Re: 440 stock stroke 10 second combos
[Re: Street Monkies]
#1999156
01/26/16 06:23 PM
01/26/16 06:23 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
I think you'll run 10s easily at that weight. I'd use a better intake and more stall.
My old 440+.030"=446" combo ran 10.40 at 129.1 mph at 3700 lbs. Ross domes, 14:1 compression, Manley H beams, stock crank Indy SR heads, out of the box other than being shaved down for compression Weiand Team G manifold, 1050 dominator Herbert solid roller 266°/278° at .050", .660"/.620" lift, 106 LSA 727, 9" 5k stall, 4.10 gear, 28x10.5 slick
#1999184
01/26/16 07:09 PM
01/26/16 07:09 PM
Posts: 336 Creston, Iowa
340man4ever
Creston, Iowa
Mine: 1974 Dodge Dart 2dr 3300lbs at the line. 440 zero decked w/flat top pistons. Ported 915 heads flow 268/207 peak. 11.25:1 Compression Mopar 590 Solid Cam 850 HP carb, M1 intake, McCandless/ ProParts Headers 727 trans w/ Dynamic 9.5 converter (hi gear flashes 5100) 4.30 gear, 30x9 slicks Footbrake @ 1800rpm shift at 6200 Bests so far: 10.77 @ 122.8 mph 1/4 1.47 60 ft 6.80 @ 99.79 1/8th
Curator at Adams County Speed Shop
#1999196
01/26/16 07:28 PM
01/26/16 07:28 PM
Posts: 9,883 MI, usa
dvw
MI, usa
440+.060",Eddy RPM heads w/ bowl cleaned, 590" MP cam, swap meet single plane, 850 Holley, Ross flat top 12-1, LY rods, 8" converter, 4.56,10.5x29.5 M/T, 68 GTX 3750. 10.85-10.95 122-123 depending on weather. Doug
#1999206
01/26/16 07:45 PM
01/26/16 07:45 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Our dragster weighs right at 1900lbs and goes goes 8.40's at elevation in Vegas, generally .3 slower than sea level FWIW. Stock block stock stroke Chinese rod ross piston 446 with a set of mildly ported -1 heads(too big really). It is actually the motor for my 68 D100. Pump gas, just under 11-1 compression very small roller. Should be plenty to propel a 2600lb car into the 9.30's at lea level.
#1999274
01/26/16 08:53 PM
01/26/16 08:53 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
At that weight...it takes very little to run 10s...
Ported 452s (flowed 262@.600), 10:1 comp, 440, M1, 950HP, 259/.550 Comp Solid, etc. ET/MPH in my sig at 3800 lbs....That combo would be knockn on 9s at your weight.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
#1999281
01/26/16 09:03 PM
01/26/16 09:03 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
For the guys running LY rods, or a cheap I beam/H beam rod. Was is your thoughts on those?. I found some I beam rods on ebay and the company claims they will handle 800 hp. Has ARP bolts. They weigh 800g, and they're $255. They're cheap H beam rods but most of them have the .990 pin. Rods are no place to pinch pennies. Long before I'd run a $255 I beam from an ebay vendor I'd run LY rods. Of course they CLAIM up to 800 hp. Sounds better than "Use at your own risk about 500 hp"...LOL. Another PROVEN "budget" rod are the ones from 440source.
#1999309
01/26/16 09:48 PM
01/26/16 09:48 PM
Posts: 1,107 Massillon, Ohio
cudatom
Massillon, Ohio
At that weight you should have no problems hitting 10's. My Cuda at 3400 ran 10.82-10.90 w/.040 over 440, 6 pk rods, heavy trw domed pistons, 590 cam, weiand intake w/750 dp and 452 heads from McCandless. This was engine lasted from 1988-2002. Was very consistent.
Ok
#1999314
01/26/16 09:57 PM
01/26/16 09:57 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Get the heads ported, a decent 5000 converter, 2" supersucker and you should be in the 9's My old motor ran 10.1 at 3150.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
#1999318
01/26/16 09:59 PM
01/26/16 09:59 PM
Posts: 570 UK
rb446
UK
Here's mine
'69 Cuda 3000lbs at the line, 1968 440SP block +.030", 10:1CR Single external Oiling by Milodon mildly ported 906's, 2.14/1.81 HS Roller Rockers CC .650" 290@.050 solid flat tappet cam Team G, 850DP, 2" f/wells Race 727, 4500 verter 14x32's, 4.88 gears Ladder Bars/coil overs 35sp Strange spool/shafts stock fr suspension w/90/10's. Went 10.7@125, 1.46 short time
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: Von]
#1999328
01/26/16 10:07 PM
01/26/16 10:07 PM
Posts: 142 Chattanooga, TN
KDY
Chattanooga, TN
Ported 452s (flowed 262@.600), 10:1 comp, 440, M1, 950HP, 259/.550 Comp Solid, etc. ET/MPH in my sig at 3800 lbs....That combo would be knockn on 9s at your weight. I'd love to hear more about this combo. What gear and converter?
[Re: Von]
#1999337
01/26/16 10:23 PM
01/26/16 10:23 PM
Posts: 1,030 ohio
67mprfan
ohio
With my Demon the best I've had so far is in my SIG it weighs 2950 with me in it...
My Buddy duster with similar setup with trans brake went 10.05 back to back in good air both are stock stroke combos
I would suggest a better converter for your combo..... What car are you using this in
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: KDY]
#1999342
01/26/16 10:28 PM
01/26/16 10:28 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Low 9.80's twenty plus years ago with a .030 over 440, stock rods (shot peened and new 3/8 bolts), TRW pistons, stock crank, roller cam, Weiand tunnel ram with two 750 holleys ( 76 jets Summer, 78 jets Fall), ported 906 heads. car weighed 2700 pounds, 727, J convertor, 14-31 slicks, and a 4.45 dana rear. Don't be afraid to go with at least a 4400 stall convertor at least. Same combo ran 10.0's with a single 1050 carb.
I will be a cake-walk with Stealth heads.
