Lead vs Bondo #2009507
02/10/16 09:30 PM
02/10/16 09:30 PM
Tucson AZ,
MadMopars Offline OP
Tucson AZ,
I did some lead work on some pitted metal today and was pretty impressed with the result. I know it's a dying art but was interested in hearing others opinion's on the use of it. Which method do you prefer, Lead or Bondo and why? I'm interested in hearing the pros and cons of each as well as the best application to use them in. Thoughts? work
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Lead vs Bondo [Re: MadMopars] #2009526
02/10/16 09:51 PM
02/10/16 09:51 PM
USA
Hooligan Offline
Hooligan  Offline
USA
I know didley squat on the matter, but I have heard that contaminants come out of the lead, which have to be thoroughly cleaned away to prevent paint issues later. Hopefully an expert can elaborate on it.
Re: Lead vs Bondo [Re: Hooligan] #2009592
02/11/16 12:11 AM
02/11/16 12:11 AM
IN
ahy Offline
ahy  Offline
IN
You are good... it is not easy to get lead to stick to steel and be somewhat level.
My choice on beat up metal or welds is neither. I use a first fill of epoxy. JB weld or PC7. It sticks very well to steel... much better than bondo and is waterproof. I use bondo for final smoothing.
Re: Lead vs Bondo [Re: MadMopars] #2009605
02/11/16 12:38 AM
02/11/16 12:38 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Here's some discussion I found on the WWW. BTW, it's called lead, but it's actually solder.
Question
Would you elaborate about preparation regarding lead body repairs?
Any good books on the subject that you would recommend?
Answer
Preparation is pretty straight forward. All galvanized coatings must be completely ground off, all paint must be removed, all rust completely sand blasted out. Lead actually likes sand blasted steel. I highly suggest having some heat sinking putty around the spot. Play-Doh will work, but dries out quickly.
First, you need to tin the area with acid core solder. Go beyond the area you intend to lead. Then, you apply lead. You work and smooth lead with heat and wooden lead paddles. The paddles are occasionally dipped in beeswax to keep lead from sticking, and to cool the paddles. The wax comes in a little tub, it's hard like a candle. It must be melted with the torch, but just enough to sorta dip the paddle in.
Lead is a joy to work with. Unlike Bondo, it can be reworked once it's hard. Just heat it up and paddle it out. I like to work it with a body file, it cuts fast, and body files were made for working lead. You can also sand it conventionally with sandpaper, and should final sand with some 180 on a DA if you do all the work with a metal file.
Once you are done, the area must be wet sanded with 320 wet or dry paper to remove any acid from the tinning process. Hope this makes things a little clearer for you. I don't know of any good books on the subject, sorry. I was taught by an old pro, and he was taught by his uncles.
Re: Lead vs Bondo [Re: MadMopars] #2009675
02/11/16 02:15 AM
02/11/16 02:15 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Lead work is an art I learned when working on expensive imports in the 60s but Bondo is easier and cheaper. Now days the metal is thinner and lead doesn't work to well. The heat necessary to lead is too much for the thin metal and makes it warp.
Re: Lead vs Bondo [Re: stumpy] #2009697
02/11/16 03:12 AM
02/11/16 03:12 AM
Tucson AZ,
Tucson AZ,
Today was actually the first day I used it. A guy I work with use to own a restoration shop many years ago and was kind enough to teach me how to do it. It was basically the same method as posted above.
To work it so quickly is pretty convenient as is the ability to reshape it, be it to move it around or to even hammer and dolly it after application.
When done well it's almost a shame to cover it up since clean metal work is so rare anymore. I guess that's the difference between running a business and doing it as a hobby though.
Re: Lead vs Bondo [Re: stumpy] #2009710
02/11/16 04:12 AM
02/11/16 04:12 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
I'll challenge that. Car bodies from the muscle car era until the present day are made of 0.032" steel. I guess pre-war cars were a little thicker. I do believe some body parts of older Japanese cars may have been a little thinner.
I was a mill sales rep for cold rolled steel sheet in coil. "Automotive gauge" steel is 0.032" thick, and the auto industry is the 800-pound gorilla in the cold rolled market. For this reason just about every cold rolled mill in the world is optimized to roll "oh thirty two". .032 is "base price" or the cheapest thickness to produce. That's why clothes washers, water heaters, refrigerators, filing cabinets, etc. are mostly .032.
My '69 Barracuda is .032 in the fenders, doors, wheel tubs, floor pan, and all the rest of the body panels. So is my '05 GTO from Australia. If I buy a new Challenger it will be .032 too.
Whenever I have 'miked' steel on my cars, it usually was about .035 or so due to paint. Take off the paint, and it's .032.
I cringe when people want to talk about gauge numbers for steel thicknesses. Gauge numbers were abandoned by mills and customers early in the industrial revolution. Every steel mill in the world rolls to decimal inches or millimeters, not to any gauge number. And steel mill customers order and buy in decimal inches or millimeters, not in any gauge number.
Re: Lead vs Bondo [Re: kentj340] #2009733
02/11/16 08:54 AM
02/11/16 08:54 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I have dealt with some 90's Japanese cars and can confirm that at least as far as Mitsubishi goes some of the sheet metal is thinner. The stuff I was in contact with in the shop was like tinfoil.
