Crew cab cabs, 2wd vs 4 wd #2001535
01/29/16 10:54 PM
01/29/16 10:54 PM
Bellevue,Mich.
Dodge33 Offline OP
Dodge33  Offline OP
Bellevue,Mich.
Got a 76 4wd truck, was gonna replace the cab with a 74 2wd. I am sure the tunnel in the front is a little bigger. The problem is the carpet jute in glued down,and the carpet is glued to that, I mean glued down.I tried to scrap it up but it is gonna take some time.just wondering what the in's and out's are.thanks for reading this and thanks in advanced for any help.
Re: Crew cab cabs, 2wd vs 4 wd [Re: Dodge33] #2001769
01/30/16 05:56 AM
01/30/16 05:56 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
You could apply heat to the bottom of the cab and see if itll loosen up
