Bushing lifter bores in KB block #1999556
01/27/16 02:00 AM
01/27/16 02:00 AM
America
WedgeFED Offline OP
WedgeFED  Offline OP
America
So can you all tell me why everyone bushes lifter bores to restrict oil to the top end on a B1MC headed, T&D paired shafts, KB block engines that will be push rod oiled? I am confused why it is bad to restrict oil thru pushrods vs. lifter bushings. I have spent many hours reading thru old posts here but have not found any solid answers as of yet. I would like to bush my block but need to make up my mind on how to restrict the oil to the top. Ken Black does not think it is necessary but everyone else has different opinions. I would like to think oil to the lifters would be your friend but I have seen a lot of people here restrict it in the bushings. So please help.
Re: Lifter bushings and push rod oiling [Re: WedgeFED] #1999570
01/27/16 02:36 AM
01/27/16 02:36 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I added PR oiling to my Hemi and a friends wedge.Lost 15 lbs of OP.Last time the engine was apart,installed restrictors in the push rods and got the 15 lbs back.I put over 2k miles on it every year and get to the track 3 or 4 times.I WANT full pressure to the lifters,even with lots of idleing there is no problem.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Lifter bushings and push rod oiling [Re: WedgeFED] #1999608
01/27/16 05:03 AM
01/27/16 05:03 AM
I'm assuming your running a solid roller camshaft with the lifters set up for pushrod oiling, correct? If so then are your lifters slotted or solid body? if slotted and have a very small hole in them for the pushrod oiling isn't that a restrictor work If solid body with a small oil hole for pushrod oiling how big is that hole? I have a set of Indy 440-1 heads with a set of paired shaft Jesels rocker arms that need pushrod oiling, I'm using a set of Comp Cams # 892 slotted (cut out, not solid body)roller lifters that have two holes in the slots in them for the pushrod oiling those heads. I JB welded up one hole on the non pressure side per instructions from Comp, I'm using them in a stock 400 block that these lifters oiling holes are sitting in the main oil galleys when the lifters are on the heel of the cam so they will oil the rockers for most of the time. I am going to use a set of spray bar covers also to help make sure there is enough oil spraying onto the valve springs(400+ lbs on the seats and 910 to 940 lbs open) to help keep them cool shruggy If it ends up flooding the valve covers with to much oil I'll restrict the spray bar fittings to a smaller size. I do have a set of B1-MC heads also that will probally end up with either a set of T&D paired shaft rockers like yours or maybe another set of Jesels shruggy Those heads will be used on a Koleno high nickel iron block with the lifters bushed with a small oiling hole already in them from Koleno for a future racing project devil
Re: Lifter bushings and push rod oiling [Re: WedgeFED] #1999626
01/27/16 09:22 AM
01/27/16 09:22 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I believe the answer is the oil leakage is through the rocker. I have paired T&D. My pushrod are restricted to .040". The rockers and pushrod ends look perfect. I put 300 passes on them and they were used when I got them. My lifter bore clearance is .002", bushed with a .100" feed hole
Doug
Re: Lifter bushings and push rod oiling [Re: dvw] #1999658
01/27/16 11:39 AM
01/27/16 11:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Mine is a SB but I have bushed bores with a .060
hole and .040 restrictions in the PRs with TD
paired rockers... it was suggested to me to use
a .040 hole vs .060... I didnt because I have the
EDM hole in the lifters for the axle oiling... the
one thing I didnt know was the EDM hole is .026 and
I was told it was .013.. thats a big difference in
loss
wave
Re: Lifter bushings and push rod oiling [Re: WedgeFED] #1999723
01/27/16 01:28 PM
01/27/16 01:28 PM
AndyF Offline
AndyF  Offline
Bushing the lifters is done for a lot of reasons that have nothing to do with restricting the oil to the top end. One reason to bush the lifters is to correct the geometry. Another good reason is to keep the oil gallery from getting exposed during operation or when something bad happens.
If you bush the lifter bores then you have to decide if you're going to run the lifter dry or not. If you want to oil the top end thru the pushrods you have to drill a small hole in the bushing in order to oil the lifter. If you don't drill the holes in the bushings then you have dry lifters and you cannot oil the top end.
Re: Lifter bushings and push rod oiling [Re: AndyF] #1999908
01/27/16 06:47 PM
01/27/16 06:47 PM
America
WedgeFED Offline OP
WedgeFED  Offline OP
America
Thanks for the info. So bushing the lifter bores is not necessary if you restrict thru push rods? I do know the lifter bores in a KB block are a lot taller that a stock block. I just trying to figure out why you would want to restrict oil to lifters? I'm kinda torn on bushing the block due to cost as for it is another 600$ on top of a 7k block. I just want to do it right the first time as for the KB block is a new thing to me. There is a lot of opinions on this so I am trying to sort thru them. It will be a 4.5 bore 3.9 stroke solid roller motor that will turn some rpm's. I would think the geometry would be perfect in a new block from KB and I do understand the chances of failure and a lifter coming out of the bore and loosing pressure. So it appears the main reason to bush with a small hole in bushing is mainly to protect from loss of oil pressure if a failure happens correct? I do also plan to run a bushed roller lifter rather than a bearing roller lifter if that is worth anything. Thanks
Re: Lifter bushings and push rod oiling [Re: WedgeFED] #1999912
01/27/16 06:53 PM
01/27/16 06:53 PM
AndyF Offline
AndyF  Offline
What does KB say? I haven't seen a new KB block so I don't know if the lifter gallery is fed in the same way as a stock block. You might not have an issue if the lifter bores are already divorced from the gallery. I seem to recall that KB used a main gallery elsewhere in the block.
