/4 posi parts source [Re: dafixr] #2012373
02/15/16 01:08 PM
02/15/16 01:08 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I don`t think any of the parts are serviceable on the cone type sure grip. I think some people have rebuilt them with shim washers and machine work. I`m pretty sure I have a NOS unit somewhere around here.
Re: 8 3/4 posi parts source [Re: mopars4ever] #2012399
02/15/16 01:40 PM
02/15/16 01:40 PM
dogdays Offline
dogdays  Offline
They are not repairable, were not designed to be repaired. The current manufacturer has a swap program but that's only for units manufactured by Auburn Gear, not the original Borg-Warner.
Do yourself a favor and buy a real limited slip from Doctor Diff.
R.
Re: 8 3/4 posi parts source [Re: dafixr] #2012425
02/15/16 02:08 PM
02/15/16 02:08 PM
Minn
SportF Offline
SportF  Offline
Minn
Actually I have rebuilt a number of these. If it simply the cone/housing wore so that the cone bottoms out, you can remove some from the bottom of the cone. A lathe is best, but you could use a grinder as well. But you should put a shim ( a great big washer) between the inside of the cone and the axle gear to shove it back into proper engagement with the spyder gear. That shim will also load the springs for the preload.
The bearings are standard parts. If you need gears or something that I don't know where you would get.
Now that I have said that, there will be a boat load of people that will tell you the cone type is the worst thing that will happen to you in your life. But I have not found that to be true.
Re: 8 3/4 posi parts source [Re: dafixr] #2012481
02/15/16 03:31 PM
02/15/16 03:31 PM
Middle TN
da50r Offline
da50r  Offline
Middle TN
The cone type I rebuilt lasted about 20k miles at most and became a 1 wheel peel again. I won't waste my time with another one.
