200R4 - 360 LA Adapter Info
#2008423
02/09/16 07:09 AM
02/09/16 07:09 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Customer is considering having an automatic overdrive trans installed behind a stock Mag 360 EFI motor in a daily driver style 65 Dart. At this point we are considering the options - trying to avoid the tunnel/crossmember reconstruction that using an A500/RH42 style trans involves. So the question is - what is the most efficient and compact way to adapt a 200R4 up to an LA engine? I see there are front pump adapters to convert to a Reid bell, which is about $650 for the adapter and bell. At that point, anybody know what else is necessary, as far as flexplate, converter, crank adapter, etc? Or is there a better way, such as an engine/trans adapter plate? Or maybe an AOD conversion? Just trying to do some homework to give the customer some options. Thanks.
Free advice and worth every penny... Factory trained Slinky rewinder.........
Re: 200R4 - 360 LA Adapter Info
[Re: Evil Spirit]
#2008488
02/09/16 12:40 PM
02/09/16 12:40 PM
Posts: 4,405 Michigan
MarkZ
Worthy
Worthy
From the sounds of it this guy needs everything. If he already has a working transmission with a converter he is happy with then look at a Gear Vendors. The costs are probably comparable.
[Re: L4staero]
#2008865
02/09/16 10:39 PM
02/09/16 10:39 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Quicktime make a good one i believe NO
[Re: Evil Spirit]
#2008925
02/09/16 11:47 PM
02/09/16 11:47 PM
Evil Spirit
Newport, Mi
I didn't see an LA - 200R4 adapter in any of Quicktimes vendors ads. As to the Gear Vendors - not even considered an option - it would take more cutting and fabrication to the floor to install one than it would the A500. I wouldn't mind cutting the floors out of a rusty car that needed pans anyways, but this was a SoCal car and the pans and trans crossmember is spotless. At this point it's build an A500 and mod the floor/crossmember in house, or spend $3K+ on a trans, parts, etc. to convert to a 200R4. So at this point I'm just looking for possible options to make the 200R4 install a little more wallet friendly before I make the decision to carve up the floors.
[Re: j.mcconnell]
#2009220
02/10/16 02:15 PM
02/10/16 02:15 PM
Evil Spirit
Newport, Mi
Well, any decent 200R4 I'e been able to find with the better drum and stator support has been $1800-2000. Add in $600 for the adapter, $400-500 for a converter - hows my math now? And I still haven't mentioned kickdown linkage/cables, fluid, or a cooler/lines, but I would need that stuff for either trans.
And as I said in my first post a "Mag 360 EFI motor" I would need a way to send the ECM a crank trigger pulse.
[Re: Evil Spirit]
#2009644
02/11/16 01:31 AM
02/11/16 01:31 AM
RapidRobert
I have a jw ultrabell adapter (big block to 904). You might see what they have to offer
[Re: RapidRobert]
#2010491
02/12/16 03:06 PM
02/12/16 03:06 PM
Evil Spirit
Newport, Mi
I have a jw ultrabell adapter (big block to 904). You might see what they have to offer Off their website - nothing to adapt a 200R4 :-(
