HEMI tick?
#1995383
01/21/16 07:59 AM
01/21/16 07:59 AM
Posts: 468 Germany, Northcoast
Buschi340
Germany, Northcoast
anyone knows where this tick is coming from? I have a 2010 6.1 in my dart. It has that tick since i installed the engine 4 years ago. milage was approx 10 thousend when i bought it. swapped cam and valve springs in the last 2 years. not really better. is it coming from the lifters? Don't wanna waste Money, time, work if it is something super simple somewhere else. It really sounds like noisy fuel injectors, just a bit louder... but mine has a carb.
anybody had that too?
Re: HEMI tick?
[Re: Buschi340]
#1995421
01/21/16 10:55 AM
01/21/16 10:55 AM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
I have owned 7 vehicles with 5.7 Hemi engines, both cars and trucks. EVERY one of them has/had that tick! The first one was an 06 Charger and the most recent a 2013 Charger, there is an 09 Ram and a 2011 Ram as well as an 06 Ram in the mix so it appears to be consistent.
Driving modern convenience in classic beauty
Re: HEMI tick?
[Re: Buschi340]
#1996734
01/23/16 12:25 AM
01/23/16 12:25 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Yeah, they tick. I work in a Dodge dealership. So I know they tick. Look up the factory cam lift specs. This is with hydraulic lifters. It's amazing they don't tick more than they already do.
[image][/image]
Re: HEMI tick?
[Re: Buschi340]
#1998255
01/25/16 11:12 AM
01/25/16 11:12 AM
Posts: 361 Canada
onig
Canada
So this is a common situation, what is ticking?
69 Dart
Re: HEMI tick?
[Re: Buschi340]
#1998517
01/25/16 05:14 PM
01/25/16 05:14 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I replace quite a few broken exhaust studs for ticks in them, pull the whole manifold new gasket and copper coat it reinstall with all new grade 8 bolts and tq to spec.
I have heard a couple others with ticks internally that seem to just keep going. Had one where the VCT thingy was making noise, he had me swap the whole engine as the truck had almost 300,000 and the truck (2011) was imaculate, found a whole "low miles" engine for not much more than the dealer wanted for the VCT and chain and guides, gaskets...
Re: HEMI tick?
[Re: Buschi340]
#1998550
01/25/16 06:41 PM
01/25/16 06:41 PM
Posts: 656 Florida
CJD AUTOMOTIVE
X2 on the exhaust bolts. Did lots of them at the dealer and in my own shop now. I'd recommend sticking with the factory bolts. The washer made on it is cone shaped to allow expansion and contraction of the manifold. BTW, this is what breaks the bolts. Stick with the OE gasket and I wouldn't coat it. The material on the gaskets' head side is designed for aluminum and the manifold side is steal shim crush. Never seen a factory gasket leak until the bolt broke.
With all that said, if it did it since new, it's probably the lifters and/or injectors. The lifters all have a slight tick. The injectors are just loud. The 6.1 is probably the loudest because of the little covers from the coils that don't quite cover the injector. They also have none of the sound absorbing foam like the 5.7 engine covers. I take a new under manifold foam insulator and cut it to fit under the little covers and around the injectors. Speaking of the insulator, you said you were carb'd. Not sure if you removed the insulator, but if so, do you have room under the intake to put the factory foam insulator back in? This may not cure it 100%, but will make a noticeable difference.
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: HEMI tick?
[Re: Buschi340]
#1998717
01/25/16 11:05 PM
01/25/16 11:05 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
The exhaust bolt ive replaced, 2 4.7's and 1 5.7 Hemi, were all the bolts with an extra stud and nut that ALSO held the heat shields on them. The heat shields have slotted holes in them for expansion. My "fix" is double nut those heat shield bolts while the first nut is just SNUG.
Mopar to the bone!!!
Re: HEMI tick?
[Re: 72Swinger]
#1999035
01/26/16 03:16 PM
01/26/16 03:16 PM
Posts: 4,573 Motor City
6PKRTSE
Motor City
My 12' Challenger Classic has the very well known tick also. I can only ever hear it if I am in a drive thru window & then I can hear it reflect off the wall with the car window down.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: HEMI tick?
[Re: Buschi340]
#1999532
01/27/16 01:14 AM
01/27/16 01:14 AM
Posts: 8,171 Plymouth, MI
Blusmbl
Plymouth, MI
My 05 has ticked since new, it's noticeably worse after an oil change. I've run Mobil 1 synthetic in it, tried both 5W20 and 5W30, no difference in noise.
My passenger side exhaust manifold heat shield has also rusted off, lol
Re: HEMI tick?
[Re: Buschi340]
#1999885
01/27/16 05:49 PM
01/27/16 05:49 PM
Posts: 656 Florida
CJD AUTOMOTIVE
I have noticed that any oil filter besides a Mopar makes the start up tick worse. I would think you guys are using Mopar filters?!
Re: HEMI tick?
[Re: Buschi340]
#1999977
01/27/16 08:17 PM
01/27/16 08:17 PM
Blusmbl
Plymouth, MI
Mine isn't on startup, it's just noisy lifters at idle, mostly with a warm engine.
Re: HEMI tick?
[Re: CJD AUTOMOTIVE]
#2000083
01/27/16 10:45 PM
01/27/16 10:45 PM
Posts: 7,664 IN
ahy
IN
I have noticed that any oil filter besides a Mopar makes the start up tick worse. I would think you guys are using Mopar filters?! MOPAR filter here... after getting a quick lube change on the road with generic filter it had bad start up tick. Light tick idling warm seems to be the normal nature of the beast.
Re: HEMI tick?
[Re: Buschi340]
#2000457
01/28/16 02:52 PM
01/28/16 02:52 PM
6PKRTSE
Motor City
Nope, Wix filters here. A different filter isn't going to cause or cure a tick.
Re: HEMI tick?
[Re: 6PKRTSE]
#2000462
01/28/16 03:04 PM
01/28/16 03:04 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Nope, Wix filters here. A different filter isn't going to cause or cure a tick. On start up it will. After it's running it won't.
Re: HEMI tick?
[Re: Buschi340]
#2000499
01/28/16 03:42 PM
01/28/16 03:42 PM
HotRodDave
Kalispell Mt.
I seen plenty of fram filters cause tics in my life, especially when I worked at wal mart back in the day and that was what we put on, we would get all kinds of complaints about tics that started after oil changes and we would fix them by putting on a different brand... ANY BRAND seemed to fix it most of the time!
