What is the cost and availability of this Chivvy alt?
Depends on which version you want.
63 A is about $46.99 + $15 core (PN 7127-3)
78 A like mine is $71.99 +16 core (PN 7273-3)
94 A is $71.99 + $16 core (PN 7294-3)
The prices are all from advance. My local one had all three in stock, and if one died in the field you could use any of the 3 in a pinch. You can probably get them cheaper online. There are also some even higher amp versions, you just need a 12SI with 3-o clock clocking.
The plug for the regulator to connect to your wiring harness is $3.29. You'd then need a rectifier diode with the stripe on the alternator side in the "warning light" wire which will connect to any fused, 12V keyed power source and connect the other wire to the blue wire from your mopar alternator, this is the sense wire and will determine where in the harness it regulates the voltage to.
Been using this since 2011 without any issues. I even have EFI and Electric fans (Ford Contour) and it works well on all.
