Re: Roller Pilot Brg Tips & Tricks?
[Re: 1E2C]
#2010047
02/11/16 07:49 PM
02/11/16 07:49 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
I tried tapping it in and currently have it wedged at an angle, can't get it to go any more so think I'm going to have to use real force to get it back out. I know I didn't have this big an issue last one I put in. Not sure if the crank is actually drilled for the original style bushing and didn't have one handy to measure against, have fought the bronze bushing battle with an undrilled crank so many times I wanted the easy way out - seems like I didn't find it this time. If it's wedged at an angle it's not going to go in no matter how hard you hit it, as you are finding out. Hit the side that is sticking out and that should help to square it up. You may have raised a burr on the inside of the crank register and that will stop it from going any further also .
[Re: 1E2C]
#2010090
02/11/16 08:38 PM
02/11/16 08:38 PM
Posts: 4,457 Washington
madscientist
Washington
The best option is to make a bushing that uses the torque converter register. If I could takes pics I woull post up how I do it.
I never use roller bearings on the input. I know it's all the rage, but then again, so is hip hop. I have repaired about 25-30 input shafts that got jacked up by roller pilot bearings. And in the end, I end up making my own bushings. So I just make a bushing that uses the TQ register, as I said above. Then you don't have to worry if the crank was finished drilled for the pilot bushing.
Any freshman level machinist can measure and make a bushing. I'd bet there are many ltttle "home shop" guys within a 15-20 drive of your house who can do it, let alone a regular machine shop.
[Re: 1E2C]
#2010121
02/11/16 09:21 PM
02/11/16 09:21 PM
RapidRobert
I did one way back on the 360 & I dont remember any (special) fitment issues and I did not freeze/heat anything
[Re: madscientist]
#2010392
02/12/16 11:17 AM
02/12/16 11:17 AM
JohnRR
Any freshman level machinist can measure and make a bushing. I'd bet there are many ltttle "home shop" guys within a 15-20 drive of your house who can do it, let alone a regular machine shop. Chrysler used to sell that newer style bushing with a bushing instead of a roller bearing so it looks like the only way to go that route is to make a bushing? If I was going to go to the trouble of making something I would just make the part that fits the convertor register and use the bushing that goes directly into the crank ???
[Re: 3csalvage]
#2010498
02/12/16 03:23 PM
02/12/16 03:23 PM
JohnRR
IIRC the 4 liter jeep engines use a pilot bearing that sets in the tc register on our older cranks! Dakotas and full size pickups also.
[Re: cudaman1969]
#2010553
02/12/16 05:02 PM
02/12/16 05:02 PM
madscientist
Washington
Imput shaft might be to soft for a roller bearing, more suitable to bronze This is 100% fact. I have repaired many of them. I have never tested for average hardness but some guys get away with the roller bearing. But it usually grooves the input. I have an old roller bearing on the shelf that I use for the dimensions.
[Re: madscientist]
#2010925
02/13/16 02:42 AM
02/13/16 02:42 AM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
I wish they still made the brass one but I haven't seen them available for years. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
