Re: Chinese Roller rockers
[Re: JudyLuvsBees]
#2011746
02/14/16 02:45 PM
02/14/16 02:45 PM
Posts: 25,894 United Socialist States of Ame...
tboomer
Don't buy junk. How is that for a suggestion? Check with Mancini,they used to sell a non needle bearing Harland Sharp rocker that is good. Also watch for a good used set of Isky iron ductile rockers. They pop up here from time to time.
[Re: JudyLuvsBees]
#2011754
02/14/16 02:52 PM
02/14/16 02:52 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Chinese rockers better than stock.
Oxymoron there.
Not gonna find Chinese rockers better than stock.
[Re: rickstershemi]
#2011757
02/14/16 02:56 PM
02/14/16 02:56 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
CK out Scorpian in Jegs or Summit....the are made in the USA and IMO the best of the Lower Buck Products.
Rickster I agree!!!!
Lead, follow or get the hell out of the way
[Re: JudyLuvsBees]
#2013673
02/17/16 01:39 AM
02/17/16 01:39 AM
Posts: 4,712 Moved to N.E. Tennessee
GomangoCuda
I`ve said it before and will likely say it again. Rocker arms is THE worst possible part to shop for by price.
[Re: 2boltmain]
#2014017
02/17/16 04:09 PM
02/17/16 04:09 PM
Supercuda
About to go away
About to go away
up yours
I realize your asking about big block rocker arms but I noticed new iron adjustable arms at mancini for only $260 when new iron adjustables for the B R/B are over $400. I wonder why the LA arms are so affordable? http://www.manciniracing.com/maraenadroar.html Only adjustable B/RB rockers I see are aluminum and cost the same as the SB ones. http://www.manciniracing.com/manciniracing21.html
[Re: rickstershemi]
#2014505
02/18/16 06:23 AM
02/18/16 06:23 AM
Posts: 10,130 A Red State
SNK-EYZ
A Red State
Rickster After searching online from what I can find Scorpion doesn't make rocker arms for Mopar (other than AMC). They don't show Mopar ones on Scorpion's website, or at Summit or Jegs.
[Re: JudyLuvsBees]
#2014508
02/18/16 07:46 AM
02/18/16 07:46 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Why do you want rollers? unless you jhave lift over 550 it will do nothing for you. Over 550 they will help somewhat with less side load scrubbing. They will give you know power gain over a set of good doctile iron adjustables. Have you ever cleaned up an engine that the roller rocker came apart in? Even the spendy ones do.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: SNK-EYZ]
#2014565
02/18/16 11:35 AM
02/18/16 11:35 AM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Rickster After searching online from what I can find Scorpion doesn't make rocker arms for Mopar (other than AMC). They don't show Mopar ones on Scorpion's website, or at Summit or Jegs. They list them on their website but not on Summit or Jegs. I'm gonna stop by Summit on my way home someday and see if they can explain why that is Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2014576
02/18/16 11:48 AM
02/18/16 11:48 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
I received an email back on 8-10-2015 stating the following from Scorpion about producing rockers for Mopars:
""We are about to release the bb Chrysler rockers but the small block rockers are still in the prototype stage with no honest e.t.a..
Scorpion Racing Products, Inc.""
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: fourgearsavoy]
#2014736
02/18/16 04:34 PM
02/18/16 04:34 PM
SNK-EYZ
A Red State
Rickster After searching online from what I can find Scorpion doesn't make rocker arms for Mopar (other than AMC). They don't show Mopar ones on Scorpion's website, or at Summit or Jegs. They list them on their website but not on Summit or Jegs. I'm gonna stop by Summit on my way home someday and see if they can explain why that is Gus I had to look again to find the Mopar rockers on Scorpion's website. They mainly put info about their stud mounted rockers and you have to look close to find the shaft mounted rockers. Some of their links don't work. If you click on catalog it's says "server not found". http://www.scorpionracingproducts.com/endurance-series---shaft-mount.html http://www.scorpionracingproducts.com/chrysler-shaft.html
