Chris Alston Chassisworks #2009953
02/11/16 05:13 PM
02/11/16 05:13 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I contacted Chris Alston Chassisworks about possibly making some better quality strut rods for Mopars. You would have thought I was asking to make space shuttle products...but if others are interested, maybe we can interest them.
Carl K Ogren - gStreet Specialist
Sales – Tech – Social Media
Chris Alston's Chassisworks
(916) 388-0288 Ext 247
cogren@cachassisworks.com
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Chris Alston Chassisworks [Re: astjp2] #2010251
02/12/16 12:36 AM
02/12/16 12:36 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: Chris Alston Chassisworks [Re: astjp2] #2010364
02/12/16 07:04 AM
02/12/16 07:04 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I looked at those, they are way different in manufacturing and engineering. Those would be similar to just using heim joints, I was looking for something more robust and on par with a ball joint where its sealed and greaseable. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Chris Alston Chassisworks [Re: astjp2] #2010419
02/12/16 12:30 PM
02/12/16 12:30 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Making your own is not that big of a stretch. Weld a ball joint receiver to the K frame. You can now thread an upper ball joint into it. Cut off the tapered end of a stock strut to seat into the control arm, weld it into a tube threaded to ball joint, viola' adjustable strut.
Don't want to weld, use a bolt in chevy ball joint and short section of swedged tube, thread the stock strut to mate to the tube.
Re: Chris Alston Chassisworks [Re: astjp2] #2010440
02/12/16 01:32 PM
02/12/16 01:32 PM
Mountain View, CA
68rrunner Offline
68rrunner  Offline
Mountain View, CA
I can see these on a drag car, but can those bearings hold the fore aft loading of a street car? I'd hate to pay $200 bucks for something that has a 1k mile service life....
Re: Chris Alston Chassisworks [Re: astjp2] #2010508
02/12/16 03:53 PM
02/12/16 03:53 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
They would have to thoroughly testing. Uniball and heims are designed for radial load, not axial. Since these need the K member opened up, might as well do the ball joint deal. Get 2 of these:
http://www.speedwaymotors.com/HOWE-K772-BALL-JOINT-KIT,213056.html
Then weld 2 of these into K member:
http://www.speedwaymotors.com/Steel-Upper-Ball-Joint-Sleeve-K772-Style,2126.html
Mopar to the bone!!!
Re: Chris Alston Chassisworks [Re: astjp2] #2010745
02/12/16 09:31 PM
02/12/16 09:31 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
'better quality strut rod'...
What is exactly the issue that needs to be improved?
Are stock strut rods failing that often?
If you just want adjustability I would probably look at adding simple HD tierod-sleeves into them.
Cut the strut in half, cut threads, install sleeve, re-install and adjust.
Another $200 saved.
Re: Chris Alston Chassisworks [Re: astjp2] #2010914
02/13/16 02:12 AM
02/13/16 02:12 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Well the mustang ones are $510 before I need modify them to fit a Mopar, but if you want to play, you have to pay....getting a lot of articulation is not cheap...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Chris Alston Chassisworks [Re: astjp2] #2011116
02/13/16 03:21 PM
02/13/16 03:21 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Biggest problem with stock strut rods is the bushings. Stock rubber is too soft, poly has poor articulation as mentioned.
Aftermarket heim setups are so poorly designed that whomever did that needs nutkicked.
For example
http://www.qa1.net/suspension/street-per...amic-strut-bars
Think about the new location of the strut rod's pivot point and how the LCA will act as it goes up and down.
Re: Chris Alston Chassisworks [Re: astjp2] #2011164
02/13/16 04:37 PM
02/13/16 04:37 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
With my torsion bars, my suspension never sees enough droop to know the difference. My torsion bars are out of load WAY before the suspension is. If a guy had .810 bars then yeah, he may see some fore and aft difference during cycles.
Re: Chris Alston Chassisworks [Re: Supercuda] #2011205
02/13/16 05:40 PM
02/13/16 05:40 PM
Central IL
Trojmn Offline
Trojmn  Offline
Central IL
For example
right, there's room for days on the front of the K to make the struts longer rather than shorter.
Re: Chris Alston Chassisworks [Re: astjp2] #2011276
02/13/16 07:26 PM
02/13/16 07:26 PM
The Netherlands
The Netherlands
I don't think it would be too hard to grind a polybushing into a nice ball shape and along with some properly cupped washers and grease it will turn into a bearing.
Re: Chris Alston Chassisworks [Re: astjp2] #2011278
02/13/16 07:31 PM
02/13/16 07:31 PM
The Netherlands
The Netherlands
Well whaddayaknow, this is pretty much what I envisioned.
Looks promising, although I don't quite see $200 worth of parts yet;
http://opentrackerracing.com/product/calvert-racing-strut-rod-bushing-set-1965-1966-mustang/
EDIT:
You can also just get the bushings alone for $100;
http://opentrackerracing.com/product/calvert-racing-strut-rod-bushing-set-1967-1973-mustang/
Maybe this will fit Mopars just fine with just a few minor mods.
Re: Chris Alston Chassisworks [Re: BigBlockMopar] #2011623
02/14/16 10:21 AM
02/14/16 10:21 AM
moparx Online content
moparx  Online Content
wouldn't those bushings need to be turned backward to work as we intend ? this would mean a ball shaped surface on the strut rod mounting area,correct ? or am i not seeing the intent correctly ? my eyes are old too, along with my brain's comprehension...........
beer
Re: Chris Alston Chassisworks [Re: astjp2] #2011663
02/14/16 12:20 PM
02/14/16 12:20 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Yes
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Chris Alston Chassisworks [Re: astjp2] #2011771
02/14/16 03:16 PM
02/14/16 03:16 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Okay, you pick up two of these for $25 each;
http://www.speedwaymotors.com/AFCO-20032-K5208-Standard-GM-Upper-Ball-Joint,38033.html
Add two of these for $10 each:
http://www.speedwaymotors.com/Swedged-Steel-Tube-3-4-Inch-Thread,2091.html
Cut off, thread, and use the tapered end from your stock strut.
Total cost, $70 plus shipping and labor to cut,thread, and drill.
Or you can petition Alston to make up a single run set of their design for $1000. Maybe convince them there is a market for them at $500 for a run of 100 sets.
Re: Chris Alston Chassisworks [Re: astjp2] #2011895
02/14/16 06:41 PM
02/14/16 06:41 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
And gain ZILCH.
Re: Chris Alston Chassisworks [Re: astjp2] #2012369
02/15/16 01:04 PM
02/15/16 01:04 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Ahh, c'mon. Its not a total zero gain. It would certainly minimize toe change under heavy braking.
Re: Chris Alston Chassisworks [Re: astjp2] #2012641
02/15/16 07:21 PM
02/15/16 07:21 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Sure, but you get that by losing the bushing with a heim already. I could see the longer lever arm argument having some cred if our cars were cycling through ALL of there travel, but I know in my cars case it does not ever drop the front more than MAYBE 1.5" below ride height.
Re: Chris Alston Chassisworks [Re: astjp2] #2012741
02/15/16 10:18 PM
02/15/16 10:18 PM
Ohio
lockjaw-express Offline
Ohio
I have been watching this tread because I have a strut rod that is bent near the end, and I was looking at buying HD stock style with new rubber bushings, or the Hotchkis units with the helm joints...
My car is more of a street strip GTX, so I do see a lot of lift and drop off of the line...in my case what would your advice be on my issue above?
Thanks, Mark
