Page 2 of 3 1 2 3
Re: Just curious, are wedge blocks being cast anytime soon? [Re: polyspheric] #2008669
02/09/16 05:17 PM
02/09/16 05:17 PM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
Originally Posted By polyspheric
I can build an entire 500 hp LS motor for what a bare block costs.
...and I could eat hot dogs for a week for the cost of a good steak. Why would anyone buy a steak if hot dogs are just as filling? Hot dogs must be better than steaks, and ls motors must be better than mopars. Although, it must get old seeing the same thing whenever someone opens the fridge/hood.
Re: Just curious, are wedge blocks being cast anytime soon? [Re: 73DAD] #2008679
02/09/16 05:56 PM
02/09/16 05:56 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Some of the Mopar guys would rather whine than spend their money to buy parts. A good Friend of mine had both a 4.500 World block and a .030 over Mega block listed on Moparts for months before he could finally sell them. I ended up buying the mega block and it was cheaper than a band-aided stock block. I've had my fingers in 4 LS chevie bocks and everyone of them had the cam bearing ATE out of them. I've seen and heard of lots of Dart block (chevy guys again) issues too. Cry me a river guys. Some of you guys enjoy whining more than you do racing.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Just curious, are wedge blocks being cast anytime soon? [Re: camastomcat] #2008696
02/09/16 06:26 PM
02/09/16 06:26 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
is 500hp the new limit of stock blocks? I personally would just use a stock one vs an LS for 500hp. Pretty soon the RB won't be able to handle a stock rebuild.
I have been phoning the dealership once a month seeing if they are available. Hopefully it's soon! I would assume they are filling up the Hemi orders before they even consider it. I also follow Koleno's facebook and it seems they aren't any closer to casting blocks again.
Re: Just curious, are wedge blocks being cast anytime soon? [Re: CTD5.9] #2008713
02/09/16 06:46 PM
02/09/16 06:46 PM
PA.
"Little"John
"Little"John
PA.
If I raced 3-5 times a year or drove it on the street I wouldn't think twice about building a low 9 second stock block engine. My last stock block engine made 275 passes (8.60's@2500 pounds) before I found a crack when I took it apart a few Winters ago. Some guys want to wind the piss out of them, crank up the compression, push the timing, and CHEAP-OUT on fuel.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Just curious, are wedge blocks being cast anytime soon? [Re: camastomcat] #2008715
02/09/16 06:47 PM
02/09/16 06:47 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Remember this is a Mopar site, so whining about how expensive race parts are is a given. If more people would open their pocket book and buy this stuff they probably would not go out of production in the first place.
Personally I was hoping it would be longer since I have a pair of megablocks at home. Figured it would be a good start on a great vacation smile Guess I will just use them now.
Re: Just curious, are wedge blocks being cast anytime soon? [Re: camastomcat] #2008743
02/09/16 07:40 PM
02/09/16 07:40 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
And people wonder why I am gun shy and replacing my 300 run aluminum rods in my pristine Mega-block.
Doug
Re: Just curious, are wedge blocks being cast anytime soon? [Re: dvw] #2008764
02/09/16 08:10 PM
02/09/16 08:10 PM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
Doug
Go all the way in and buy an aluminum block to match those rods!
I don't blame you in the least - peace of mind is worth the cost of a set a rods any day!
Re: Just curious, are wedge blocks being cast anytime soon? [Re: camastomcat] #2008833
02/09/16 10:01 PM
02/09/16 10:01 PM
New York
polyspheric Offline
polyspheric  Offline
New York
You mean, like everyone's goal: a Gen-II hemi? You know, "for the wow factor"?
Strangely, this same argument was current when people started replacing their 150 hp (3/4 race) Ford flatheads with 200 hp (stock) 1949 Olds, 1949 Cadillac and 1951 Chrysler junkyard engines.
Sorry, the combination of easy availability, low costs, and super power is very compelling.
For those not familiar, the LS series features:
1. Aluminum heads (yes, every single one). Despite the comments that appeared here in the Trick Flow post, multi-angle valves (BBC, Boss, 385) are not needed for excellent ports. All LS heads are wedge with parallel valves. 2007-* 6.0 & 6.2 square intake ports (including trucks) flow over 300 cfm as-cast, as-installed.
2. Aluminum blocks in all cars and many trucks. New factory replacement aluminum block: $1,200.
3. 6 bolt cross-bolted main bearings caps (yes, every single one).
4. Factory cast crankshaft safe to over 1,000 hp on boost (less N/A or nitrous).
5. Factory 1.7 rockers are safe above 6,500 RPM.
6. Stock pushrods are only 7.4" long.
LS engines are almost 20 years old, get used to it.
Boffin Emeritus
Re: Just curious, are wedge blocks being cast anytime soon? [Re: camastomcat] #2009184
02/10/16 01:13 PM
02/10/16 01:13 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Killed a couple of them one a Hemi and one Wedge both were steel rod motors FWIW. Also both were engines I bought not built. Word to the wise if you buy a racecar or engine from someone might be best to just freshen it and replace some stuff smile leaned my lesson unfortunately. One reason I am not a huge has of a steel rod they tend to destroy stuff.
