Dana 60 pinion seal #199825
01/21/09 10:51 AM
01/21/09 10:51 AM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
I have one leaking. Is it as easy as removing the yoke, and remove and replace the seal? Is there something about getting it back in the same place as not to disturb pinion depth?
Thanks,
JN
Re: Dana 60 pinion seal [Re: PS Arrow] #199826
01/21/09 11:04 AM
01/21/09 11:04 AM
Fort Worth, Texas
Mike Miller Offline
Mike Miller  Offline
Fort Worth, Texas
Pinion depth and bearing preload are set with shims so nothing will change...... pull the yoke and replace the seal!!!
Re: Dana 60 pinion seal [Re: PS Arrow] #199827
01/21/09 11:05 AM
01/21/09 11:05 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Thanks,
JN
Pull the yoke,replace the seal,so easy a caveman can do it.
Re: Dana 60 pinion seal [Re: B G Racing] #199828
01/21/09 11:09 AM
01/21/09 11:09 AM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
Hey I may resemble that
Thanks for the replies!!!
Now...what do I torque it to when I reinstall?
goodntight???
Re: Dana 60 pinion seal [Re: PS Arrow] #199829
01/21/09 11:24 AM
01/21/09 11:24 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Good and tight,I never use the torque spec cause of the different nuts,thread lockers and etc.If you want try 150#s or airwrench tight.I seen guys pull the threads in the nut or on the pinion trying to get 250# to 270#
Re: Dana 60 pinion seal [Re: PS Arrow] #199830
01/21/09 11:37 AM
01/21/09 11:37 AM
NY usa
540challenger Offline
NY usa
All good advise but make sure when you pull the yoke to look at the area that the seal rides the yoke.
It can be worn and need a sleave or to be replace and a new seal will not fix the leak if that is the case.
Must of the time it is just the seal just keep
Re: Dana 60 pinion seal [Re: 540challenger] #199831
01/21/09 12:12 PM
01/21/09 12:12 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If the yoke is worn it can be turned down and have a wearsleave installed or just remove the spring from the seal and seperate it where it is joined and cut a 1/4" of the female side and re-join it making it a tighter fit.
Re: Dana 60 pinion seal [Re: PS Arrow] #199832
01/21/09 12:32 PM
01/21/09 12:32 PM
PA
Z
zooom Offline
zooom  Offline
Z
PA
The assembly torque setting might not matter [except if too loose] if you're setting up a race-only differential, but for a street car rear you'll be better off to refer to the OE pinion nut spec for the one you're working on. Incorrect pinion nut torque leads to all kinds of gear/bearing noise as the bearing preload & gear backlash settings change over time. Typical pinion nut torque for a D-60 is about 250-275 ft-lbs. - a very "tight" setting, for a new assembly. However, if you are working with an existing differential setup the best approach is to measure the pinion rotating torque [prior to disassembly] and remenber to restore the setup to this rotating torque value after you remove the nut/replace the seal/replace the nut/torque it down. Experienced "rear" workers can sense the rotating pinion torque by their hands; other mechanics use an in-lb torque wrench to measure it. Both methods work well & will give you a better assembly!
Re: Dana 60 pinion seal [Re: zooom] #199833
01/21/09 12:36 PM
01/21/09 12:36 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Walt,If the pinion was setup correctly,most Dana 60s use shims to preload the pinion to 20lbs in.this will never change.It's not like crush sleeves the are found in 8-3/4s and Spicers
Re: Dana 60 pinion seal [Re: B G Racing] #199834
01/21/09 02:23 PM
01/21/09 02:23 PM
that is exactly right
Re: Dana 60 pinion seal [Re: Cab_Burge] #199835
01/22/09 08:11 AM
01/22/09 08:11 AM
Sun City, Fla.
tpahemi Offline
tpahemi  Offline
Sun City, Fla.
John, I believe the rear is overfilled with oil. Call and I tell you the history of that rear.
