Axle hole size for new studs question.
#2010933
02/13/16 02:55 AM
02/13/16 02:55 AM
Posts: 1,675 Mi.
G-Money1320
Mi.
I am installing new ARP 3" wheel studs in my axles. My question is what size smaller does the hole need to be safely for the knurl to properly be secured?? I have Moser axles and the tech said the holes are drilled at .656 for a .665 knurl and the new studs are .680. I can get a 43/64 drill bit that will open the hole to .671. Is that going to be tight enough or could I go a little tighter?? I will measure the studs and holes in the axles to get the exact measurements before any alterations, but would like any experience on the tightness if possible. Thanks!!
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
Re: Axle hole size for new studs question.
[Re: G-Money1320]
#2010957
02/13/16 05:29 AM
02/13/16 05:29 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
[Re: G-Money1320]
#2011298
02/13/16 08:13 PM
02/13/16 08:13 PM
Posts: 25,885 Rio Linda, CA
John_Kunkel
Rio Linda, CA
.005"-.007" undersize hole is all you need.
[Re: G-Money1320]
#2011303
02/13/16 08:19 PM
02/13/16 08:19 PM
Posts: 16,928 NC
440Jim
NC
I can get a 43/64 drill bit that will open the hole to .671 Remember, when you drill with a bit that is .671", the resulting hole will normally be slightly oversize, maybe +0.003 depending on machine and technique.
[Re: 440Jim]
#2011629
02/14/16 10:40 AM
02/14/16 10:40 AM
Posts: 19,485 north of coder
moparx
I can get a 43/64 drill bit that will open the hole to .671 Remember, when you drill with a bit that is .671", the resulting hole will normally be slightly oversize, maybe +0.003 depending on machine and technique. absolutely correct. possibly more depending on the runnout or play in the quill of your drill press. and if drilled by hand, any amount of problems can arise, from way oversize hole diameter,egg shaped holes, crooked holes, tapered holes, etc.
[Re: moparx]
#2012126
02/14/16 11:47 PM
02/14/16 11:47 PM
Posts: 1,675 Mi.
G-Money1320
Mi.
Thanks for the input, if it wasnt so cold here I could go out and knock one of the old studs out and get a measurement.Greg
[Re: G-Money1320]
#2012241
02/15/16 03:14 AM
02/15/16 03:14 AM
Posts: 20,188 Park Forest, IL
slantzilla
Park Forest, IL
Mr. Gasket makes a set with .665 knurls on them. I just went through this putting a set ij my stock Duster axles. .680's just would not go in.