There is a rotted '88 Shelby Daytona sitting in the yard, I'll have to take a mic to it in a few spots and check. I'm of the opinion too that at least since the 80's the sheet metal on cars is thinner.
When the windshield company put new glass in my '87 CSX he dented the roof with his elbow! Had to get the dent wizard out to fix it. I have never seen a "classic" mopar dent that easy.
BTW- I have done some lead work too filling pin holes that were in the donor tunnel ram hood for my GTX. It came out real nice and would use this method again.
"I think its got a hemi"
Re: Lead vs Bondo [Re: MadMopars] #2009881
02/11/16 03:14 PM
02/11/16 03:14 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Any truth to the rumor that using lead will give off fumes that can be harmful to your health and that protection is advised?
Re: Lead vs Bondo [Re: Sxrxrnr] #2009895
02/11/16 03:40 PM
02/11/16 03:40 PM
dogdays Offline
dogdays  Offline
Fumes, dust that can be ingested through lungs or eating a sandwich, it's all true. Lead isn't good for you.
Lead is especially harmful to children, born and unborn. It is carried in from your garage in a number of ways. So if you value your children or grandchildren.....................
How much lead will actually harm an adult is another question. We'll have to get an industrial hygienist's opinion on that.
R.
Re: Lead vs Bondo [Re: kentj340] #2010081
02/11/16 08:34 PM
02/11/16 08:34 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
FYI this is correct, as far as an 87 GLHS goes. I'll check a 75 Dart tomorrow.
Re: Lead vs Bondo [Re: MadMopars] #2010622
02/12/16 06:37 PM
02/12/16 06:37 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Lead is readily absorbed through the skin as well so gloves are a must. If you're going to sand it (and you will) a good respirator is also a must. As dogdays so noted, lead dust can and will saturate your clothes so be mindful of what you drag into the house with you. Take precautions and enjoy the spectacle of Pb.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: Lead vs Bondo [Re: ahy] #2010634
02/12/16 07:01 PM
02/12/16 07:01 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i never would have thought of that! thumbs
Re: Lead vs Bondo [Re: mikemee1331] #2010752
02/12/16 09:39 PM
02/12/16 09:39 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
I don't think it would stay flexable enough.
Re: Lead vs Bondo [Re: MadMopars] #2011026
02/13/16 12:17 PM
02/13/16 12:17 PM
Spanaway, Washington State
P
patosmith Offline
patosmith  Offline
P
You can get materials from Eastwood that are "lead free".
I had to lead the seams where the roof meets the quarter panel. I didn't how well the lead free stuff worked so I opted for the "lead" and made sure I had plenty of ventilation.
You don't want to go thick with bondo.
Re: Lead vs Bondo [Re: Sxrxrnr] #2011039
02/13/16 12:52 PM
02/13/16 12:52 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Any substance can cause issues with health, temporarily, or permanently, so use commonsense, as to some of the worrywarts comments posted here on lead, unless your going to be opening up a lead smelting shop, I wouldn't be concerned over the SHORT term usage you may intend
Then again you are in California, so EVERYTHING has a health warning label on it
Re: Lead vs Bondo [Re: DAYCLONA] #2011078
02/13/16 02:25 PM
02/13/16 02:25 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Correct assessment. Only place such a label is missing is where it is most needed.
Stamped on the foreheads of our Governor and other such assorted nutsos of our purported illustrious Governmental 'Officials'.
Re: Lead vs Bondo [Re: Sxrxrnr] #2011273
02/13/16 07:18 PM
02/13/16 07:18 PM
dogdays Offline
dogdays  Offline
This unthinking, aggressively ignorant attitude is what turns many off to the car culture.
There are many things that are "harmful" that I don't worry about. But lead is on the list of things I worry about.
AS I SAID, I don't know the level at which it poses a health risk to adults. But I do know that lead is transported when Dad walks in the door from the garage, probably airborne lead as well.
It is a fact that lead is harmful to children. Their brains are still developing. It doesn't take industrial amounts of lead for that to happen. So stop speaking from ignorance.
R.
Re: Lead vs Bondo [Re: MadMopars] #2011316
02/13/16 08:37 PM
02/13/16 08:37 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It takes a lot more than you would bring in on your shoes from a simple lead repair. You really need to take your own advise and stop speaking from ignorance and fear mongering.
Re: Lead vs Bondo [Re: dogdays] #2011433
02/13/16 11:28 PM
02/13/16 11:28 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
If you had bothered to read or perhaps you have already forgotten, it was I that first suggested possible dangers from lead in this thread.
Your extremist attitude is exactly what both Dayclona and I were suggesting is the state of mind in the state of Calyforunua enabled on by voters who for the most part don't have the scientific wit to understand what is the phenomenon that causes the 24 hour cycle of night and day.
Yet they and those for whom they vote for are for banning plastic bags, nuclear power, dams and all fossil fuels. No matter the costs, because as Bernie suggests, someone else will pay for it. You must live here to understand.
I suggest you lighten up and attempt to bring a little humor into your life. Just as Dayclona was attempting with his posting. Apparently he struck a nerve instead.
