Front bumper brackets - E-body? #2005552
02/04/16 05:36 PM
02/04/16 05:36 PM
Albany, NY
stevec Offline OP
stevec  Offline OP
Albany, NY
Are the front bumper brackets the same for a 1974 Cuda and a 1971 Cuda?
Re: Front bumper brackets - E-body? [Re: stevec] #2005575
02/04/16 06:22 PM
02/04/16 06:22 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Nope. 70-72 brackets are shorter. 73-74 are longer, as the bumper sticks out further to comply with the feds 5 mph crash regs. A rubberized filler piece was used to fill the gap.
Re: Front bumper brackets - E-body? [Re: 318 Stroker] #2005588
02/04/16 06:48 PM
02/04/16 06:48 PM
Albany, NY
stevec Offline OP
stevec  Offline OP
Albany, NY
Thanks.
Re: Front bumper brackets - E-body? [Re: stevec] #2005603
02/04/16 07:11 PM
02/04/16 07:11 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Something I should clarify. If you're wanting to use the 73-74's on a 71, you could re-drill the brackets to mount them further rearward.
If you go mixing bumpers and brackets, check the bolt hole spacing where the bumper bolts to the brackets as I think it may be different.
Are you wanting to put 74's on a 71, or 71's on a 74?
Re: Front bumper brackets - E-body? [Re: stevec] #2005668
02/04/16 08:54 PM
02/04/16 08:54 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You might want to check. When I put tucked the bumpers in on my 73 Challenger there were 2 sets of holes. I just slid them back. Is a Cuda the same don't know but it's worth checking. Also I mounted 71 bumpers on them. In the rear I used 72 brackets.
Doug
Re: Front bumper brackets - E-body? [Re: stevec] #2006032
02/05/16 12:55 PM
02/05/16 12:55 PM
Albany, NY
stevec Offline OP
stevec  Offline OP
Albany, NY
I am going to be installing 1971 bumpers on a 1971 car. My problem was that I took the brackets off years ago and couldn't find them. I did find a set off the 1974 parts car that I had. I finally did locate the brackets from the 71, so now I'm ok. Thanks for your help.
