Re: wheel horsepower vs. ET
[Re: mcat4321]
#2005801
02/04/16 11:49 PM
02/04/16 11:49 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I shift my D50 at 6800 but cross the finish line at 63-6400 and the Wallace calculator says that I am making 638 hp with my ET and weight. My dyno sheet says I am making 638 hp at 6800. That sounds pretty close. But the dyno said my motor makes 662 hp at 7300.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#2005810
02/05/16 12:08 AM
02/05/16 12:08 AM
Posts: 2,855 Pattison Texas
CSK
Pattison Texas
I shift my D50 at 6800 but cross the finish line at 63-6400 and the Wallace calculator says that I am making 638 hp with my ET and weight. My dyno sheet says I am making 638 hp at 6800. That sounds pretty close. But the dyno said my motor makes 662 hp at 7300. use the mph
[Re: mcat4321]
#2005815
02/05/16 12:15 AM
02/05/16 12:15 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
540 rwhp on my challenger 3600lbs or so got me around a 6.70 1/8th
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: mcat4321]
#2005819
02/05/16 12:23 AM
02/05/16 12:23 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
It seems to me that most of the time I hear someone throwing their HP numbers around and bragging about it they have never raced their car. Many just like to bench race with their HP numbers as I see it a good bit. I always ask them what does the car run since to me HP means little if you dont know how to use it and get it to the ground. Its funny when I see a hotrod with a blower and making over 1000 HP and yet they never race it. Ron
[Re: D-50]
#2005980
02/05/16 09:22 AM
02/05/16 09:22 AM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
One thing is for sure, whether you want to believe the Calculator is RWHP or something else, if you are not correcting your track mph for atmospheric conditions before you use the calculator, the number you get will be an actual hp number, which is not what people use when talking chassis and engine dynos numbers. They are always using corrected numbers. And that little piece of cardboard and most on line calculators have no idea if you are in Colorado on a 90°F day or Maryland on a 42°F day.
[Re: mcat4321]
#2006008
02/05/16 11:29 AM
02/05/16 11:29 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
508 rwhp at 3700 lbs. ran 10.40 at 129.1 mph 636 rwhp at 3800 lbs. ran 9.54 at 140.4 mph
Same car, 2 different engines, same DynoJet chassis dyno.
[Re: Duner]
#2006034
02/05/16 01:00 PM
02/05/16 01:00 PM
383man
Balt. Md
On my tech card - I always say mine has 250hp.
Same thing when somebody asks. It's WAY easier than hearing somebody tell me their brother's neighbor's uncle's brother had one JUST like it that made 400 hp stock - that went 9.00s off the showroom floor. Then they start into that whole "$100 bill on the dash story"........ Yea that $100 dollar bill on the dash has been around a long time as I cant even remember how many times I have heard that. I had a guy tell me his basically stock 340 Demon ran low 12's so I asked him his mph in the 1/4 ? He told me about 135 ! I told him I could run high 9's with that mph. Ron
[Re: an8sec70cuda]
#2006053
02/05/16 01:42 PM
02/05/16 01:42 PM
Posts: 570 UK
rb446
UK
Same car, 2 different engines, same DynoJet chassis dyno. Thats quite interesting in the % drivetrain loss dept actually.... 636rwhp/3800 = 864fly to run the no's 60 Foot E.T. : 1.33 1/8 Mile E.T. : 6.02 1/8 Mile Trap Speed : 112.88 1/4 Mile E.T. : 9.54 1/4 Mile Trap Speed : 140 36% loss on the day at the track to rwhp dyno figs 508rwhp/3700 = 650fly to run the no's. 60 Foot E.T. : 1.45 1/8 Mile E.T. : 6.56 1/8 Mile Trap Speed : 103.58 1/4 Mile E.T. : 10.40 1/4 Mile Trap Speed : 129 28% loss per rwhp dyno figs thats a bit excessive in the loss dept! perhaps weight is the answer if drivetrain the same? As I said before I'm not saying my calcs are 100% as only a tool but its worked out pretty much spot on for everything I've ever inputed, but then it would cos I'm after hp no's for the cars I ran and know about all the spec of the motors which matches up with hp produced/weights and timeslips + I ran at the same track every time, Santa Pod. 0 elevation....so you just keep changing the hp no. till you get the Actual ET/mph run....working in reverse if you like.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: rb446]
