Rivets #1997118
01/23/16 03:55 PM
01/23/16 03:55 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
Does anyone make restoration rivets for the 70 coromet bumper fillers?
Re: Rivets [Re: 70 buzz] #1997163
01/23/16 05:17 PM
01/23/16 05:17 PM
Canada
ACR2000 Offline
ACR2000  Offline
Canada
Do you have a pic of the actual rivet..
Re: Rivets [Re: 70 buzz] #1997165
01/23/16 05:25 PM
01/23/16 05:25 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
Actually I do. Looked at a used one I have.it is more of a plastic nail instead of a rivet. Has a large head with retaining threads on the end. It looks like something you would pounds to a hole to hold down. Head is .5, thread thickness .275, overall length .685.
Re: Rivets [Re: 70 buzz] #1997359
01/23/16 10:24 PM
01/23/16 10:24 PM
Georgia
69bfan Offline
69bfan  Offline
Georgia
Check Restoration Specialties at www.restorationspecialties.com under the nylon rivet section. Several applications may meet your needs. I can measure some of them tomorrow and provide more details at that time.
www.restorationpartsandmaterials.com
Correct Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs.
www.dalescudashop.com
Correct style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
Re: Rivets [Re: 69bfan] #1997396
01/23/16 11:05 PM
01/23/16 11:05 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
. Sounds good and thanks
Re: Rivets [Re: 70 buzz] #1997725
01/24/16 03:00 PM
01/24/16 03:00 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
I picked up a set at Totally Auto. They have the metal rivets also. Do you have the metal shape retaining pieces also?
Re: Rivets [Re: Pynzo] #1997728
01/24/16 03:05 PM
01/24/16 03:05 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
no
Re: Rivets [Re: Pynzo] #1997748
01/24/16 03:28 PM
01/24/16 03:28 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
do you have a picture of it
Re: Rivets [Re: 70 buzz] #1997812
01/24/16 05:21 PM
01/24/16 05:21 PM
Georgia
69bfan Offline
69bfan  Offline
Georgia
I measured two of the most common applications as used on the Mopars and the one that measures out closest to yours has the following dimensions.
Head Diameter: 0.498 inches
Overall Length: 0.703 inches
Shank Diameter @ Head: 0.144 inches
Shank Diameter @ Ribbed Area: 0.279 inches
The dimensions for the rivet as described above was used on some of the 66 to 67 cars where the rear bumper filler was attached to the body panel.
The most common nylon rivet used throughout the Mopar line has the following dimensions and most commonly were found on say your inner fender top rear C shaped splash shield. The dimensions are as follows:
Head Diameter: 0.496 inches
Overall Length: 0.588 inches
Shank Diameter @ Head: 0.146 inches
Shank Diameter @ Ribbed Area: 0.272 inches
Let me know if you should have any questions as these are common components for our weatherstrip kits.
Re: Rivets [Re: 70 buzz] #1997847
01/24/16 06:16 PM
01/24/16 06:16 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
I'll post a pic tomorrow. I have 3, one side worth. They were very rusty so I'll need to make 6.
Re: Rivets [Re: 69bfan] #1997907
01/24/16 07:51 PM
01/24/16 07:51 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
. Thanks, I will do that.
Re: Rivets [Re: Pynzo] #1997911
01/24/16 07:53 PM
01/24/16 07:53 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
Thanks, I did email totally auto to see what they have
Re: Rivets [Re: Pynzo] #1997913
01/24/16 07:54 PM
01/24/16 07:54 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
. Thanks, I emailed totally auto to see what they have.
Re: Rivets [Re: Pynzo] #1997951
01/24/16 08:47 PM
01/24/16 08:47 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
does the metal shape retaining piece go on the bottom of the piece I showed?
Re: Rivets [Re: 70 buzz] #1998093
01/24/16 11:53 PM
01/24/16 11:53 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
The plastic rivets hold the Filler to the top inner bumper frame. These metal shapes are the inner support for the metal rivets that attach the filler to the bumper hoop. The metal rivets are fresh air hood box rivets, and are also used to attach the center bumper painted trim piece.
Third pic shows 2 new plastic rivets on left, 2 OEM on right, and a new air box rivet.
Re: Rivets [Re: Pynzo] #1998225
01/25/16 07:18 AM
01/25/16 07:18 AM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
thanks man, that is great picture an explanation.i appreciate your help.
Re: Rivets [Re: Pynzo] #1999668
01/27/16 11:05 AM
01/27/16 11:05 AM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
Well totally auto didn't get back with Me yea or nay? Any suggestions?
Re: Rivets [Re: 70 buzz] #1999803
01/27/16 02:29 PM
01/27/16 02:29 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Try calling them.
Re: Rivets [Re: 70 buzz] #1999875
01/27/16 04:19 PM
01/27/16 04:19 PM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
I sent you a PM.
68 Charger R/T 440 auto
Re: Rivets [Re: 70 buzz] #1999918
01/27/16 06:08 PM
01/27/16 06:08 PM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
I had to replace some of the rivets that hold the small doors on the various underdash e-body a/c ducts recently, I found some on ebay.
These might be worth a try if you're stuck?
rivets
