HEMI tick? #1995383
01/21/16 07:59 AM
01/21/16 07:59 AM
Germany, Northcoast
Buschi340 Offline OP
Germany, Northcoast
anyone knows where this tick is coming from?
I have a 2010 6.1 in my dart. It has that tick since i installed the engine 4 years ago. milage was approx 10 thousend when i bought it. swapped cam and valve springs in the last 2 years. not really better. is it coming from the lifters? Don't wanna waste Money, time, work if it is something super simple somewhere else. It really sounds like noisy fuel injectors, just a bit louder... but mine has a carb.
anybody had that too?
Re: HEMI tick? [Re: Buschi340] #1995421
01/21/16 10:55 AM
01/21/16 10:55 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
I have owned 7 vehicles with 5.7 Hemi engines, both cars and trucks. EVERY one of them has/had that tick! The first one was an 06 Charger and the most recent a 2013 Charger, there is an 09 Ram and a 2011 Ram as well as an 06 Ram in the mix so it appears to be consistent.
Driving modern convenience in classic beauty
Re: HEMI tick? [Re: Buschi340] #1995484
01/21/16 01:19 PM
01/21/16 01:19 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
I thought I read somewhere it was the valve guides but I have been wrong before.
Re: HEMI tick? [Re: Buschi340] #1995509
01/21/16 02:31 PM
01/21/16 02:31 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
my 05 Daytona,5.7 hemi has a tick,never went away don't hurt how it runs
Re: HEMI tick? [Re: Buschi340] #1996734
01/23/16 12:25 AM
01/23/16 12:25 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Yeah, they tick. I work in a Dodge dealership. So I know they tick. Look up the factory cam lift specs. This is with hydraulic lifters. It's amazing they don't tick more than they already do.
[image][/image]
Re: HEMI tick? [Re: Buschi340] #1998236
01/25/16 09:59 AM
01/25/16 09:59 AM
Germany, Northcoast
Germany, Northcoast
but it is really loud ( for my taste ). Like i know from my old SB Rockers. Just a bit different in the Sound. higher frequence. Am I too sensitive? smile Can a change of all Rockers fix it? or first a test with thicker oil like 10w40?
Re: HEMI tick? [Re: Buschi340] #1998255
01/25/16 11:12 AM
01/25/16 11:12 AM
Canada
onig Offline
onig  Offline
Canada
So this is a common situation, what is ticking?
69 Dart
Re: HEMI tick? [Re: Buschi340] #1998517
01/25/16 05:14 PM
01/25/16 05:14 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I replace quite a few broken exhaust studs for ticks in them, pull the whole manifold new gasket and copper coat it reinstall with all new grade 8 bolts and tq to spec.
I have heard a couple others with ticks internally that seem to just keep going. Had one where the VCT thingy was making noise, he had me swap the whole engine as the truck had almost 300,000 and the truck (2011) was imaculate, found a whole "low miles" engine for not much more than the dealer wanted for the VCT and chain and guides, gaskets...
Re: HEMI tick? [Re: Buschi340] #1998550
01/25/16 06:41 PM
01/25/16 06:41 PM
CJD AUTOMOTIVE Offline
X2 on the exhaust bolts. Did lots of them at the dealer and in my own shop now. I'd recommend sticking with the factory bolts. The washer made on it is cone shaped to allow expansion and contraction of the manifold. BTW, this is what breaks the bolts. Stick with the OE gasket and I wouldn't coat it. The material on the gaskets' head side is designed for aluminum and the manifold side is steal shim crush. Never seen a factory gasket leak until the bolt broke.
With all that said, if it did it since new, it's probably the lifters and/or injectors. The lifters all have a slight tick. The injectors are just loud. The 6.1 is probably the loudest because of the little covers from the coils that don't quite cover the injector. They also have none of the sound absorbing foam like the 5.7 engine covers. I take a new under manifold foam insulator and cut it to fit under the little covers and around the injectors. Speaking of the insulator, you said you were carb'd. Not sure if you removed the insulator, but if so, do you have room under the intake to put the factory foam insulator back in? This may not cure it 100%, but will make a noticeable difference.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: HEMI tick? [Re: Buschi340] #1998717
01/25/16 11:05 PM
01/25/16 11:05 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
The exhaust bolt ive replaced, 2 4.7's and 1 5.7 Hemi, were all the bolts with an extra stud and nut that ALSO held the heat shields on them. The heat shields have slotted holes in them for expansion. My "fix" is double nut those heat shield bolts while the first nut is just SNUG.
Mopar to the bone!!!
Re: HEMI tick? [Re: 72Swinger] #1999035
01/26/16 03:16 PM
01/26/16 03:16 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My 12' Challenger Classic has the very well known tick also. I can only ever hear it if I am in a drive thru window & then I can hear it reflect off the wall with the car window down.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: HEMI tick? [Re: 6PKRTSE] #1999388
01/26/16 11:12 PM
01/26/16 11:12 PM
USA
Suregrip391 Online content
Suregrip391  Online Content
USA
The ticking noise got MUCH quieter when I switched over to 5W/20 pennzoil platinum synthetic in my wife's 5.7
It ticked so loud using conventional motor oil.
Re: HEMI tick? [Re: Buschi340] #1999532
01/27/16 01:14 AM
01/27/16 01:14 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
My 05 has ticked since new, it's noticeably worse after an oil change. I've run Mobil 1 synthetic in it, tried both 5W20 and 5W30, no difference in noise.
My passenger side exhaust manifold heat shield has also rusted off, lol
Re: HEMI tick? [Re: Blusmbl] #1999645
01/27/16 11:21 AM
01/27/16 11:21 AM
IN
ahy Offline
ahy  Offline
IN
I've had 4 gen III's and they all have a light tick... a bit like like a solid flat tappet cam. Last one I ran to 175k and no issues.
I did once have a warped manifold and leak... that was louder and showed up only when cold. New manifold + gasket (dealer) fixed it though it could have been re-surfaced also.
Re: HEMI tick? [Re: Buschi340] #1999885
01/27/16 05:49 PM
01/27/16 05:49 PM
I have noticed that any oil filter besides a Mopar makes the start up tick worse. I would think you guys are using Mopar filters?!
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: HEMI tick? [Re: Buschi340] #1999977
01/27/16 08:17 PM
01/27/16 08:17 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Mine isn't on startup, it's just noisy lifters at idle, mostly with a warm engine.
Re: HEMI tick? [Re: CJD AUTOMOTIVE] #2000083
01/27/16 10:45 PM
01/27/16 10:45 PM
IN
ahy Offline
ahy  Offline
IN
MOPAR filter here... after getting a quick lube change on the road with generic filter it had bad start up tick.
Light tick idling warm seems to be the normal nature of the beast.
Re: HEMI tick? [Re: Buschi340] #2000457
01/28/16 02:52 PM
01/28/16 02:52 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Nope, Wix filters here. A different filter isn't going to cause or cure a tick.
Re: HEMI tick? [Re: 6PKRTSE] #2000462
01/28/16 03:04 PM
01/28/16 03:04 PM
On start up it will. After it's running it won't.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: HEMI tick? [Re: Buschi340] #2000499
01/28/16 03:42 PM
01/28/16 03:42 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I seen plenty of fram filters cause tics in my life, especially when I worked at wal mart back in the day and that was what we put on, we would get all kinds of complaints about tics that started after oil changes and we would fix them by putting on a different brand... ANY BRAND seemed to fix it most of the time!
