Re: REAR DIFF OIL...................
[Re: Thumperdart]
#2011106
02/13/16 03:08 PM
02/13/16 03:08 PM
Posts: 11,737 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I use Amsoil 75-90 when it's up to me. Have always had good results.
[Re: Thumperdart]
#2011118
02/13/16 03:22 PM
02/13/16 03:22 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I use 80-90 non syn in my 8 3/4.. maybe you should stick with what has worked since everyone says that you should have blown it up ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Thumperdart]
#2011158
02/13/16 04:32 PM
02/13/16 04:32 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
75/140 syn Valvoline has shown pretty significant temperature drops over 80/90 weight and its all I use, but, I wonder if heavier might be better in your case to maybe reduce shock loads? Is that even possible?
Mopar to the bone!!!
[Re: upnover]
#2011383
02/13/16 09:55 PM
02/13/16 09:55 PM
Thumperdart
State of confusion
Ever chassis dyno or do back to backs at the track to see what if any power/et is in syn oils including engine oils? I figured/hoped the syn Valvoline had maybe assisted in my junk living for 12 years street/strip w/a spool but who really knows............
[Re: Thumperdart]
#2011400
02/13/16 10:37 PM
02/13/16 10:37 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I would recommend 2 cups of Henry's Roofing mastic. One cup of cheap cooking oil. And a half a cup sawdust. Kind of old school thinking but bulletproof
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2011411
02/13/16 10:50 PM
02/13/16 10:50 PM
Thumperdart
State of confusion
Naw, already tried that stuff and it didn`t work too well for me............
[Re: Thumperdart]
#2011673
02/14/16 12:36 PM
02/14/16 12:36 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I use Lucas 80/90 heavy duty gear oil. When I had a 9" I used Redline synthetic.
[Re: Thumperdart]
#2011701
02/14/16 01:43 PM
02/14/16 01:43 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Hey Dom,
I think that you're not loading up the gears enough to get a good pattern in the paint. But I have seen this before from guys doing this the first time. You're pattern is real close. Maybe not perfect, but close. Just like you told me about the air bleeds, that every .001" matters. It matters in your shim setup also. Maybe Jason has some thinner shims than what you have available. You are only off a small amount.
[image][/image]
[Re: Thumperdart]
#2011782
02/14/16 03:34 PM
02/14/16 03:34 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
Doc Diff/Cass will tell you to use 75/140.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
