Re: 77 D100 steering issue
[Re: elmor353]
#1998583
01/25/16 07:42 PM
01/25/16 07:42 PM
RapidRobert
manual steering or power steering? it did not wander before & you rebuilt it cuz it was simply worn out, correct? if so then it has to be in the caster/camber/toe in settings to which he set it to.
[Re: elmor353]
#1998597
01/25/16 08:12 PM
01/25/16 08:12 PM
RapidRobert
I ain't sure, I was wanting to get some basic info to try & pin it down some (till the truck guys see this) unless something obvious jumped out at me & nothing is hitting me. EDIT Something just did hit me: if it handled OK before but was sloppy/worn out & now it is tighter from the rebuild but the alignment made it handle worse then it has to be the alignment settings (there were no offset bushings in there before & they ain't in there now)
[Re: Don_440]
#1998846
01/26/16 03:45 AM
01/26/16 03:45 AM
Posts: 4,231 State of retirement
52savoy
State of retirement
You may aso want to look at where the steering box is mounted,usually cracks and lets the box move,had serveral of these trucks and even seen brace made across frame for support generally speaking i would start there ,then coupler,after that check ball joints(especially if it flows grooves in road or darts from side to side after hitting bumps) hopefully tech checked ilder arm,etc Must be a pretty common problem with those old trucks. My '77 has had the front frame boxed along with welded tabs on each frame rail and a 1 1/4" tubing brace bolted across. It was done right at the (rebuilt)steering box. Also someone put in a sway bar, poly strut rod bushings and looks like the control arm bushings have been tinkered with. Got this truck a month ago and still finding good stuff on it.
