Push button removal #2009455
02/10/16 08:10 PM
02/10/16 08:10 PM
Ontario Canada
70barracuda Offline OP
Ontario Canada
Hello, Got a 64 Fury push button car, Can you take the 2- cables off under the dash, I want to remove dash. I see one has a clip, the other does not, can it be done this way or do they have to come out of trans. Thank You
Re: Push button removal [Re: 70barracuda] #2009485
02/10/16 08:58 PM
02/10/16 08:58 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i think there are 2 3/8 nuts holding it in place--they are way inside the housing--take it loose--let it hang--remove the dash---my guess is your arent getting rid of them.....
Re: Push button removal [Re: 70barracuda] #2009511
02/10/16 09:33 PM
02/10/16 09:33 PM
Ontario Canada
Ontario Canada
The 2- nuts hold the bracket but the cable itself is snapped onto a pin/ rod. No pin and washer like the other side ? Mmm
Re: Push button removal [Re: 70barracuda] #2009677
02/11/16 02:19 AM
02/11/16 02:19 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Been a lot of years for me but I do know they can be disconnected at the dash end. Not easy as I recall but it may depend on your level of dash disassembly. I do seem to vaguely remember if the instrument cluster is removed it becomes a simple task shruggy
Maybe someone with a "better" memory will chime in beer
Re: Push button removal [Re: 70barracuda] #2009920
02/11/16 04:26 PM
02/11/16 04:26 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
as I remember like my 62 dart there is 2 small nuts that attach it to the dash and then you can take out the dash I don recommend taking the cables off the shifter mech as it is a pain to reconecr
Re: Push button removal [Re: 70barracuda] #2010038
02/11/16 07:35 PM
02/11/16 07:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Many dashes can be removed without disturbing the PB mechanism. Just back off the small set screw in the Park lever knob, remove the knob and the buttons remain in the mechanism when the dash is removed.
Sometimes there is a separate trim plate that has to come off before the dash.