Re: Just curious, are wedge blocks being cast anytime soon? [Re: camastomcat] #2009224
02/10/16 02:27 PM
02/10/16 02:27 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Al, did you repair those blocks?
Doug
Re: Just curious, are wedge blocks being cast anytime soon? [Re: camastomcat] #2009235
02/10/16 02:40 PM
02/10/16 02:40 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The Hemi was repairable, small hole and pan rail was all. The Wedge block was a total disaster. It is sitting on the side of the house. It is missing a 1 foot section on one side and about 10" on the other. Got the bottom of the bores on 5 holes and destroyed the cam tunnel. I actually gave away the Hemi block to a buddy and bought a new one.
This is the other side..It was WAY worse than it looks here. It was broken for about a foot down the rail. Only the pan was holding it together. Sad part is we only had 11 passes on it since acquiring it and it was a nice pre world block that had bushed lifter bores too..Oh well live and learn
Re: Just curious, are wedge blocks being cast anytime soon? [Re: Al_Alguire] #2009259
02/10/16 03:03 PM
02/10/16 03:03 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
Whining is the Ford 9 inch cowl hood nothe a mopar stuff...no blocks to build is a fact..my builder doesn't want a aluminum block I did but he knows more then me or I wouldn't need him..some of you guys was born with a mopar in your mouth not me I've been had mopar so since I was in my early 20s 44 now..I don't collect and hold parts for future use..I own a small business that I collect parts for ..I tried bill Mitchell about blocks waiting to hear how they come out..as far as kb I just can't see sending 3000 and waiting till they ready to do something. .again small business owner ..so I'm not whining I'm stating fact. .like I said whining is telling people your no mopar cause you got a 9inch cowl hood or cause the valve is Chevy angle predator head lol that's whining. .
Re: Just curious, are wedge blocks being cast anytime soon? [Re: camastomcat] #2009264
02/10/16 03:12 PM
02/10/16 03:12 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Why would he object to an aluminum block, let me guess holing on to some out dated thinking that you will give up HP because of the aluminum block? Just curious. Letting a lack or iron blocks stop you from building an engine is outdated thinking. If it is a cost thing I can understand that, but frankly if you want to build a Mopar engine it is the only opting right now. So I fail to see the issue...
You can call Indy(preferably a dealer)and have an aluminum block at your door next week.
Re: Just curious, are wedge blocks being cast anytime soon? [Re: Al_Alguire] #2009271
02/10/16 03:21 PM
02/10/16 03:21 PM
an8sec70cuda Offline
iagree
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Just curious, are wedge blocks being cast anytime soon? [Re: camastomcat] #2009277
02/10/16 03:29 PM
02/10/16 03:29 PM
Orange County, Ca.
B1CUDA Offline
B1CUDA  Offline
Orange County, Ca.
It is mind boggling to me that Mopar has their heads so buried in the sand? At the end of the day, it comes down to supply and demand, and they obviously don't see it, as a money making venture. I have had every type of Mopar block, from iron to aluminum, and it is incredible to me that, as of today, Mopar makes ZERO blocks, both big and small blocks, all (or most) of the vendors are hard to get stuff from, including World, KB, and last but not least, the holier than thou geniuses at Indy, who think they have a clue, when they are some of the biggest horse's a$$es on the planet. Oh, forgot the nightmare that is the Ritter block. So glad that my stuff is gone, and, due to the block and 20+ year old cylinder head technology, except for the Gen 3 Hemi and Predator stuff, I will probably never do another Mopar, if things stay the same.
Re: Just curious, are wedge blocks being cast anytime soon? [Re: B1CUDA] #2009298
02/10/16 04:02 PM
02/10/16 04:02 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
Thank you..coming from someone who has been there done that. ..
Re: Just curious, are wedge blocks being cast anytime soon? [Re: camastomcat] #2009494
02/10/16 09:05 PM
02/10/16 09:05 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I'd take a nice aluminum block in trade for my Mega block.
Doug
Re: Just curious, are wedge blocks being cast anytime soon? [Re: dvw] #2009547
02/10/16 10:57 PM
02/10/16 10:57 PM
NY
X
XXHEMI Offline
XXHEMI  Offline
X
NY
In my case I run my car in F.A.S.T so aluminium would not fly.
Re: Just curious, are wedge blocks being cast anytime soon? [Re: camastomcat] #2009560
02/10/16 11:16 PM
02/10/16 11:16 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Paint it orange smile
Re: Just curious, are wedge blocks being cast anytime soon? [Re: XXHEMI] #2009571
02/10/16 11:30 PM
02/10/16 11:30 PM
fullmetaljacket Offline
Paint orange with magnetic paint. that way when they break out the magnets, you won't be caught out in the field. LOL.
Page 2 of 3 1 2 3
