Re: 1970 GTX Firewall
[Re: RT03]
#1999896
01/27/16 06:22 PM
01/27/16 06:22 PM
Posts: 5,141 East Aurora (Buffalo) NY
RoadRunner
Did someone convert the car to a four speed at one time? I actually see three black plastic plugs between teh master cylinder and inner fender. Two holes are for the studs of the clutch pedal bracket and the middle one most likely from the spot weld that held bracket to firewall. Though, most I have seen had two spot welds. I also see the z-bar linkage that sits on top of the frame rail. So at some point, there was most likely a four speed in the car.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RT03]
#2000496
01/28/16 03:38 PM
01/28/16 03:38 PM
RoadRunner
To be 100% correct on filling the holes from the clutch bracket, I beleive the two holes that lined up with the studs were acutally dimples. The spot weld hole should be flat. I wish I had a picture to show you. My 69 Road Runner firewall had the two dimples. I just drilled them out to add my clutch when I converted to four speed.
[Re: RoadRunner]
#2000654
01/28/16 07:48 PM
01/28/16 07:48 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
To be 100% correct on filling the holes from the clutch bracket, I beleive the two holes that lined up with the studs were acutally dimples. The spot weld hole should be flat. I wish I had a picture to show you. My 69 Road Runner firewall had the two dimples. I just drilled them out to add my clutch when I converted to four speed. Yes they are dimples
