Roller Pilot Brg Tips & Tricks? #2009894
02/11/16 03:37 PM
02/11/16 03:37 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
How much force is required to install one of these? It feels like it's close to going, but after a night in the freezer and a second attempt it's still a no go. What am I missing? Oh yeah, 84 360 for what it's worth.
Re: Roller Pilot Brg Tips & Tricks? [Re: 1E2C] #2009905
02/11/16 04:00 PM
02/11/16 04:00 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
You should be able to knock it in without the freezer trip. I only saw one that was falling in too easy by hand, due to previous damage in crank recess. Went back to brass oem style for that one. Make sure you put it in with seal facing trans. IIRC, there's a taper on face showing crank side.
Re: Roller Pilot Brg Tips & Tricks? [Re: 1E2C] #2009907
02/11/16 04:04 PM
02/11/16 04:04 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I use the brass bearings. I've seen the rollers go bad and ruin the input shaft.
Re: Roller Pilot Brg Tips & Tricks? [Re: fastmark] #2009919
02/11/16 04:25 PM
02/11/16 04:25 PM
dogdays Offline
dogdays  Offline
It's a press fit, needs some coaxing with a hammer.
BUT!!!
Before you do, drill and tap two 1/4-20 holes across from each other so you can get it out easier. Takes about 10 minutes and is really worth it if you have to disassemble.
R.
Re: Roller Pilot Brg Tips & Tricks? [Re: 1E2C] #2009969
02/11/16 05:54 PM
02/11/16 05:54 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
I tried tapping it in and currently have it wedged at an angle, can't get it to go any more so think I'm going to have to use real force to get it back out. I know I didn't have this big an issue last one I put in. Not sure if the crank is actually drilled for the original style bushing and didn't have one handy to measure against, have fought the bronze bushing battle with an undrilled crank so many times I wanted the easy way out - seems like I didn't find it this time.
Re: Roller Pilot Brg Tips & Tricks? [Re: 1E2C] #2010024
02/11/16 07:18 PM
02/11/16 07:18 PM
Innisfil Ontario Canada
Mogre Offline
Mogre  Offline
Its been a few years, but from what I recall, heat expands and cold contracts metal. We used to put the bearing on a light bulb to heat it up and sometimes had to ice the shaft. Good luck.
Re: Roller Pilot Brg Tips & Tricks? [Re: 1E2C] #2010026
02/11/16 07:21 PM
02/11/16 07:21 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
I can't get it into the crank register, long ways yet to trying to stick the tranny input shaft in.
Re: Roller Pilot Brg Tips & Tricks? [Re: 1E2C] #2010047
02/11/16 07:49 PM
02/11/16 07:49 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If it's wedged at an angle it's not going to go in no matter how hard you hit it, as you are finding out.
Hit the side that is sticking out and that should help to square it up. You may have raised a burr on the inside of the crank register and that will stop it from going any further also .
Re: Roller Pilot Brg Tips & Tricks? [Re: 1E2C] #2010090
02/11/16 08:38 PM
02/11/16 08:38 PM
Washington
madscientist Offline
Washington
The best option is to make a bushing that uses the torque converter register. If I could takes pics I woull post up how I do it.
I never use roller bearings on the input. I know it's all the rage, but then again, so is hip hop. I have repaired about 25-30 input shafts that got jacked up by roller pilot bearings. And in the end, I end up making my own bushings. So I just make a bushing that uses the TQ register, as I said above. Then you don't have to worry if the crank was finished drilled for the pilot bushing.
Any freshman level machinist can measure and make a bushing. I'd bet there are many ltttle "home shop" guys within a 15-20 drive of your house who can do it, let alone a regular machine shop.
Re: Roller Pilot Brg Tips & Tricks? [Re: 1E2C] #2010121
02/11/16 09:21 PM
02/11/16 09:21 PM
I did one way back on the 360 & I dont remember any (special) fitment issues and I did not freeze/heat anything
Re: Roller Pilot Brg Tips & Tricks? [Re: madscientist] #2010392
02/12/16 11:17 AM
02/12/16 11:17 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Chrysler used to sell that newer style bushing with a bushing instead of a roller bearing so it looks like the only way to go that route is to make a bushing?
If I was going to go to the trouble of making something I would just make the part that fits the convertor register and use the bushing that goes directly into the crank ???
Re: Roller Pilot Brg Tips & Tricks? [Re: 1E2C] #2010434
02/12/16 01:14 PM
02/12/16 01:14 PM
wooster ohio
3
3csalvage Offline
3csalvage  Offline
wooster ohio
IIRC the 4 liter jeep engines use a pilot bearing that sets in the tc register on our older cranks!
Re: Roller Pilot Brg Tips & Tricks? [Re: 3csalvage] #2010498
02/12/16 03:23 PM
02/12/16 03:23 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Dakotas and full size pickups also.
Re: Roller Pilot Brg Tips & Tricks? [Re: 1E2C] #2010503
02/12/16 03:48 PM
02/12/16 03:48 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Imput shaft might be to soft for a roller bearing, more suitable to bronze
Re: Roller Pilot Brg Tips & Tricks? [Re: cudaman1969] #2010553
02/12/16 05:02 PM
02/12/16 05:02 PM
Washington
Washington
This is 100% fact. I have repaired many of them. I have never tested for average hardness but some guys get away with the roller bearing. But it usually grooves the input.
I have an old roller bearing on the shelf that I use for the dimensions.
Re: Roller Pilot Brg Tips & Tricks? [Re: madscientist] #2010925
02/13/16 02:42 AM
02/13/16 02:42 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I wish they still made the brass one but I haven't seen them available for years.
Gus beer
64 Plymouth Savoy
Dana 60