#2006063
02/05/16 02:00 PM
02/05/16 02:00 PM
an8sec70cuda
Same car, 2 different engines, same DynoJet chassis dyno. Thats quite interesting in the % drivetrain loss dept actually.... 636rwhp/3800 = 864fly to run the no's 60 Foot E.T. : 1.33 1/8 Mile E.T. : 6.02 1/8 Mile Trap Speed : 112.88 1/4 Mile E.T. : 9.54 1/4 Mile Trap Speed : 140 36% loss on the day at the track to rwhp dyno figs 508rwhp/3700 = 650fly to run the no's. 60 Foot E.T. : 1.45 1/8 Mile E.T. : 6.56 1/8 Mile Trap Speed : 103.58 1/4 Mile E.T. : 10.40 1/4 Mile Trap Speed : 129 28% loss per rwhp dyno figs thats a bit excessive in the loss dept! perhaps weight is the answer if drivetrain the same? As I said before I'm not saying my calcs are 100% as only a tool but its worked out pretty much spot on for everything I've ever inputed, but then it would cos I'm after hp no's for the cars I ran and know about all the spec of the motors+ I ran at the same track every time, Santa Pod. 0 elevation....so you just keep changing the hp no. till you get the Actual ET/mph run....working in reverse if you like. The actual timeslips were... 1.49, 6.62 at 104.1 mph, 10.40 at 129.1 mph 1.32, 6.05 at 112.9 mph, 9.54 at 140.4 mph The torque converters were different for each motor, but the rest of the driveline is identical. The car gained weight w/ the bigger motor due to adding a rollcage. The 60' is slow on the 10.40 pass NOT due to spinning...that combo just didn't leave real hard.
[Re: an8sec70cuda]
#2006065
02/05/16 02:17 PM
02/05/16 02:17 PM
Posts: 570 UK
rb446
UK
I think thats pretty close for the big hp motor, so I think I've been using a pretty good system. The one thing I did manage to do was beat the short time numbers given by a small amount on a few occasions with the 440 car I ran.
[Re: mcat4321]
#2006075
02/05/16 02:28 PM
02/05/16 02:28 PM
Posts: 570 UK
rb446
UK
Yes thats correct, and weight of car, drivetrain design and and......I personally am not interested in rwhp, its fly hp for exactly that reason, but it was interesting to see how much was in theory actually lost with those rw dyno no's when most say 10>20% and Wallace says 10%
[Re: Duner]
#2006358
02/05/16 11:04 PM
02/05/16 11:04 PM
Posts: 570 UK
rb446
UK
I have dyno charts showing RWHP - but the numbers are overly optimistic / false when compared to actual timeslips. Since all dynos are different, I assume the one I was on would be considered "happy" or "not stingy". LOL It worked well for a tuning tool, but that's about it.
With that said: 705rwhp only produced 10.51 @ 130.13 mph at 4190# in my truck. Actually using my numbers I think your 705rwhp quoted is actually closer to fly hp!....and as you say "optimistic" by a long way I reckon, as this is what I got for your timeslip> Power to Weight Ratio: 5.87 60 Foot E.T. : 1.46 1/8 Mile E.T. : 6.63 1/8 Mile Trap Speed : 102.53 1/4 Mile E.T. : 10.51 1/4 Mile Trap Speed : 128 thats with a hp input of 714/4190lbs
what is probably more correct is if put in 748fly hp you get> 60 Foot E.T. : 1.44 1/8 Mile E.T. : 6.53 1/8 Mile Trap Speed : 104.14 1/4 Mile E.T. : 10.34 1/4 Mile Trap Speed : 130 thats probably more in line with a heavy as trying to get 4000+ to move ain't easy, your gonna lose some ET, set aside aero issues, thats a hard one! I just got too much time on my hands and don't race anymore ..and I'm stuck in front of my computer mostly with my work.
