Re: Sleeved cylinder burning oil, rest are perfect, why?
[Re: Seank]
#200679
01/22/09 02:05 AM
01/22/09 02:05 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
hmmm...interesting. I might have the same problem, but my stroked 383 is still making enough power to bring smiles to my face, everything sounds normal, I have good oil pressure, etc. So, I realy don't want to go looking for problems at this point. only problem is that I MIGHT have a slight blow-by issue on one cylinder that does have a sleeve in it.
**Photobucket sucks**
[Re: Mopar1]
#200681
01/22/09 08:05 AM
01/22/09 08:05 AM
Posts: 10,757 North Dakota
6PakBee
North Dakota
If the cylinder passed the leakdown test, it probably isn't a ring seal issue. That would rule out the ring/wall incompatibility question. Looks to me like that cylinder isn't firing. What color is the exhaust valve on that cylinder? If it isn't a shade of brown then you aren't firing. Fuel, fire, and mechanically sound are all required to work. Start checking what you don't have. Good luck.
[Re: 6PakBee]
#200682
01/22/09 10:16 AM
01/22/09 10:16 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Check you intake port on that cylinder for oil. It could be a sealing issue for the intake. Oil will show up on the intake valve too.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: Seank]
#200684
01/22/09 11:12 AM
01/22/09 11:12 AM
Rug_Trucker
Did you use block off plates for the exhaust crossover?
[Re: Seank]
#200685
01/22/09 12:39 PM
01/22/09 12:39 PM
70Cuda383
Marysville, O-H-I-O
well, if you really are not firing in that cylinder, all that fuel has to go somewhere, and will find its way into your oil pan. that's why your pan smells of gas.
my oil smells of exhaust and is super black after maybe 500 miles of driving.
but then again, It's been about 4 years now since my Cuda's been on the road, and all our other cars are modern, computer controlled EFI crap, so maybe I got spoiled in that short amount of time and am being too critical of my engine!
[Re: Seank]
#200686
01/22/09 02:21 PM
01/22/09 02:21 PM
The top of your piston looks like it's either being washed down by fuel with no combustion or is not getting any fuel at all entering the cylinder. This would definitely contribute to the engine running rough. As stated, you could have an ignition problem caused by a bad spark plug wire, dist. cap, severe vacuum leak, etc. In regard to the excessive noise you are hearing have you checked for zero valve lash on each cylinder?
#200687
01/22/09 04:15 PM
01/22/09 04:15 PM
Posts: 3,318 Southern Maryland
klunick
Southern Maryland
This may be fishing, but when you put the engine together, all your pistons looked alike/correct. I think the engine bottom is all good. I might suspect you have an intake or an electrical problem. Are your wires on correctly and was the dizzy installed right. That one cylinder could possibly indicate something is out of firing order and by the looks of the other ones and your description, it may be all of them are out.
67 Barracuda FB
69 Superbee
"Southern Maryland: If you want a good looking woman, you had better bring her with you"
[Re: 6PakBee]
#200688
01/22/09 05:55 PM
01/22/09 05:55 PM
Posts: 4,179 California
mickm
California
... Looks to me like that cylinder isn't firing. What color is the exhaust valve on that cylinder? ...
the very second i saw that picture, that is what i thought, "that cylinder isn't firing". personally, i would look there first. what does the plug look like? what do the valves look like? test the plug wire to that cylinder, check the distributor cap, etc...
doesn't mean i'm right, but if it was me, that is the first place i would start...
[Re: klunick]
#200690
01/22/09 06:05 PM
01/22/09 06:05 PM
Posts: 94 Austin, Texas
Seank
Austin, Texas
Rug Trucker id you use block off plates for the exhaust crossover A: I am running an edelbrock performer and fel pro 1213, no exhaust crossover. Mopar 4 me: In regard to the excessive noise you are hearing have you checked for zero valve lash on each cylinder? A: Umm no. I just used the original rocker set with new pushrods but used .030 shims to put it back to what the machine shop said it cut off the deck. I never had valve problems with it before but after I let it sit for 1 year one of them started tapping real bad on startup and it always did after that point, even after an oil change. Now i think its just went bad and maybe its not pumping up anymore to open up a valve. Cam looks perfect so I’ll put new lifters in there, they are cheap enough. Klunick: I think the engine bottom is all good. I might suspect you have an intake or an electrical problem. Are your wires on correctly and was the dizzy installed right. That one cylinder could possibly indicate something is out of firing order and by the looks of the other ones and your description, it may be all of them are out. A: Dist is an aftermarket mopar unit, unchanged from when it ran great. Idles perfectly but under load it runs like crap. I think the plugs are fouled and/or the dist is not pumpin out the amps. I’ll ohm check the wires, and check every spark at the end of the wire. If if no good I’ll put my MSD6 on the car. I appreciate everyones suggestions. I am going to throw the intake on tonight sans gaskets and see how much clearance I have between it and the heads to make sure the intake wasn’t cut too much leading to an oil intake problem. Then I will pick up new gaskets/plugs and all of that and get it all back together. This just illustrates why you can’t leave engines sitting for a long time. I was getting real depressed there for a while. Thanks Sean
[Re: burdar]
#200692
01/22/09 07:01 PM
01/22/09 07:01 PM
Bad valve guide? You said the intake valve had some oil on the back.
[Re: mickm]
#200695
01/23/09 09:18 AM
01/23/09 09:18 AM
Rug_Trucker
A nice tool is the infared thermometer. I bought it when I bought my Cummins to check it. I found one cylinder on my Duster is running 160* so somehing is going on there. It may be valve lash is too tight. I've been running some pretty close lash with the stock cam.
