Re: Quarter mile times and setup. [Re: gremlinsteve] #2009633
02/11/16 01:18 AM
02/11/16 01:18 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Please do tell! What size cam is in it now and what is it being replaced with? What aspect were you involved with on the build? Very impressive build
Re: Quarter mile times and setup. [Re: 70VcodeCoronetRT] #2009642
02/11/16 01:29 AM
02/11/16 01:29 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Steve, is he still running a stock 6.1 intake? Ive been told those are pretty much done at 6500 rpm. I have one I ported and polished on mine, i'd say its done at more like 6900 but I have not put it on a dyno to find out.
Mopar to the bone!!!
Re: Quarter mile times and setup. [Re: gremlinsteve] #2009647
02/11/16 01:34 AM
02/11/16 01:34 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Originally Posted By gremlinsteve
Originally Posted By WO23Coronet
There's a guy on the LXForums that's run a 9.4 @ 144 mph in a 3200 lb Magnum. It's a pretty decent build, 468" and Thitek heads. I'm sure a similar time could be run at less cubes and Apache heads, just have to twist it harder.
You should wait till we get the small cam out of that monster and the new one in
A lil more head and get that stock intake worked on some and we're hoping for a much better number
I'm taking this is a NA engine. Can you post the engine specs or are they not available for viewing.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Quarter mile times and setup. [Re: 70VcodeCoronetRT] #2009687
02/11/16 02:38 AM
02/11/16 02:38 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What does sixpackgut rum again? He's well in the 9's in an A body isn't he?
Re: Quarter mile times and setup. [Re: sixpackgut] #2009748
02/11/16 10:53 AM
02/11/16 10:53 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Originally Posted By sixpackgut
67 barracuda 3150lbs
6.1 block 4.08 x 4.09 bore
11-1. 600 lift 250@50
Ported eagles
Short 4150 intake with some porting.
2" dom adapter and thumpercarb
2" tti headers
Best 1.41, 6.25, 9.88 @ 134
9" conveter and 3.55 gears
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Quarter mile times and setup. [Re: 72Swinger] #2011080
02/13/16 02:26 PM
02/13/16 02:26 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted By 72Swinger
^^^ That is pretty dang impressive right there! I will probably never make a "good" pass in mine but I couldnt be happier with its performance on pump gas and 0 maintenance and ability to drive it anywhere.
At 122 mph in your 72 Dart you have low 11's potential with good hook. up Ron
Re: Quarter mile times and setup. [Re: 70VcodeCoronetRT] #2011547
02/14/16 01:41 AM
02/14/16 01:41 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Thanks Ron, im confidant it has 124-125 in it but honestly its far from setup for drag racing. Its a corner carver.
Re: Quarter mile times and setup. [Re: 70VcodeCoronetRT] #2013462
02/16/16 10:03 PM
02/16/16 10:03 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
I can tell you guys that I removed a 422 W9RP motor and replaced it with a G3 that was a 6.1 block and heads stroked to 426"
my car weighed 3250 with 727 and dana on drag radials with 456 gear and exhaust. same car combo for both motors
W9 went 9.63
3G went 9.61
pretty darn impressive for stock block and heads
Re: Quarter mile times and setup. [Re: 70VcodeCoronetRT] #2013618
02/17/16 12:55 AM
02/17/16 12:55 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Rick what size injectors and fuel pressure do you use?
Re: Quarter mile times and setup. [Re: 70VcodeCoronetRT] #2014179
02/17/16 08:35 PM
02/17/16 08:35 PM
Canada
onig Offline
onig  Offline
Canada
340Rick, tell us more on engine set-up.
69 Dart
Re: Quarter mile times and setup. [Re: 70VcodeCoronetRT] #2014240
02/17/16 10:09 PM
02/17/16 10:09 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
60lb siemens at 42psi
6.1 block with manley crank and rods with diamond pistons 426"
CNC 6.1 heads by modern then touched up by David Barton
265/274 @ 50 solid roller with gutted stock lifters and harland sharp rockrs 3/8 push rods
OTB Drag Pak intake and 4150 FAST throttle body
FAST XFI/XIM 2.0
purty simple combo made 776HP on Bartons dyno
Re: Quarter mile times and setup. [Re: 70VcodeCoronetRT] #2014242
02/17/16 10:15 PM
02/17/16 10:15 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Thanks Rick, I think I need to go down in injector size.
Re: Quarter mile times and setup. [Re: 72Swinger] #2021187
02/28/16 12:08 PM
02/28/16 12:08 PM
PA.
"Little"John
"Little"John
PA.
Are you guys following this one. Looks like blocks are coming soon.
http://www.yellowbullet.com/forum/showthread.php?t=1603762
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Quarter mile times and setup. [Re: pittsburghracer] #2021267
02/28/16 02:25 PM
02/28/16 02:25 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I hope its super strong because Goss just broke his stock block
Re: Quarter mile times and setup. [Re: 70VcodeCoronetRT] #2021320
02/28/16 03:28 PM
02/28/16 03:28 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I think Goss needs a billet block and Hellcat heads.
