478 Hemi #1996955
01/23/16 01:22 PM
01/23/16 01:22 PM
Canada
Cape Offline OP
Cape  Offline OP
Canada
Hey everyone. I have a Hemi that's more set up for drag racing it's a 12:5.1 cp Pistons the cam is huge a solid roller 800 lift 292int 294ex. Heads are stock Mopar crate motor heads with better valves and comp springs the heads are cast. the block is a world block bored 30 over. My question is I want to make it more street and was wondering what you would do to it? Can I use the Pistons that are in it on pump gas? I don't really want to have them cut to make it work. Cam selection is up to you. If I forgot anything let me know. Thanks.
I guess my question is is it possible to use this short block and cast heads on pump gas. But changing cam and springs and valves. Thanks
Re: 478 Hemi [Re: Cape] #1996990
01/23/16 02:05 PM
01/23/16 02:05 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
That's a lot of compression with cast iron heads for pump gas. I don't think you could get away with a thicker head gasket to kill enough compression. If the domes are solid, you might be able to mill some off the top. Lowering cam duration is only going to raise cranking compression at this point, and make matters worse for using pump gas. E85 fuel might be an option, but that depends on availability in your area.
[image][/image]
Re: 478 Hemi [Re: Cape] #1997105
01/23/16 04:43 PM
01/23/16 04:43 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Only things I would change is reduce the compression 1pt down to 11:5 with Cometec gaskets, and switch to a milder cam under .740 lift....That's it really. Hemi's will tolerate a lot of compression on 93. What intake and carb(s)?
Re: 478 Hemi [Re: Cape] #1997126
01/23/16 05:07 PM
01/23/16 05:07 PM
Canada
Cape Offline OP
Cape  Offline OP
Canada
I have a 1050 dominator on it now and a Mopar single plane intake that I'm thinking of getting machined to fit the 1050 without the spacer.
Re: 478 Hemi [Re: Cape] #1997262
01/23/16 09:16 PM
01/23/16 09:16 PM
Dragula Offline
Dragula  Offline
If that is the M1, those were horrible for fuel distribution for us....and would be the last intake I would use....A modmad with interchangeable tops if hood clearance is a must....Or a Dick Landy one converted to a 4500....I know somebody is repoping those, just can't find it...
http://www.hotrod.com/how-to/engine/hrdp-1008-dick-landy-484-hemi-engine/
Re: 478 Hemi [Re: Cape] #1997324
01/23/16 10:34 PM
01/23/16 10:34 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
You could drop to a 6.76 rod, if you're on a 6.86. Then use a thin head gasket. You'd be near 10.5:1.
Re: 478 Hemi [Re: Cape] #1997365
01/23/16 11:28 PM
01/23/16 11:28 PM
Canada
Cape Offline OP
Cape  Offline OP
Canada
The intake looks just like the Barton one but a 4150 one. The rods are stock size 426 rods.are you talking about getting rid of my single plane for a duel plane?
Re: 478 Hemi [Re: Cape] #1997635
01/24/16 01:31 PM
01/24/16 01:31 PM
Dragula Offline
Dragula  Offline
No, not exactly...It was a heavily modified 4150 dual plane, and they made it into a 4500 single plane...I would never run a dual plane on anything unless its the only option for hood clearance, and then I usually turn it into a single plane as best as I can...The Modman is also an option.
Found it....Indy Heads catalogue pg 22, although it states its still a dual plane. The ones I have seen in use were not. The inside was all gutted out to make a low profile single plane...
http://www.indyheads.com/images/22.cat2014.pdf
If hood clearance isn't an issue, I would go with stay with what you have...Plugs have looked the best with the Indy or the Barton ones we have tested.
Re: 478 Hemi [Re: Cape] #1998057
01/25/16 12:09 AM
01/25/16 12:09 AM
Canada
Cape Offline OP
Cape  Offline OP
Canada
The one I have is a single plane one that even without the spacer I still can't use a dominator on it with a stock hood. Thanks for the info on the other intake. I'd still like to use my dominator on the street and that intake would do the trick.
Re: 478 Hemi [Re: Dragula] #1998134
01/25/16 01:43 AM
01/25/16 01:43 AM
Dragula Offline
Dragula  Offline
Modman....Pick a top plate and go. Never tried one, but on 478 cubes it should work fairly well. Or you could buy the Hemi intake I have for sale....in the race section 1st pg, but that won't fit under most hoods either.
http://www.indyheads.com/images/news3.2012.pdf
Re: 478 Hemi [Re: Cape] #1998284
01/25/16 12:02 PM
01/25/16 12:02 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
Dragula...the intake he has looks just like the Barton single plane, it's just a 4150 flange. Sold as a MP part and has "MOPAR" cast where the typical Barton logo would be.
You should be able to redo the flange on this manifold for the 4500 pattern. It's shorter than the Barton manifold and I have seen the Barton manifold cut down to fit under the hood.
Cape...hemis can tolerate a lot of compression w/ pump gas. There's a few around 12:1 doing it. I'd try a thick head gasket and get a custom cam ground for it. Call Dwayne Porter for a cam. 802-951-1955
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 478 Hemi [Re: Cape] #1998337
01/25/16 01:36 PM
01/25/16 01:36 PM
Canada
Cape Offline OP
Cape  Offline OP
Canada
Thanks for all the help guys. Here's another question. I had to use taller valve covers because of the taller springs for the solid roller cam. I'd like to switch back to stock valve covers but still make decent power with a smaller cam. How big of a cam can you use and still maintain stock valve covers? I don't care if it's less hp how the motor sits now it made 740@7000 so to go to something smaller and a little easier on the valve train would be great. Thanks again.
Re: 478 Hemi [Re: Cape] #1998346
01/25/16 01:42 PM
01/25/16 01:42 PM
Alberta,Canada
605ply Offline
605ply  Offline
Alberta,Canada
another option with intake is two fours..they'd fit under your hood...just found a stage V for500 cdn on kijiji......but edelbrock makes2x4 manifold, summit price us477$(if memory serves price has just gone up 50$+)..edelbrock carbs are cheap and plentiful and work quite well
...dominator won't work on a modman..
Re: 478 Hemi [Re: 605ply] #1998677
01/25/16 10:10 PM
01/25/16 10:10 PM
Dragula Offline
Dragula  Offline
Again, get one of those all milled out like a single plane, or a modman....
Re: 478 Hemi [Re: Dragula] #1998682
01/25/16 10:23 PM
01/25/16 10:23 PM
Alberta,Canada
605ply Offline
605ply  Offline
Alberta,Canada
the stage v and eddie are single plane...you can put a dominator on a modman i wouldn't
Re: 478 Hemi [Re: Cape] #1998995
01/26/16 01:51 PM
01/26/16 01:51 PM
wappinger falls new york
Jimi_Vignogna Offline
every street hemi with cast iron heads I ran @ 12.5 to 1 on pump gas. the only aluminum head engine was 13.2 to one on pump gas. never had a problem
Re: 478 Hemi [Re: Jimi_Vignogna] #1999464
01/27/16 12:12 AM
01/27/16 12:12 AM
Dragula Offline
Dragula  Offline
They will tolerate a lot more than most. I never ran iron heads on pump gas at over 12:1, but the aluminum's will definitely tolerate 12:1.
Re: 478 Hemi [Re: Cape] #1999529
01/27/16 01:09 AM
01/27/16 01:09 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I built mine with only 10.4-1. Most of the time all I've got to work with is 87.Dave
