I'm in the process of installing a set of QA1 tubular lower control arms on my 70 Cuda and I would like to check in here if anyone here has any experience with these control arms? I have a new set of Firm Feel greaseable pivot shafts with a nylon bushing, is there an advantage of using them over the OEM style pivot shafts that the QA1 lower control arms are delivered with? Any thoughts are welcome
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600) 1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600) 1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
