Bushing lifter bores in KB block
#1999556
01/27/16 02:00 AM
01/27/16 02:00 AM
Posts: 216 America
WedgeFED
America
So can you all tell me why everyone bushes lifter bores to restrict oil to the top end on a B1MC headed, T&D paired shafts, KB block engines that will be push rod oiled? I am confused why it is bad to restrict oil thru pushrods vs. lifter bushings. I have spent many hours reading thru old posts here but have not found any solid answers as of yet. I would like to bush my block but need to make up my mind on how to restrict the oil to the top. Ken Black does not think it is necessary but everyone else has different opinions. I would like to think oil to the lifters would be your friend but I have seen a lot of people here restrict it in the bushings. So please help. Thanks
Re: Lifter bushings and push rod oiling
[Re: WedgeFED]
#1999570
01/27/16 02:36 AM
01/27/16 02:36 AM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
I added PR oiling to my Hemi and a friends wedge.Lost 15 lbs of OP.Last time the engine was apart,installed restrictors in the push rods and got the 15 lbs back.I put over 2k miles on it every year and get to the track 3 or 4 times.I WANT full pressure to the lifters,even with lots of idleing there is no problem.
[Re: WedgeFED]
#1999608
01/27/16 05:03 AM
01/27/16 05:03 AM
Posts: 43,225 Bend,OR USA
Cab_Burge
I'm assuming your running a solid roller camshaft with the lifters set up for pushrod oiling, correct? If so then are your lifters slotted or solid body? if slotted and have a very small hole in them for the pushrod oiling isn't that a restrictor If solid body with a small oil hole for pushrod oiling how big is that hole? I have a set of Indy 440-1 heads with a set of paired shaft Jesels rocker arms that need pushrod oiling, I'm using a set of Comp Cams # 892 slotted (cut out, not solid body)roller lifters that have two holes in the slots in them for the pushrod oiling those heads. I JB welded up one hole on the non pressure side per instructions from Comp, I'm using them in a stock 400 block that these lifters oiling holes are sitting in the main oil galleys when the lifters are on the heel of the cam so they will oil the rockers for most of the time. I am going to use a set of spray bar covers also to help make sure there is enough oil spraying onto the valve springs(400+ lbs on the seats and 910 to 940 lbs open) to help keep them cool If it ends up flooding the valve covers with to much oil I'll restrict the spray bar fittings to a smaller size. I do have a set of B1-MC heads also that will probally end up with either a set of T&D paired shaft rockers like yours or maybe another set of Jesels Those heads will be used on a Koleno high nickel iron block with the lifters bushed with a small oiling hole already in them from Koleno for a future racing project
[Re: dvw]
#1999658
01/27/16 11:39 AM
01/27/16 11:39 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Mine is a SB but I have bushed bores with a .060 hole and .040 restrictions in the PRs with TD paired rockers... it was suggested to me to use a .040 hole vs .060... I didnt because I have the EDM hole in the lifters for the axle oiling... the one thing I didnt know was the EDM hole is .026 and I was told it was .013.. thats a big difference in loss
[Re: AndyF]
#1999908
01/27/16 06:47 PM
01/27/16 06:47 PM
Posts: 216 America
WedgeFED
America
Thanks for the info. So bushing the lifter bores is not necessary if you restrict thru push rods? I do know the lifter bores in a KB block are a lot taller that a stock block. I just trying to figure out why you would want to restrict oil to lifters? I'm kinda torn on bushing the block due to cost as for it is another 600$ on top of a 7k block. I just want to do it right the first time as for the KB block is a new thing to me. There is a lot of opinions on this so I am trying to sort thru them. It will be a 4.5 bore 3.9 stroke solid roller motor that will turn some rpm's. I would think the geometry would be perfect in a new block from KB and I do understand the chances of failure and a lifter coming out of the bore and loosing pressure. So it appears the main reason to bush with a small hole in bushing is mainly to protect from loss of oil pressure if a failure happens correct? I do also plan to run a bushed roller lifter rather than a bearing roller lifter if that is worth anything. Thanks
[Re: WedgeFED]
#1999912
01/27/16 06:53 PM
01/27/16 06:53 PM
Posts: 31,050 Oregon
AndyF
What does KB say? I haven't seen a new KB block so I don't know if the lifter gallery is fed in the same way as a stock block. You might not have an issue if the lifter bores are already divorced from the gallery. I seem to recall that KB used a main gallery elsewhere in the block.
You might have better luck if you start a different thread and ask about bushed lifter bores in a KB block. Someone with recent KB experience can tell you what they know.
I do know that people bush the lifter bores in Indy blocks to correct the geometry but maybe KB has better machining processes than Indy??
440Jim had a KB block set up for pushrod oiling so maybe send him a PM. I think a couple other guys on here also have experience with that. Point is you are asking a very specialized question and your thread title isn't going to help you get the answer.
Re: Bushing lifter bores in KB block
[Re: WedgeFED]
#2001007
01/29/16 05:17 AM
01/29/16 05:17 AM
Cab_Burge
Did KB say to run a chrome lifter in that unbushed block instead of a standard steel body roller lifter?
[Re: WedgeFED]
#2001070
01/29/16 11:30 AM
01/29/16 11:30 AM
Posts: 361 Canada
onig
Canada
How are you guys restricting the pushrods for limited oiling?
69 Dart
[Re: WedgeFED]
#2001167
01/29/16 02:21 PM
01/29/16 02:21 PM
Posts: 19,373 Las Vegas
Al_Alguire
Las Vegas
Don't recall saying it was superior to a KB. I have had them and they are by far the best there is IF you can et one. As for the Indy I will stand by that as I have both. You are right I have no track record and am surely not very well informed
[Re: WedgeFED]
#2001190
01/29/16 02:56 PM
01/29/16 02:56 PM
Al_Alguire
Las Vegas
Nothing wrong with me. Maybe just trigger happy over an incorrect statement I suppose If I offended you I apologize. Lots of ways to skin a cat for sure.