You might have better luck if you start a different thread and ask about bushed lifter bores in a KB block. Someone with recent KB experience can tell you what they know.
I do know that people bush the lifter bores in Indy blocks to correct the geometry but maybe KB has better machining processes than Indy??
440Jim had a KB block set up for pushrod oiling so maybe send him a PM. I think a couple other guys on here also have experience with that. Point is you are asking a very specialized question and your thread title isn't going to help you get the answer.
Re: Lifter bushings and push rod oiling [Re: WedgeFED] #2000362
01/28/16 12:08 PM
01/28/16 12:08 PM
NC
440Jim Offline
440Jim  Offline
NC
A standard KB water block does not have any pressurized oil going to the lifter galleries. They offer an option to gun drill the passages to intersect the lifter bores for pushrod and/or lifter pressure oiling. That passage intersects on the opposite side of the lifter bore than a stock block. The KB block does have a different "priority" oiling main passage from the pump to the main bearings. If you order the optional lifter oiling, a passage is machined up the back of the block, around the cam bearing, and then forward to intersect the lifter bores. You can see the main oil passage on the Left side. The holes with the spot face are drilled through the main passage to each main bearing, then a pipe plug is put in each external hole.
I ran my 2014 KB block with the optional lifter oiling passages and T&D paired rockers (pushrod oiling). I restricted the Comp 892 (offset) roller lifters by plugging both ~.1" dia holes and drilling the oil passage side ~0.035". IMO, restricting the pushrod is a valid choice also. My block did not have the lifter bores bushed, as KB does not think it is needed. The cam I ran had lobe lifts of 0.471"/0.451" (int/exh).
Re: Lifter bushings and push rod oiling [Re: 440Jim] #2000419
01/28/16 01:50 PM
01/28/16 01:50 PM
America
WedgeFED Offline OP
WedgeFED  Offline OP
America
Thanks 440Jim. Sounds like you have the same story I was told. The block I have on order does have the lifter oil option. And yes KB told me lifter bushings are not needed. I have just kinda been confused due to so many different opinions and also seeing so many people bushing the lifter bores to restrict oil. I'm sure I have a while till I have to make a decision as for my block has only been on order since Oct. 6 2015...
Re: Bushing lifter bores in KB block [Re: WedgeFED] #2000435
01/28/16 02:14 PM
01/28/16 02:14 PM
wappinger falls new york
Jimi_Vignogna Offline
we run a .030" hole in the bushings and .028" restriction hole in the pushrods.
Re: Bushing lifter bores in KB block [Re: WedgeFED] #2001005
01/29/16 05:01 AM
01/29/16 05:01 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
I modified these to fit the lifter oil galleys of the KB block.
http://www.summitracing.com/int/parts/mor-22016/overview/
Plynouth VIP '67 TT IC EFI
Re: Bushing lifter bores in KB block [Re: WedgeFED] #2001007
01/29/16 05:17 AM
01/29/16 05:17 AM
Did KB say to run a chrome lifter in that unbushed block instead of a standard steel body roller lifter?
Re: Bushing lifter bores in KB block [Re: WedgeFED] #2001070
01/29/16 11:30 AM
01/29/16 11:30 AM
Canada
onig Offline
onig  Offline
Canada
How are you guys restricting the pushrods for limited oiling?
69 Dart
Re: Bushing lifter bores in KB block [Re: WedgeFED] #2001081
01/29/16 11:57 AM
01/29/16 11:57 AM
Jerry Kathe Offline
Jerry Kathe  Offline
Bushing are not required in a dry bore aluminum block (such as KB or INDY- must be of equivalent alloy). Special material lifters are not required either. I have also used banded and solid body lifters with no notable difference either but prefer banded.
If its not a motor that see's extended idle time such as street cruising. ...dont mess with push rod oiling...not required or desirable for race applications.
Re: Bushing lifter bores in KB block [Re: WedgeFED] #2001152
01/29/16 02:05 PM
01/29/16 02:05 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
ummmmm.....ok, I will continue to do it the wrong way thanks stirthepot
Re: Bushing lifter bores in KB block [Re: WedgeFED] #2001162
01/29/16 02:11 PM
01/29/16 02:11 PM
Jerry Kathe Offline
Jerry Kathe  Offline
Says the guy who thinks the world block is superior to Indy/KB.
haha
Re: Bushing lifter bores in KB block [Re: WedgeFED] #2001167
01/29/16 02:21 PM
01/29/16 02:21 PM
Las Vegas
Las Vegas
Don't recall saying it was superior to a KB. I have had them and they are by far the best there is IF you can et one. As for the Indy I will stand by that as I have both. You are right I have no track record and am surely not very well informed
Re: Bushing lifter bores in KB block [Re: Al_Alguire] #2001186
01/29/16 02:48 PM
01/29/16 02:48 PM
Jerry Kathe Offline
Jerry Kathe  Offline
[quote=Al_Alguire. You are right I have no track record and am surely not very well informed [/quote]
What do you mean by that?
I never said or suggested any such thing.
One thing that I will say is that in past, when I have provided input to someone completly other than you, you have more than once made sarcastic-pretentious comments for no logical reason......[ Moparts Family Site - Keep it Friendly ] is wrong with you?
Re: Bushing lifter bores in KB block [Re: WedgeFED] #2001190
01/29/16 02:56 PM
01/29/16 02:56 PM
Las Vegas
Las Vegas
Nothing wrong with me. Maybe just trigger happy over an incorrect statement I suppose smile
If I offended you I apologize. Lots of ways to skin a cat for sure.
