`56 Plymouth modern front end swap advice
#1962414
12/03/15 02:24 PM
12/03/15 02:24 PM
Posts: 1,675 Caldwell, Idaho
67R/T4speeder
Caldwell, Idaho
I have a `56 Plymouth car that I would like to put a 360 4-speed in and was considering a whole front suspension upgrade at the same time, maybe Heidts ??. Keeping the outside looking stock .
Any input from anyone that's been there done that would be appreciated.
pismopowerwagon@aol.com
Re: `56 Dodge modern front end swap advice
[Re: 67R/T4speeder]
#1962477
12/03/15 03:47 PM
12/03/15 03:47 PM
Posts: 27,205 Rio Linda, CA
John_Kunkel
The Erection Connection
Rio Linda, CA
My '56 Plymouth with 360 and 5-speed has a '91 Dakota front clip spliced to the original frame. Modern ball joint suspension, power R&P steering and disc brakes.
Mine has 2" dropped spindles so I don't know how the ride height would be stock.
[Re: 67R/T4speeder]
#1962643
12/03/15 07:47 PM
12/03/15 07:47 PM
67R/T4speeder
Caldwell, Idaho
WOW that make me want to drop it a bit Front width looks right too. Very nice incentive for sure thank you
[Re: John_Kunkel]
#1962693
12/03/15 09:17 PM
12/03/15 09:17 PM
moparpollack
Lil Herman
Lil Herman
85086
Any build pictures?
[Re: moparpollack]
#1963167
12/04/15 02:28 PM
12/04/15 02:28 PM
John_Kunkel
Rio Linda, CA
The work was done by the PO.
[Re: John_Kunkel]
#1964880
12/07/15 12:28 PM
12/07/15 12:28 PM
67R/T4speeder
Caldwell, Idaho
Do you use wheel adapters to get away from the 6 lugs Dakota? Any idea what year donor truck is preferred? Thanks Andy
[Re: dogdays]
#1964881
12/07/15 12:29 PM
12/07/15 12:29 PM
67R/T4speeder
Caldwell, Idaho
There are all sorts of mustang II-based front ends out there, such as Heidt's or Fatman, and they have been working for years. I believe with most of those setups you keep your existing framerails. The aftermarket is full of upgrade parts for this basic setup. The same basic setup was used on the Granada so don't let someone tell you it isn't strong enough.
The Dakota swap is very popular here and it looks like that's because it is a good one. People either swap the whole frame or else cut and weld the new front end to the old back half of the frame.
I wonder when Dakotas are going to become scarce, they aren't really valued for much else and they are scarce on the roads right now. Probably quite a few sitting besides barns, though.
The Crown Vic is way too wide for a '50s car and there's no easy way to narrow it, as the crossmember is an aluminum casting. The rack and pinion is another problem. Hard to make it shorter...On the other hand, the Crown Vic would be just right for my '50 Buick, now there's a thought.
R. Thanks I like the Dakota idea
[Re: 67R/T4speeder]
#1965007
12/07/15 04:27 PM
12/07/15 04:27 PM
John_Kunkel
Rio Linda, CA
Andy
My lugs are 5 X 4.5" so it might be a '90 clip or rotors were changed...junkyard receipt says it was a '91.
[Re: 67R/T4speeder]
#1993462
01/18/16 05:03 PM
01/18/16 05:03 PM
67R/T4speeder
Caldwell, Idaho
OK its not a Dodge I oops it a Plymouth Plaza I got excited with a new project. Found a Dakota the other day also. So here we go!!
Plaza straight six is suppose to be good runner so I will test it out where it is and if good I have `40 that could use it.
[Re: 67R/T4speeder]
#1995691
01/21/16 05:35 PM
01/21/16 05:35 PM
67R/T4speeder
Caldwell, Idaho
Found a decent truck for the swap, it has PS. PB. at least so those parts will come in handy. Dang it even runs so I can move it around at the shop tell I am ready. I have lots of measuring to do, better get a new tape measure ready.
Anyone need a service bed ? LOL
[Re: 67R/T4speeder]
#1995833
01/21/16 08:21 PM
01/21/16 08:21 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Anyone need a service bed ? LOL Those Service Truck Beds make killer trailers I built a fleet of them years ago for my workers out of old utility trucks. Rickster
