Tubular rivet tools #2000097
01/27/16 11:00 PM
01/27/16 11:00 PM
Bellevue,Mich.
Dodge33 Offline OP
Dodge33  Offline OP
Bellevue,Mich.
I have some grilles I want to restore. I seen some pliers and dies on eBay. Where should I buy a good set from? On the rivets I can figure out the diameter, but how about the length? Any info you can give me I want to say thanks in advance. The grilles are 69 road runner I am gonna start on,then 69 dart and so on.
Re: Tubular rivet tools [Re: Dodge33] #2000264
01/28/16 02:44 AM
01/28/16 02:44 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Here is a source for rivets and rivet tools.
http://www.aircraftspruce.com/menus/ha/rivets.html
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: Tubular rivet tools [Re: Dodge33] #2000386
01/28/16 12:54 PM
01/28/16 12:54 PM
WNY
slimert Offline
slimert  Offline
WNY
I bought a rivet squeezer off ebay a while back, get one with the deepest throat available. IMHO it'll pay for itself on one grill resto. As far as the hollow rivet length, I think it was 3/16" but that was for a 70 Challenger grill.
http://www.ebay.com/itm/Hand-Rivet-Squeezer-3-Reach-w-6-Rivet-Sets-New-/280750358896?hash=item415e068170:m:mzVJU70QXC78cOw5LG-JOQg
Re: Tubular rivet tools [Re: Dodge33] #2001009
01/29/16 06:37 AM
01/29/16 06:37 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Google semi tubular rivets to find many suppliers of rivets and tools.
To determine length, see this chart:
http://www.rivetsinstock.com/rivets/semitubular-rivets.html
For example, for 1/8" dia semi tubular rivets, length = grip + 0.075", where grip is the material thickness to be riveted.
If you have access to both sides of the rivet, you can save on tooling by using a hand clincher, hammer, and a buck. An example of a buck would be a 1/4"-3/8" dia steel rod held in a rigid vice with the head of the rivet placed on the tip of the rod. The rod tip should be dished to the shape of the rivet head.
See hand clinchers here. What is called the "optional squeezer die" is how the dished end of the rod above should be made, or you could buy their die and stick it in the drilled end of a rod or other fixture.
http://www.hansonrivet.com/hand-rivet-clinchers.htm
As said at this site, you can squeeze in a drill press if you have room. The clincher would be held in the drill press chuck, and the squeezer die would be held below. This gives an idea of how much force is needed to squeeze a rivet. Hint: don't turn the power on.
Photo is a clincher I made on my lathe.
Re: Tubular rivet tools [Re: Dodge33] #2001348
01/29/16 06:10 PM
01/29/16 06:10 PM
Georgia
1969383S Offline
1969383S  Offline
Georgia
http://tubularrivetclincher.yolasite.com/
This is the tool I have and used for 69 Barracuda grille rebuild.
I also used this tool for the fresh air doors, Ashtray , Heater Box, 2 speed Wiper Motor and more. Easily paid for itself after one grille.
www.Rivetinstock.com had all the varying size rivets required and even a quantities of 100 were inexpensive IMO.
Gerald
