Re: Quarter mile times and setup.
[Re: 70VcodeCoronetRT]
#2009642
02/11/16 12:29 AM
02/11/16 12:29 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Steve, is he still running a stock 6.1 intake? Ive been told those are pretty much done at 6500 rpm. I have one I ported and polished on mine, i'd say its done at more like 6900 but I have not put it on a dyno to find out.
Mopar to the bone!!!
[Re: gremlinsteve]
#2009647
02/11/16 12:34 AM
02/11/16 12:34 AM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
There's a guy on the LXForums that's run a 9.4 @ 144 mph in a 3200 lb Magnum. It's a pretty decent build, 468" and Thitek heads. I'm sure a similar time could be run at less cubes and Apache heads, just have to twist it harder. You should wait till we get the small cam out of that monster and the new one in A lil more head and get that stock intake worked on some and we're hoping for a much better number I'm taking this is a NA engine. Can you post the engine specs or are they not available for viewing.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: sixpackgut]
#2009748
02/11/16 09:53 AM
02/11/16 09:53 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
67 barracuda 3150lbs
6.1 block 4.08 x 4.09 bore 11-1. 600 lift 250@50 Ported eagles Short 4150 intake with some porting. 2" dom adapter and thumpercarb 2" tti headers
Best 1.41, 6.25, 9.88 @ 134
9" conveter and 3.55 gears
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: 72Swinger]
#2011080
02/13/16 01:26 PM
02/13/16 01:26 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
^^^ That is pretty dang impressive right there! I will probably never make a "good" pass in mine but I couldnt be happier with its performance on pump gas and 0 maintenance and ability to drive it anywhere. At 122 mph in your 72 Dart you have low 11's potential with good hook. Ron
#2011547
02/14/16 12:41 AM
02/14/16 12:41 AM
72Swinger
Nebraska
Thanks Ron, im confidant it has 124-125 in it but honestly its far from setup for drag racing. Its a corner carver.
#2013618
02/16/16 11:55 PM
02/16/16 11:55 PM
72Swinger
Nebraska
Rick what size injectors and fuel pressure do you use?
#2014179
02/17/16 07:35 PM
02/17/16 07:35 PM
Posts: 361 Canada
onig
Canada
340Rick, tell us more on engine set-up.
69 Dart
#2014240
02/17/16 09:09 PM
02/17/16 09:09 PM
Posts: 3,998 GO BUCKS !!!!!!!
340RICK
GO BUCKS !!!!!!!
60lb siemens at 42psi
6.1 block with manley crank and rods with diamond pistons 426"
CNC 6.1 heads by modern then touched up by David Barton
265/274 @ 50 solid roller with gutted stock lifters and harland sharp rockrs 3/8 push rods
OTB Drag Pak intake and 4150 FAST throttle body FAST XFI/XIM 2.0
purty simple combo made 776HP on Bartons dyno
#2014242
02/17/16 09:15 PM
02/17/16 09:15 PM
72Swinger
Nebraska
Thanks Rick, I think I need to go down in injector size.
[Re: pittsburghracer]
#2021267
02/28/16 01:25 PM
02/28/16 01:25 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I hope its super strong because Goss just broke his stock block
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
#2021320
02/28/16 02:28 PM
02/28/16 02:28 PM
72Swinger
Nebraska
I think Goss needs a billet block and Hellcat heads.
