Mopar Cyl Head Porting Templates - RB/LA/Mag - download here #1999692
01/27/16 12:40 PM
01/27/16 12:40 PM
Manitoba, Canada
DaytonaTurbo Offline OP
Manitoba, Canada
For your downloading pleasure I am happy to present downloadable versions of the Mopar cylinder head bowl porting templates for big block B/RB, small block LA and Magnum. Complete printable templates with instructions in pdf form.
A special thank-you needs to go out to RapidRobert. He generously mailed me hard copies which I scanned and used to create this pdf.
Enjoy!
Uploading the file to the moparts server did not produce a downloadable result, even after I formatted a version to fit under the moparts 2mb file limit. I have uploaded the file to 3 different online file sharing websites. If all of these fail, feel free to PM me your email address and I can send them to you direct.
http://www.filedropper.com/moparportingtemplates-rblamagnum
(nice quick download when I tried it this morning)
http://www.filehosting.org/file/details/538414/Mopar%20Porting%20Templates%20-%20RB_LA_Magnum.pdf
(sends a download link to your email junk folder which you must click on, download is quick)
http://s000.tinyupload.com/?file_id=01537989574007844684
(direct download, slow speed but works)
Re: Mopar Cyl Head Porting Templates - RB/LA/Mag - download here [Re: DaytonaTurbo] #2000026
01/27/16 09:26 PM
01/27/16 09:26 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Cool, downloaded from the first site just fine. Thank You.
Re: Mopar Cyl Head Porting Templates - RB/LA/Mag - download here [Re: DaytonaTurbo] #2000312
01/28/16 09:58 AM
01/28/16 09:58 AM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
Thanks for putting that together.
Re: Mopar Cyl Head Porting Templates - RB/LA/Mag - download here [Re: DaytonaTurbo] #2000379
01/28/16 12:44 PM
01/28/16 12:44 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Thanks!!!
Getting old just means you were smarter than some and luckier than others.
Re: Mopar Cyl Head Porting Templates - RB/LA/Mag - download here [Re: DaytonaTurbo] #2001876
01/30/16 01:29 PM
01/30/16 01:29 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Thank you
Re: Mopar Cyl Head Porting Templates - RB/LA/Mag - download here [Re: DaytonaTurbo] #2005172
02/03/16 11:41 PM
02/03/16 11:41 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Thanks - any W2 templates out there?
Re: Mopar Cyl Head Porting Templates - RB/LA/Mag - download here [Re: Sixpak] #2005457
02/04/16 02:48 PM
02/04/16 02:48 PM
dogdays Offline
dogdays  Offline
Company porn blocker blocked all three sites.
Have to do it at home, I guess.
R.
Re: Mopar Cyl Head Porting Templates - RB/LA/Mag - download here [Re: DaytonaTurbo] #2005988
02/05/16 10:23 AM
02/05/16 10:23 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
Thats awesome!
So would it be ok to just scale up the width for bigger valves?
Re: Mopar Cyl Head Porting Templates - RB/LA/Mag - download here [Re: DaytonaTurbo] #2006117
02/05/16 03:25 PM
02/05/16 03:25 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
I do have cleaner versions of the LA-Swirl Port instructions at home, let me know if you want me to email you these.
Also, I second Sixpak's Q...any W2 templates out there???
Re: Mopar Cyl Head Porting Templates - RB/LA/Mag - download here [Re: Alchemi] #2006397
02/05/16 11:53 PM
02/05/16 11:53 PM
Scaling em up may work (I ain't up on "scaling") but what I do know works is if you have 2.14 intakes is to widen the 2.08 templates 30 tho wider on each side (2.14-2.08= .060 div by 2 is .030" . I'd trace em out that much wider on a clear sheet of fairly stiff laminate plastic like what they come on. EDIT Yeah I dont know why the LA swirl port instructions were so double printed/messy, that is the way I got em & they were brand new
Re: Mopar Cyl Head Porting Templates - RB/LA/Mag - download here [Re: DaytonaTurbo] #2018744
02/24/16 01:54 PM
02/24/16 01:54 PM
Manitoba, Canada
Manitoba, Canada
If anyone's tried printing them up yet, I'd be interested to hear any real-world feedback.
Re: Mopar Cyl Head Porting Templates - RB/LA/Mag - download here [Re: DaytonaTurbo] #2019212
02/25/16 01:20 AM
02/25/16 01:20 AM
nj pine beach
dart9ss Offline
dart9ss  Offline
nj pine beach
I have a set of originals part # p4120437 never used. if anybody is interested I ll let them go for a couple bucks. It's clear plastic sheet with the direct connection instruction sheet.
pm me.
Re: Mopar Cyl Head Porting Templates - RB/LA/Mag - download here [Re: DaytonaTurbo] #2024972
03/05/16 01:39 PM
03/05/16 01:39 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
DaytonaTurbo and RapidRobert, thanks so much for doing this!
I think its important to note that the high swirl LA head templates are NOT for all LA heads ever made. They are designed for the later model 308 and 576 heads, or the P series 459269, 5249767, or 5249574 heads ONLY. Use of these templates on any heads made earlier than the late '80s could run the risk of thin walls and water jacket penetration.
One of the best summaries I've seen on small block heads is here on moparts: http://www.moparts.org/Tech/Archive/smallblock/23.html
Re: Mopar Cyl Head Porting Templates - RB/LA/Mag - download here [Re: TC@HP2] #2025034
03/05/16 03:16 PM
03/05/16 03:16 PM
Manitoba, Canada
Manitoba, Canada
Yes, and the instructions with the templates state this much.
Re: Mopar Cyl Head Porting Templates - RB/LA/Mag - download here [Re: DaytonaTurbo] #2025359
03/05/16 11:57 PM
03/05/16 11:57 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
The first download site doesn't seem to work (anymore?) for me.
The second site, personally I usually don't care much for leaving behind my emailaddress on those sharing sites.
The tinyupload-site did work OK.
But I'm willing to provide a more clean downloadlink for this PDF and templates from my site. The PDF is downloadable as also viewable on the site;
http://www.bigblockmopar.com/tech/mopar-porting-templates-rb-la-magnum-heads/
If not, I'll remove the page again.
