Re: Mopar SS front spring hangars- 116" & 117" WB
[Re: AndyF]
#1997652
01/24/16 01:53 PM
01/24/16 01:53 PM
RapidRobert
Kinda out on a limb here on this part of it but if the tires are hitting there in the front with 7" front hangars I'm thinking the springs are the wrong ones (at least the front segment is way too short for your app). When sorted out make sure the rear hangar angle is correct also. I like the bottom of the shackles a bit rearward from plumb so the springs can compress when they "work" rather than possibly raising the chassis which can happen if the shackle is forward and the rear eye swings down in an arc as it goes over center. Might not be a dealbreaker but every little bit helps but that'd be the perfect time to get it right then it is done & you dont have to deal with it again. Holler what the spring issue turns out to be
[Re: 808CUDA]
#1997660
01/24/16 02:03 PM
01/24/16 02:03 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
All 69 B bodys had 22 inch front segments.All SS springs are 20 inch.IIRC Andy a member makes the mancini hangers.I know on my 65 the MP hangewrs are wrong and there are 2 one for dodge one Plymouth.I ran big tires on my 69 Beel and had lots of clearance.i diod have the OE springs though.Mancin should have the hangers listed by body and car.Rocky
Chrysler Firepower
[Re: 808CUDA]
#1999071
01/26/16 04:03 PM
01/26/16 04:03 PM
therocks
Niles , Ohio
I was hoping Andy would jump in.he makes them for Mancini IIRC.Nice quality product.I have a set on my 65.Rocky
Chrysler Firepower
