Re: SB Victor heads shipped...well, at least mine!
[Re: CJD AUTOMOTIVE]
#1999745
01/27/16 02:14 PM
01/27/16 02:14 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Talked to Rick and found out the delay. They would run a set and it would do everything right and then screw up a port. Run another and fine, another and screw one up. They chased it for awhile and had to get Haas out and they tore the machine down and found a broken tooth in the rotary table. They are back up and producing. Here is a milled rocker stand head: ![](http://i1060.photobucket.com/albums/t445/340cuda/IMG_0440_zpsyrli1z2p.jpg)
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
#1999762
01/27/16 02:45 PM
01/27/16 02:45 PM
fast68plymouth
So. Burlington, Vt.
I guess I'm still confused as to why they wouldn't locate the exhaust bolt holes to be more vertically centered on the port openings.
[Re: fast68plymouth]
#1999840
01/27/16 04:11 PM
01/27/16 04:11 PM
Posts: 656 Florida
CJD AUTOMOTIVE
I guess I'm still confused as to why they wouldn't locate the exhaust bolt holes to be more vertically centered on the port openings. Rick fixed that. This is an early head that was junked from the machine problem. Using it as a test for rocker stands milled. Remember the W5 gasket is round port, and these are "D" shaped, so not as far off as it looks. Here is a gasket: ![](http://i1060.photobucket.com/albums/t445/340cuda/GA-HG340W5R_zpscvlvq3so.jpg)
#2000414
01/28/16 01:45 PM
01/28/16 01:45 PM
fast68plymouth
So. Burlington, Vt.
Admittedly I am not up on all the latest stuff available for the SB mopar, but are there commercially available headers that have flanges that are reasonably close to those gaskets, or is this pretty much a situation where you're going to need custom headers?
#2000584
01/28/16 06:17 PM
01/28/16 06:17 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Admittedly I am not up on all the latest stuff available for the SB mopar, but are there commercially available headers that have flanges that are reasonably close to those gaskets, or is this pretty much a situation where you're going to need custom headers? Your good, TTI and others make W5 headers.
#2000585
01/28/16 06:22 PM
01/28/16 06:22 PM
dartman366
Mt. Vernon, Ohio
Admittedly I am not up on all the latest stuff available for the SB mopar, but are there commercially available headers that have flanges that are reasonably close to those gaskets, or is this pretty much a situation where you're going to need custom headers? Your good, TTI and others make W5 headers. I have W2/W5 Hedman Hustlers on my car, I think Hooker makes them too.
#2000780
01/28/16 11:17 PM
01/28/16 11:17 PM
dartman366
Mt. Vernon, Ohio
And those headers have flanges that are pretty close to the pic of that gasket?
The reason I ask is, and maybe my memory is off(very possible)but I thought the W2 center ports were spread farther apart than how that gasket looks.
Maybe someone will post a pic of that gasket on the head & header when they start getting into people's hands. mine had the adapter plates that bolted to the head and I port matched the adapter plate, then the headers bolted to the plates.
#2000973
01/29/16 03:16 AM
01/29/16 03:16 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Admittedly I am not up on all the latest stuff available for the SB mopar, but are there commercially available headers that have flanges that are reasonably close to those gaskets, or is this pretty much a situation where you're going to need custom headers? Your good, TTI and others make W5 headers. TTI is working on a new header for this head...in the car, no existing header will work...not sure about a W5 fenderwell but for sure no under chassis header will work... The ex. port is too high and wide (overall width of head Int.-ex.). Hoping he does 2 styles, 1 street around 1 7/8 x 3.5" and another around 2" step with a 4" collector. Brian
Brian Hafliger
#2014324
02/18/16 12:00 AM
02/18/16 12:00 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Surely you have the heads now?
Brett Miller W9 cnc'd heads STR Chassis fabraction
#2043525
04/01/16 02:13 PM
04/01/16 02:13 PM
Posts: 6,018 Salem
Grizzly
Moparts Proctologist
Salem
Hughes has a little update on their site, gives the impression things are rolling along to get these in your hands. I have my mind made up for a set, but want to see you guys get them up and running and provide a review first. ![work work](/ubbthreads/images/graemlins/custom/work.gif)
Mo' Farts
Moderated by "tbagger".
#2043612
04/01/16 04:00 PM
04/01/16 04:00 PM
1967dartgt
Hilltown Pa
wonder if they will ever get done
