Re: MT 33x10.5w vs Hoosier 33x10.5w for a 4-Speed NSS car.
[Re: Thumperdart]
#1999718
01/27/16 01:23 PM
01/27/16 01:23 PM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
Are those screens on your carbs or those Edelbrock air filters.......hard to tell........
Thumper, They are the old style sort of heart shaped air cleaners without filters. Also located under the air cleaner cover, I have some fine screens as an additional layer. No close up pics here at the office, but here are a couple of underhood pics. Problem with mine is I am using an old Eddy STR cross ram intake. It is modified to make the carbs into an inline setup, but they are too close together for most filters. Setting these up back to back with some small mods, plus the additional screen inside gives me protection from debris, but it is still not as good as a regular filter. The extra screens underneath are fine veggie strainers with the handles cut of LOL. -Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
[Re: dvw]
#1999719
01/27/16 01:25 PM
01/27/16 01:25 PM
GTSDave
Thanks again for all the replies. Looks like I will probably drop down in tire size, and start shopping for new front shocks.
-Dave
[Re: GTSDave]
#1999759
01/27/16 02:40 PM
01/27/16 02:40 PM
GTSDave
Thanks Sky,
Just found an e-mail from 2007 and it looks like my slicks were purchased back in May or June of 2007! Time to change them, even though they only have 52 passes. I just don't trust them... So the slicks are getting chaged out for sure.
Still working on other upgrades as well. For us the racing season is just around the corner, and our local tracks appear to still be open with the exception of rain days...... Hope to get some TNT and video before the SHRA season kicks off again.
-Dave
[Re: GTSDave]
#1999779
01/27/16 03:06 PM
01/27/16 03:06 PM
Thumperdart
State of confusion
Thumper, They are the old style sort of heart shaped air cleaners without filters. Also located under the air cleaner cover, I have some fine screens as an additional layer. No close up pics here at the office, but here are a couple of underhood pics. Problem with mine is I am using an old Eddy STR cross ram intake. It is modified to make the carbs into an inline setup, but they are too close together for most filters. Setting these up back to back with some small mods, plus the additional screen inside gives me protection from debris, but it is still not as good as a regular filter. The extra screens underneath are fine veggie strainers with the handles cut of LOL. -Dave Take em off, re tune and get back w/us cos those things SUCK big time and yes, I`ve tested em...........
[Re: GTSDave]
#1999850
01/27/16 04:25 PM
01/27/16 04:25 PM
GTSDave
Thumper,
Not trying to discount your advice and will keep it in mind.
Not sure you can see it in the pics, but there is no filter media/foam in them, just a secondary screen to keep rocks and tire bits out of the engine. Some tracks we run at have a short ramp up area and there are times when I get pelted with debris from cars in front of me in the burnout box. I have run with and without them and they made no difference whatsoever. Carb spacing is too close together to run anything off the shelf.
The video above was showing one of the passes after I started having trouble with a vacuum leak at a race. Jetted up some to keep going as the rounds were getting short. Made it to the finals that night at close to 2am on a greasy track only to red light at the big show LOL. But thats racing.
My 60' times were way off even before the bog and I believe it was a traction issue.
Looked through my log book and the fastest pass so far was 10.22/138.29 Terrible 60' with a big top end charge. Blew the tires off. So far the quickest pass was a 9.952/137.79 same track but a different race. Both were in St. Louis.
The only thing changed in my combo between those runs and the one in the video was an up size in the jetting because of the vacuum leak. You should have seen the pass before that one where it REALLY bogged! I have it on video somewhere. Will look for it.
-Dave
[Re: GTSDave]
#1999928
01/27/16 07:28 PM
01/27/16 07:28 PM
Posts: 4,457 Washington
madscientist
Washington
With a stick you need double adjustable up front. Even if it is a Viking or QA1's. There is no way I would just tighten up the shock on bump and rebound.
It looks like you may have a bit too much travel up front too. I can't see the video.
[Re: GTSDave]
#2000001
01/27/16 08:59 PM
01/27/16 08:59 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
Very Nice Car I haven't used tires the same tires but used MT29.5 x 10.5 stiff sidewall and Hoosier 29.0 x 10.5W (also stiff sidewall). Last year at the hot rod reunion (New England) I decided to put new hoosiers on since the MT had about 150 passes. My 60' times were way off. I also tried launching at 5500 and could not get better than 1.45 60'. So on the 2nd day I put the old MTs back on and the 60' dropped to 1.41. I tried it again at Lebanon Valley and saw the same thing. So just went back to the old MTs. Then dropped the launch to 4500 and the 60' dropped down to 1.34 Kind of interesting
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: GTSDave]
#2000265
01/28/16 02:47 AM
01/28/16 02:47 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I run close to your times, 10.30 at 130 . I just have stock Monro shocks up front, got tired of changing oil pans. Launches with the wheels up as pictured , shift before the 60 foot. 60 ft times are 1.47 . Launch at 4,700 shift at 6,800 3.25 low gear, 4.56 rear with 11.5 29.5 W Hoosiers. Low compression 505 pump gas engine.
[Re: GTSDave]
#2000631
01/28/16 07:11 PM
01/28/16 07:11 PM
GTSDave
Ok,
I will be ordering new slicks within the next couple of days. Just dont trust these because they are so old. I will order the M/T.
Monty, your point on the shocks is well taken and several people off the board have told me the same thing.
So which shocks to you all recommend.
-Dave
