Re: Real world weight loss program and it` cost..........
[Re: fullmetaljacket]
#1994643
01/20/16 02:11 AM
01/20/16 02:11 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Hidden treasures.
I'm going to have a chat with my Trans guru "Top Boy" and Rick at A&A about the best light weight internals to use in a real street/strip Manual valve body 65' cable shift trans. I've got two pumps in that pup you know.
Nice to hear from you DVW. Considering taking out my 727 and gear vendor and putting in a 904. It would be over a 70 lb reduction
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
#1994800
01/20/16 12:01 PM
01/20/16 12:01 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Since the first of the year, I am down 23 lbs: -Alum front bumper brackets/fender rods -removing some junk that I need not carry all the time -aluminum inner door handles
I have another 15-20 lbs of weight I can remove off the front end. The goal is to just keep me occupied through the long MI winter. I am not trying to turn the car into a gutted mess, just a simple street cruiser on a diet.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
#1996163
01/22/16 09:37 AM
01/22/16 09:37 AM
Posts: 9,883 MI, usa
dvw
MI, usa
I know, my transmission guy "Top Boy" has those 904's humming behind some really good street small blocks in our clubhouse. I never thought they could survive, but he knows them inside out and with a lot of stock parts that he combines to make for a good piece. To bad a 04 won't snout up to a big block that easy.
Rick over at A&A said to stay away from aluminum drums for a street/strip car. not worth the band adjustments and wear. I also stood away from that lightweight titanium flexplate.
What's up with some Titanium or T-aluminum convertor development? Might work if someones got the time and skills.LOL. Mine being a drag car has lots of aluminum goodies. Though not installed now it even had and aluminum rear annulis (outer planetary) and only 2 pin planets. Even now the 3 pins survive. My trans is 14lbs lighter with a stock 65 case. Doug
[Re: dvw]
#1996218
01/22/16 12:32 PM
01/22/16 12:32 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
FMJ,didn't upgrade the front input shaft to accept 66 & up converter??
[Re: Thumperdart]
#1996348
01/22/16 04:02 PM
01/22/16 04:02 PM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
A&A has a 'race prepped' case they sell. It's probably a little lighter than your garden variety TF case though I'm not sure how much; we're probably talking a pound or less. They machine an access hole into the bell for converter bolt access so I'm sure that accounts for most of the weight difference. The best thing about it though (besides being sparkly clean) is they tap the pan rail for external pressure adjustments so you don't have to remove the pan to do it. There's a tap for a trans brake too. I got one for my 904, really nice to work with.
Lee, do you still have the ball & trunion?
'71 Duster '72 Challenger '17 Ram 1500
#1996424
01/22/16 05:29 PM
01/22/16 05:29 PM
fullmetaljacket
Okay, here we go. A little use of L shape aluminum stock goes to good placement.
#1996433
01/22/16 05:51 PM
01/22/16 05:51 PM
fullmetaljacket
A little bend here, a little bend there and a visit with the welder to the sides and we are close to a bolt in front bumper mount boss. This little, but long and patient process takes 2 Lbs off the very front end. Cutting and removing the steel piece and measuring in the new light alloy part is a task to say the least. Everything up front except the fenders needs to come off for easier access with cutting tools, sanders and chisels.
It will look stock once the aluminum flushed pan head bolts and nuts are covered with a little flash putty to hide the mount points. Will show the finished slick results at a later date.
A senior moment, but not sure if the A-bodies and or E-bodies have similar mount bosses. Is this true?
[Re: Thumperdart]
#1996515
01/22/16 07:34 PM
01/22/16 07:34 PM
RMCHRGR
Spahn Ranch
For a second there I thought you were gonna recreate that entire rad support out of aluminum.... are you? ![shock shock](/ubbthreads/images/graemlins/custom/shock.gif)
[Re: RMCHRGR]
#1996531
01/22/16 08:03 PM
01/22/16 08:03 PM
fullmetaljacket
Partly.
The radiator support top and bottom cross bridge rails are the most difficult, but once they would be made, I'm not comfortable with just bolting them on as cross hinge in place of welding. They are structural to the chassis strength contrary to the belief of the K-member taking all the blame.
The stamped side walls are easier, but still time consuming.
There's a lightweight A-990 repro version on E-vague for only $$$$$$800 LOL.
If only aluminum/Titanium could weld to other steel structures. That being said, there is belief that bolting something to another is actually stronger than welding (Bridges, elevated Subway tracks etc) But I still want a weld. So on that note, no, I will not recreate the whole thing, but there will be a small portion of the frame rail longitude made out of aluminum that will slip into the original and blind bolt through. Everything else will reinstall and look stock and weigh less.
When Skicker saw the twinkle in my eyes at Carlisle when I was looking this very same cross member part at his booth, he pretty much said, I know you are up to no good. We laughed our a&$es off. By the way, at his booth up against the fence at gate #7, he has an abundance of small and large parts along with the knowledge to help almost anybody. He's a great source of fact and chat.
#1997393
01/24/16 12:01 AM
01/24/16 12:01 AM
dvw
MI, usa
DVW. I can't ever try and question your set up as it runs like stink. Have you ever asked if the deletion of the rear pump could be happy in a street/strip car like mine? I'll have to ask this to my trans guru. I see no reason for the rear pump. I Take a good look at the rear lube circuit (cooler return) to make sure there's not an internal leak path. The current trans has a seal pressed in behind the roller bearing in the rear support. I've run them w/o the seal but not on the street. Doug
