Re: Modern Bullitt build
[Re: rhamson]
#1994390
01/19/16 10:07 PM
01/19/16 10:07 PM
Posts: 676 Maryland
Keepat
Maryland
Good work Pat. I love the way over the top" engineering you are doing on this project. Patience is your virtue. Thank you Ralph, I hope you're well and move along with your challenge your project? Pat
[Re: PasiR]
#1995164
01/20/16 09:56 PM
01/20/16 09:56 PM
Posts: 676 Maryland
Keepat
Maryland
Very nice driveshaft loop! Thank You! I'm really happy with how it turned out. Pat
[Re: Keepat]
#1996275
01/22/16 02:03 PM
01/22/16 02:03 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Been watching this one, and it is really turning out nice. Your attention to detail and fab skills is what separates this car from the rest. Too bad most will never notice or appreciate the time and skills required. Keep it up!!
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
[Re: Keepat]
#1996328
01/22/16 03:33 PM
01/22/16 03:33 PM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
The driveshaft/extra crossmember is a fantastic idea and should help give your car roll cage like rigidity with all the extra supports you have installed to shore up the flimsy unibody! I also installed the subframe connectors/ torque boxes in my Challenger without any drivetrain installed. I'm not sure how the factory did this but I am sure it will lessen any amount of frame deflection and movement once the drivetrain is installed.... My car will be put on an alignment rack and setup for optimism performance so I am sure factory specs won't work for me......
71 Challenger 528 Hemi project 09 Gr Cherokee 5.7 hemi in da house!!
[Re: CJD AUTOMOTIVE]
#1996482
01/22/16 06:51 PM
01/22/16 06:51 PM
Posts: 676 Maryland
Keepat
Maryland
Been watching this one, and it is really turning out nice. Your attention to detail and fab skills is what separates this car from the rest. Too bad most will never notice or appreciate the time and skills required. Keep it up!! Thank you Craig!
[Re: mopar4don]
#1996489
01/22/16 06:56 PM
01/22/16 06:56 PM
Posts: 676 Maryland
Keepat
Maryland
I know for one, I APPRECIATE the time you take to show your work! It sure helps guys like me with there build.
Say Pat, can you tell me why your putting the torq boxes in now without the weight of the motor? Don, I did install the frame connectors when the car was complete and on the ground, and with the frame connectors installed I didn't see any problem with adding torque boxes when the car was on the rotisserie. It is so much nicer welding right side up instead of upside down ;-) Thank you! Pat
[Re: tpabayflyer]
#1996490
01/22/16 06:59 PM
01/22/16 06:59 PM
Posts: 676 Maryland
Keepat
Maryland
The driveshaft/extra crossmember is a fantastic idea and should help give your car roll cage like rigidity with all the extra supports you have installed to shore up the flimsy unibody! I also installed the subframe connectors/ torque boxes in my Challenger without any drivetrain installed. I'm not sure how the factory did this but I am sure it will lessen any amount of frame deflection and movement once the drivetrain is installed.... My car will be put on an alignment rack and setup for optimism performance so I am sure factory specs won't work for me...... I am very happy with the way the crossmember driveshaft loop came out and considering the modification I made to the factory crossmember I think it added a lot more rigidity to the frame. Thank you! Pat
[Re: Keepat]
#2004516
02/03/16 12:30 AM
02/03/16 12:30 AM
Posts: 2,963 Wisconsin
Stewpar
Wisconsin
Pat:
I personally ignore this thread for periods of time so that I can spend more time looking at more pictures and updates. The work you do is amazing, your creativity and attention to detail are out of this world. I will be both happy and sad when this build is done!
Admiration For Multiple Carburetor Vehicles...
[Re: Stewpar]
#2004728
02/03/16 12:08 PM
02/03/16 12:08 PM
Posts: 676 Maryland
Keepat
Maryland
Pat:
I personally ignore this thread for periods of time so that I can spend more time looking at more pictures and updates. The work you do is amazing, your creativity and attention to detail are out of this world. I will be both happy and sad when this build is done! Funny my wife would like me to do the same thing with the build ;-) Thank You! Pat
[Re: Keepat]
#2004748
02/03/16 12:50 PM
02/03/16 12:50 PM
Posts: 20,328 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
Cannot wait to see the finished product. This is one of the best threads Moparts has ever had, and the car is certainly going to be one of the nicest anywhere.
Earning every penny of that moderator paycheck.
DBAP
"They don't think it be like it is, but it do." - Oscar Gamble
[Re: not_a_charger]
#2004960
02/03/16 06:01 PM
02/03/16 06:01 PM
Posts: 676 Maryland
Keepat
Maryland
Cannot wait to see the finished product. This is one of the best threads Moparts has ever had, and the car is certainly going to be one of the nicest anywhere. Thank you sir!!! Pat
[Re: Hooligan]
#2006834
02/06/16 05:20 PM
02/06/16 05:20 PM
Posts: 676 Maryland
Keepat
Maryland
AMAZING work and imagination! What planet are you from??? LOL, I'm pretty sure earth but some of my friends think it's planet Uranus ;-) Thank you! Pat
