Re: Mix metallic paint code in single stage without metallic?
[Re: DaytonaTurbo]
#2005122
02/03/16 10:54 PM
02/03/16 10:54 PM
Posts: 4,923 new berlin wisconsin
Mr T2U
look at some paint chips to find a color you like.
with some metallic paints, sometimes almost all of the tints are metallic. if you leave the metallic out the color might not be remotely close to the color you want. sometimes it's the other way. 90% of the tints are black or dark brown with a little yellow, white mixed in and 10% metallic a lot of the time the metallic lightens up the color and makes it what it is. if you leave out the metallic the color might be close to black or something muddy like dark brown.
I just painted a light charcoal gray metallic paint on a car today. 70% of the color was black tint with a little yellow and white, then 30% of it was metallic. if I left out the metallic I would have painted a black shaded mud paint. the metallic tint made it a light charcoal paint.
for the record I have been mixing and painting PPG water based basecoat for the last 3 months.
perception is 90% of reality
[Re: DaytonaTurbo]
#2005247
02/04/16 01:15 AM
02/04/16 01:15 AM
DaytonaTurbo
Manitoba, Canada
Edit: After doing some more searching, I was actually able to find pics of someone who had this exact color code mixed up without the metallic. Looks about like I expected, the same color but without the pop of the metallic flakes. For this project, it'll do.
[Re: screamindriver]
#2005396
02/04/16 12:44 PM
02/04/16 12:44 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Additional info : Just about any color can be turned into a matte finish by the supplier adding a "flattening agent" to the mix..A good mixer will know how much to add.. A "so-so" mixer will posibly give you some in another container to add if your test spray does'nt suit you.. Agreed, if the OP wants to eliminate the metallic and have a flat/matte finish as well with a single stage, a flattening agent can be added at the time of a spray out, usually you don't exceed no more than 30% flattening agent to the base
[Re: DaytonaTurbo]
#2007201
02/07/16 03:13 AM
02/07/16 03:13 AM
Posts: 377 Riverside, California
ghostrider
The problem with whole car single stage metallic paint is when you try to buff it out and go through a layer in places, making a mismatched color area, or you spray it on wrong and get tiger stripes. The factory didn't buff most metallics so the issues weren't there.
Must remember... my humor doesn't work on forums.....my humor doesn't work on forums.
Former Mopars include
69 Super Bee, 71 Sebring, 68 Charger, 69 Charger, 78 D150, 67 300, 71 Road Runner clone, 79 T-top Doba, 67 Barracuda, 91 TC by Maserati, 68 Town & Country
