Re: Use of muriatic acid....
[Re: Apollo 13]
#2008408
02/09/16 03:56 AM
02/09/16 03:56 AM
Posts: 802 Maysville, Kentucky
Apollo 13
Maysville, Kentucky
Bumping this back up.....
Indcontrols....What type of device for water pressure. Like a deck pressure washer or ? And how long was this process.
Rebel....How long was it before you saw any results. I have a place that can hot tank it. Do you think that would do it over the course of a few weeks...or ?
Thanks in advance for all the help.
If you don't start it , you don't have to end it.
Re: Any and All Ideas on removing engine block filler ?
[Re: rowin4]
#2008511
02/09/16 01:14 PM
02/09/16 01:14 PM
Posts: 8,360 fredericksburg,va
cudaman1969
fredericksburg,va
Just a note on the muriatic acid. As it might eat away the hard block slowly it will also eat away at the block material at a faster rate. Also if anyone is thinking of using muriatic acid for rust removal , don't do it in your garage, the fumes will kill you before you can get out, also the fumes will rust every piece of bare metal in the garage. Do it out side with a good breeze blowing away from anything that you might like to keep, also wear rubber gloves and eye protection . I other words, muriatic acid is some bad $hit. That's new to me, I have used MA for years on all types of steel-cast iron, never saw any metal removed, what looked like metal removed was what the rust had allready eaten. Always use outside keep in closed container. For the OP, put a few drops in there and see what happens, never know unless tried.
[Re: Apollo 13]
#2008560
02/09/16 02:29 PM
02/09/16 02:29 PM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
I wonder if soaking in vinegar would break it down?
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
[Re: BBR]
#2008562
02/09/16 02:32 PM
02/09/16 02:32 PM
dartman366
Mt. Vernon, Ohio
I wonder if soaking in vinegar would break it down? Well, if not at least it will be pickled. ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
[Re: Apollo 13]
#2008846
02/09/16 10:20 PM
02/09/16 10:20 PM
Posts: 1,361 Wild West
M_D
Wild West
If the acid didn't at least eat away enough filler in a certain time frame (before the block started to significantly suffer), it might be hard to rinse and neutralize acid that found its way into deeper voids between the filler and block.
If I had the block and seriously wanted to find out I would try to remove a sample piece of the filler and do some testing outside the block.
[Re: Bill1234]
#2369958
09/13/17 11:53 AM
09/13/17 11:53 AM
Posts: 4,586 Motor City
6PKRTSE
Motor City
I have a buddy that has a 455 Pontiac block 3/4 filled and drives it on the street all of the time. It runs cooler than any of my Mopars every have.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#2369982
09/13/17 12:35 PM
09/13/17 12:35 PM
Posts: 13,407 Marion, South Carolina [><]
an8sec70cuda
I have a buddy that has a 455 Pontiac block 3/4 filled and drives it on the street all of the time. It runs cooler than any of my Mopars every have. Water temp will be cooler...common for a filled block. But I bet the oil temp is up there.
[Re: Apollo 13]
#2370992
09/14/17 11:10 PM
09/14/17 11:10 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
My half fill 528 will sit in traffic all day in summer but gets up a bit on the highway
1963 Plymouth Max Wedge 1971 Barracuda
