ram owers #2005473
02/04/16 03:12 PM
02/04/16 03:12 PM
bc
3
37dodge Offline OP
37dodge  Offline OP
bc
On my 2011 ram the seal on the cargo/ brake light on the back of the cab went and the storage units under the back seat filled with water. not sure how common this is just a heads up.
Re: ram owers [Re: 37dodge] #2005592
02/04/16 06:52 PM
02/04/16 06:52 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I have heard of it before so I would say it is not uncommon. I believe it was a issue on many years. Also the rear sliding window drains get clogged and can cause water issues also.
Re: ram owers [Re: mopars4ever] #2005727
02/04/16 10:40 PM
02/04/16 10:40 PM
Mo.
racerx Offline
racerx  Offline
Mo.
^^^This^^^and I have a older 95 model ram mad
Re: ram owers [Re: racerx] #2005811
02/05/16 12:09 AM
02/05/16 12:09 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
On a 1995 Ram Clubcab rear sliding window there are two small indented spots in the lower slider groove.
Are these the drains that get stopped up?
These two cutouts do not seem to have holes going downward, but a spray shot of WD40 into them seems to drain away.
On a 1995 if the upper rear brake light cover is not sealed with a bead of silicone RTV it will let in water that strangely drains through hidden interior sheet metal channels that end up in the front seat passenger side floor mat area.
Re: ram owers [Re: 360view] #2005967
02/05/16 08:47 AM
02/05/16 08:47 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Thaxs for the info. thumbs
Re: ram owers [Re: 37dodge] #2006018
02/05/16 12:08 PM
02/05/16 12:08 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: ram owers [Re: 37dodge] #2006603
02/06/16 11:03 AM
02/06/16 11:03 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Thaxs for that link. thumbs
Re: ram owers [Re: mopars4ever] #2006670
02/06/16 01:05 PM
02/06/16 01:05 PM
USA
3
360view Offline
360view  Offline
3
USA
I also thank you for the link.
I went out and looked again on my manual sliding rear windows on my 1995.
There are two small outside drains on the rear window lower weatherstripping.
I gently pressed a thin steel wire up into both of these outside drains but the wire would not continue up completely into the interior window slider groove.
Apparently on 1994-1995s at least
The water is supposed to drain to the right/left sides of the slider groove
and then out under black cover bars on each side
before liquid turns downward through the two weatherstrip drains.
This keeps you from fishing a wire through to check that a drain is open.
Re: ram owers [Re: 37dodge] #2006802
02/06/16 04:05 PM
02/06/16 04:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Same thing happens to non-sliders and it is the third brake light. Some RTV on the rubber gasket cures it.
Re: ram owers [Re: 37dodge] #2006873
02/06/16 06:46 PM
02/06/16 06:46 PM
bc
3
37dodge Offline OP
37dodge  Offline OP
bc
On mine third light filled with water and burned out the brake light, i made a new rubber gasket.
