Re: opinions on M & H tires
[Re: DamienH]
#199763
01/21/09 07:12 PM
01/21/09 07:12 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
i talked to the guys at the PRI show and they said they will work better at the track than MT will but was told flat out they wont last as long. they looked really nice and i was just on M&H's website and found out they are much cheaper than buying from jegs. there is also some Tiger code that will give rebates. i have some friends looking into this tiger code for me right now. i think i'm going to give them a try next
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#199764
01/21/09 08:48 PM
01/21/09 08:48 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
We used to run M&H before our current Phoenix/Firestone.Never any problems hooking up.We used the original muscle car tire when it was advertised as a stock eliminator tire then on to regular drag slicks.
[Re: Plumcrazyracing]
#199768
01/22/09 07:08 PM
01/22/09 07:08 PM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
I run their slicks. Can't complain. John Hashim at M&H will tell you everything you need to know. He is real good to work with and has a lot of history with M&H. May even give you the "tiger code".
I was fortunate enough to know John's Dad co-founder Ernie Hashim....great people...John truly supports the grass roots guys as best he can and still survive...Famoso Raceway is John's second home he's there alot taking temps on every car rolling through the boxes.
